Old 02-06-2020, 10:22 AM #1
chester4Run chester4Run is offline
chester4Run is on a distinguished road
Dagnabit -- License plate light screws
Something to add to the list for new 4Runner owners -- change your license plate light screws to stainless (4 screws).
Mine were badly corroded and when I went to replace a bulb I had extract one of them the hard way. I pushed too hard with extraction bit and snapped off the plastic tab it fastens too up inside. Now I get to replace that whole plastic piece, so it looks like I need to disassemble the tail gate.
Those factory screws were all badly corroded to the point that the heads were completely or nearly gone.
2020 SR5 Tundra 4wd
2015 LE Sienna fwd
2011 SR5 4R 4wd
2004 SR5 4R 4wd v6
1994 SR5 4R 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 10:44 AM #2
LIT4R LIT4R is offline
LIT4R will become famous soon enough
The screws from the dealership are usually low quality, which is a funny place to skimp. My father has been a used car manager for many years and I always found it funny how every time I buy a new (see "used") car, the first thing out of his mouth is, "Go to Lowe's and get stainless screws." They really do work.
LIT4R is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:10 AM #3
mustangr2 mustangr2 is offline
mustangr2 will become famous soon enough
This is my list. I was surprised how bad they were after a year. It was brutal getting them off.
mustangr2 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 01:09 PM #4
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Ace Hardware had a nice selection of plate bolts in all sizes and materials in their nut/bolt/washer section. It's in one of the little pull out trays.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 01:28 PM #5
MannMade82 MannMade82 is offline
Real Name: Jason
MannMade82 is on a distinguished road
Real Name: Jason
I believe the OP is referring to the screws securing the lenses for the license plate lights. But it is also important to use stainless bolts on the actual license plate(s), along with a license plate frame that doesn't rust. If the frame isn't plastic or aluminum, it doesn't last one Ohio winter for me.
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 02:40 PM #6
curmudge1 curmudge1 is offline
Real Name: Dave
curmudge1 is on a distinguished road
Real Name: Dave
Question What size replacements?
I had similar problem when I replaced one of the light bulbs last fall. Pushed the tab up, and it's kind of out of line now.
I wanted to replace the screws, but what size? If you did, then do you recall what size screws? Did you get stainless replacements at hardware store/big box/marine supply?
Thanks.
Dave
2012 red Trail Edition
curmudge1 is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 03:07 PM #7
Thanks.
Dave
I used stainless sheet metal screws from Ace. I don't recall the size, but it's easy to match against the screws you have. It's going into plastic, so mostly just make sure the head isn't much larger than OEM.
2020 SR5 Tundra 4wd
2015 LE Sienna fwd
2011 SR5 4R 4wd
2004 SR5 4R 4wd v6
Old 02-06-2020, 03:10 PM #8
Confirmed. I'm talking about the lights above the license plate, specifically the screws that hold them in. I also have stainless screws in the license plate and this silicone license plate holder. Since it has a back and is nice and soft, there is no scratching and no rattle when you close the hatch.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
2020 SR5 Tundra 4wd
2015 LE Sienna fwd
2011 SR5 4R 4wd
2004 SR5 4R 4wd v6
Old 02-06-2020, 03:30 PM #9
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
If you can find new stainless screws for the clear bulb cover great, if not remove screws and coat with fluid film or the like to prevent corrosion and decay. I should pull my bulb cover screws and practice what I preach. I had this issue on a 3rd gen and I can see my 5th gen screws getting rusty.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 10-05-2023, 10:57 AM #10
ghoch30 ghoch30 is offline
ghoch30 is on a distinguished road
Were you able to find just the plastic clips to replace or did you have to replace the whole plastic piece? Just did the same thing yesterday...
ghoch30 is offline   Reply With QuoteReply With Quote
Old 03-16-2025, 01:51 PM #11
eeberhar eeberhar is offline
eeberhar is on a distinguished road
Frustrated but fixed - license plate light screws - 5th Gen 4runner
keep in mind I am not the most mechanically inclined but I really wanted to fix this without going to the dealer. Based on my web searches/experiences - this might help someone.
1. I tried the 'spray with rust lubricant over multiple days' - NO LUCK
2. I tried (bought a dremel) the cut a slot for a flat screwdriver (and I mucked up the screw heads) - NO LUCK
3. I tried the 'drill it out' method even bought a new drill bit - these are from what I read 'iron screws' - I was not able to get them to drill out - NO LUCK
4. I tried the heat the screw up (and I mucked up the lens during this process) - NO LUCK
5. I ended up cutting the plastic lens out and was able to get a vice grip type wrench on the screws and they came out.
I replaced the lens with LED lens that plug into the light bulb slots.
I used #8 stainless screw self tapping screws
Keep in mind
- the screws 'tap' into plastic NOT a metal clip
- the plastic 'tabs' on the rear garnish that you screw the lens into isnt 'strong' the 'outside' screws plastic receiving ends are the weaker of the 2 points of contact
- careful dremeling as I ended up with a big of collateral damage due to lack of dremel skill and lack of patience
Hope someone finds this useful
Dagnabit -- License plate light screws-4runnerlicenseplate1-jpg  Dagnabit -- License plate light screws-4runnerlicenseplate2-jpg  Dagnabit -- License plate light screws-4runnerlicenseplate3-jpg  Dagnabit -- License plate light screws-4runnerlicenseplate4-jpg
eeberhar is offline   Reply With QuoteReply With Quote
Old 03-16-2025, 09:56 PM #12
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I replaced the rusted screws from the license plate light assembly with cheapo stainless from Amazon.
Size is #8 x 5/8”.
The heads on these were a bit oversized so I ground them a bit using a drill and a file.
After a couple years, even the cheapo stainless have a few minor rust spots.
2010 Trail - 146k mi - KDSS - Classic Silver Metallic - Bilstein 5100s - Tires: Michelin X-LT A/S 36psi - Oil: M1 EP 5W/30 - Diffs and T/C: Delvac 75W-90 Synthetic - Toyota WS ATF - ScanGauge - Viofo dashcam - Husky Weatherbeaters - Plasti Dip wheels and chrome delete - Wheel Center Caps delete - Roof Rack Cross Bars delete - Cargo Tray divider delete
1000MPH is offline   Reply With QuoteReply With Quote
badly , corroded , hard , replace , screws
Ughhh- rusted license plate light screws Hapeacres 4th Gen T4Rs 12 11-20-2020 08:28 PM
License Plate Screws/Bolts MaliciousClout 4th Gen T4Rs 11 06-30-2018 11:37 AM
Replacement screws for rear license plate light bulb cover ic0517 5th gen T4Rs 0 06-15-2017 01:47 PM
need some help - license plate screws stuck theliman Maintenance/Detailing 8 01-09-2014 06:50 PM
Repair Bumper Holes (license plate screws) jpless Maintenance/Detailing 2 05-13-2010 06:55 PM
