Old 06-06-2020, 11:53 AM #76
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Originally Posted by Triggerhappy View Post
For the life of me I cannot figure out the drl’s. Wired correctly, but my high beams still act as the drl.
Also, when the drls are powered, they never shut off. *Review* Alpharex Pro headlights Thoughts?
I have the Luxx's so not exactly the same but similar. High beams will still be DRL unless you clip the wire that supplies the lower voltage on the wiring harness from the vehicle. Not sure why they did that. Seems like it could have been powering the new DRL strip instead. As for the Alpharex DRL, you have a fuse tap on the INJ fuse?
NB17Limited is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 12:04 PM #77
Triggerhappy Triggerhappy is offline
Real Name: Jake
Triggerhappy is on a distinguished road
Real Name: Jake
Yeah. The add a fuse is in (ign). Maybe I was hoping they would work from the light stalk to turn on and off.
Which is the low voltage to the vehicle?
Triggerhappy is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 12:40 PM #78
david05111 david05111 is offline
david05111 will become famous soon enough
Just to be clear, does "clip" mean "snip" or "cut"? That's irritating, if so. I really don't want to have to cut wiring harnesses, etc. to be able to install stuff that should basically be plug-and-play.
david05111 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 03:29 PM #79
Yeah they aren't going to do that. Again, if Alpharex had tapped the DRL wire for the new DRLs then you would be able to.
Old 06-06-2020, 03:37 PM #80
Yep. Alpharex doesn't mention doing that but I ran across it in another thread.
Come to think of it, someone who is more handy with electronics could probably wire up something that works correctly. If you could get a male and female versions of the highbeam/DRL harnesses, you could probably pass the highbeam and ground wires through and take the DRL signal and add a capacitor (I think that's what is used to keep LEDs from flickering at pulsing voltages) that then runs to the DRL positive wire.
I do agree though that it is annoying to not be truly plug and play.
Old 06-07-2020, 07:44 AM #81
Real Name: Jake
Real Name: Jake
That’s a bummer. Guess I’ll have to keep playing with em. I do wish it was an actual plug n play.
Old 06-07-2020, 08:07 AM #82
Your best bet for stalk controlled DRLs is to hijack the DRL wire. I think the harness is in the fuse box. I can do some more looking into it. I think the antiflicker adapters for LEDs on other makes of vehicles would work. I have some of those laying around. If I can get the male and female connectors I'll give it a go.
Old 06-08-2020, 11:43 PM #83
nauticalbluetrd's Avatar
nauticalbluetrd nauticalbluetrd is offline
nauticalbluetrd is on a distinguished road
Sheesh that sucks. Let me know if you figure it out.
nauticalbluetrd is offline   Reply With QuoteReply With Quote
Old 06-09-2020, 01:48 AM #84
BEAR x SF's Avatar
BEAR x SF BEAR x SF is offline
BEAR x SF will become famous soon enough BEAR x SF will become famous soon enough
BEAR x SF's Avatar
BEAR x SF is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 03:56 PM #85
belmontek84 belmontek84 is offline
belmontek84 is on a distinguished road
TRDJon did a review on the alpharex Luxx series headlights heres some links
ALPHAREX Luxx Series Install and First Impressions - Toyota 4Runner
YouTube
Alpharex Luxx Series Night Drive Only - Toyota 4Runner
YouTube
belmontek84 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 01:42 AM #86
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
Update: June 29, 2020
I put my stock headlights back in. The alpharex pros with HIDs are a huge improvement over stock, but they are too bright for my eyes.
The projectors need a foreground limiter. The intense foreground lighting dialates the pupils too much and makes everything farther out and to the sides too dark even though the lights are brighter than stock.
I can see why morimoto designed their lights with a dark spot in the front of the vehicle now.
I'm going to store these til I have the ambition to take them apart and tinker with adding foreground limiters.
Having driven with the stock headlights for a bit now, I realize my eyes are not as strained anymore after a long night drive.
The stock 4runner projectors are actually not that bad. They have a good foreground limiter, they don't blind drivers to your right when you are passing, but they do need higher output. Old tech but saves your night vision.
I can see why the best HID projectors have foreground limiters now (TL HID projectors, rx350, etc.)
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 06:16 PM #87
z32-z33 z32-z33 is offline
z32-z33 is on a distinguished road
Thanks for keeping us updated.
z32-z33 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 09:39 PM #88
You're welcome.
I'm always willing to help or give a heads up.
Old 08-05-2020, 03:05 PM #89
shak# shak# is offline
shak# is on a distinguished road
For those who run PRO with HID. Can you fit the HID H11 bulb into pro series? The documentation says they take h7 bulbs only.
shak# is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 04:58 PM #90
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
YouTube
YouTube
meh. sounds sponsored.
tjnptel1 is offline   Reply With QuoteReply With Quote
alpharex , hid , pro , stock , video
Magnuson Supercharger 2K Mile Review and 6K Mile Review bowhun2r 5th gen T4Rs 139 08-24-2023 03:25 PM
Aftermarket black headlights - review and lots of pics fullboogie 4th Gen T4Rs 314 10-01-2021 08:50 AM
GE Night Hawk Platinum Review (headlights) djskorch 3rd gen T4Rs 25 12-03-2018 11:25 PM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
