Old 03-02-2020, 09:43 PM #61
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
Originally Posted by ForRun View Post
Now on a PC it still looks like the cut off is bad upfront and close with the Alpharex. maybe because they put a type of surround from the projectors?
1st pic is yours, 2nd is my old XB and for comparsion I put up the stock H11. In the stock H11 follow the crack center the road, coming towards the runner and shifts to the left. Cant barley see it with the XB. My pics were taken at the same spot within inches of each other. I'll need to wait for more photos. If someone could post before and after shots taken from the exact same spot, camera planted front / center of the steering wheel that would be awesome, thanks
Hey, I got a pic after final aiming. It took a few weeks but I got them at the perfect height now and the HIDs have broken in more. Here's a pic front and center.
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 11:53 PM #62
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Originally Posted by CharlesNellis View Post
So I removed my headlights to see how I insert them in because I wanted to make sure the "rod" was facing down on the bulb.
Turns out they weren't. I was at about a 10 o clock position with the tab and the rod was at 4.
I fixed it so I was at 12 o clock and the rod was now at 6 o clock.
Remounted the lights and now my passenger side had a wacky beam pattern!
I messed around with it a bit and 10 o clock gave me the best pattern on the passenger's side and 12 o clock on the driver's side.
I guess these cheap Amazon HID bulbs may not be on a perfect plane so you have to pick the right spot for them.
I would try to reclock before you return.
So after trying different clocking orientations here is the best cut off line I could get (LED fog lights are disconnected). Also, I did swap out the the Innovited 55W 5000K HID I originally installed to the Innovited 35W 6000K HIDs. With these, here is I how clocked them, tab @ 3o’clock and rod at 9o’clock on both driver and passenger low beam projectors. Cut off line is not as clean as yours, but I guess I can live with it. The wall and pavement I’m parked at is not level, so the wall’s line does look slanted.
*Review* Alpharex Pro headlights-130b8643-53a3-4f9c-bab4-63f471a337a9-jpg
mcat707 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 12:46 AM #63
Yeah that looks way better. I'd be happy with that cutoff. I'm going to swap my 55 watt out to 35 too. I was reading and they say 55 watt only lasts 1000 hours and 35 last 3000. This will be the sixth time i remove the bumper. Pro bumper removal status.
Old 03-03-2020, 01:02 AM #64
mcat707's Avatar
mcat707's Avatar
Yeah the same reason I went to 35W also. I think I’m around that sixth number also. I just hope I don’t reach Legendary status. Even gave me a reason to buy a Milwaukee cordless 3/8 ratchet just for the job.
Old 03-23-2020, 06:05 PM #65
ImJacobJames ImJacobJames is offline
ImJacobJames is on a distinguished road
I saw that Alpha Rex recently came out with the Luxx-Series. Anyone know anything about this?
ImJacobJames is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 06:24 PM #66
mcat707's Avatar
mcat707's Avatar
14-20 Toyota 4Runner Luxx-Series Projector Headlights Mid-Night Black
Looks like the PRO-Series but has an activation light feature and LED headlights. I wonder if the LED headlight bulbs are replaceable by the owner or they have to be shipped back to the manufacturer to replace them?
Old 03-23-2020, 08:26 PM #67
those are clean looking!
Old 04-27-2020, 01:33 PM #68
belmontek84 belmontek84 is offline
belmontek84 is on a distinguished road
Originally Posted by aesthetics View Post
Love my pro lights. Really only takes 10 minutes to pull it. 30 mins first time for me since the 2020 has 2 extra bolts you gotta unscrew under the hood latch for the safety sense I didn't see. Would most likely buy novas in future if they have good beam pattern
Do the pro headlights have a sequential turn signal like the Nova series does?
belmontek84 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 01:37 PM #69
mcat707's Avatar
mcat707's Avatar
The PRO’s do have a sequential turn signal. Just not sure if they are the same as the NOVA’s as I have not seen it on those.
Old 04-27-2020, 03:08 PM #70
Yeah they're sequential. The light starts towards the grill and moves out word.
Old 04-27-2020, 03:11 PM #71
27 Apr 20 Update:
I'm going to be opening up these lights to put a foreground limiter in.
The foreground lighting is way too intense and distracting with HIDs.
Old 05-11-2020, 01:13 PM #72
27 Apr 20 Update:
any new updates on these lights?
Old 05-11-2020, 03:39 PM #73
Nah, been pretty lazy lately.
Old 05-12-2020, 05:06 PM #74
Looking forward to the updates as the become available
Old 06-06-2020, 10:51 AM #75
Triggerhappy Triggerhappy is offline
Real Name: Jake
Triggerhappy is on a distinguished road
Real Name: Jake
For the life of me I cannot figure out the drl’s. Wired correctly, but my high beams still act as the drl.
Also, when the drls are powered, they never shut off. 😐 Thoughts?
Triggerhappy is offline   Reply With QuoteReply With Quote
alpharex , hid , pro , stock , video
Magnuson Supercharger 2K Mile Review and 6K Mile Review bowhun2r 5th gen T4Rs 139 08-24-2023 03:25 PM
Aftermarket black headlights - review and lots of pics fullboogie 4th Gen T4Rs 314 10-01-2021 08:50 AM
GE Night Hawk Platinum Review (headlights) djskorch 3rd gen T4Rs 25 12-03-2018 11:25 PM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
