Old 02-08-2020, 12:01 AM #1
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
*Review* Alpharex Pro headlights
Install went well. The lights sit good and there are no noticeable gaps.
Once the lights are in you cannot change the low beam bulb so pick and clock which bulb you want to run before putting everything back together.
This can also pose an issue for those of you who run longer LED bulbs that stick out past the dust cap too. They most likely wont clear. The wires for my HID bulbs barely cleared.
Here's a couple pics showing what I mean:
The HID kit I got is off of Amazon. Innovite 55w 4300k HID off of a recommendation from another forum member. He says he has been running them trouble free for 3 to 4 years.
These are a great improvement over stock for about $520 total (headlights + HIDs).
The only negative for me are the high beams. The stock highbeams are 10x better than the ones on the alpharex Pros. Perhaps some LED bulbs are on order for the highs. I can still get to the highbeam dustcap.
I'm slightly bothered by the passenger side. I think it can shoot out a little more to the right. Perhaps I will loosen a few headlight bolts on top and retighten while pushing the headlights to the right.
I will get daytime shots of the exterior another time but for now, here are some videos and photos.
The videos are on the same road. Excuse the language in the first video, the phone went wonky.
Stock headlight video.
YouTube
Alpharex Pro video
YouTube
Stock headlights vs. Alpharex Pro
The thread that made me consider these:https://www.toyota-4runner.org/3437996-post100.html
Update:
No pics but I put some katana h7 LEDs in the high beams and the output is even more garbage than with the h7 halogens. That bulb is supposed to be one of the good ones in highbeam projectors but maybe the youtubers only tested the intensity 3 feet away.
So I went to autozone and got some h7 xtremevisions. Much better output and I retain color definition at distance.
That's the route I would go with. HID lows, xtremevision halogens high. I was thinking about HID in the highs too but might want to retain the ability to flash
Update:
So I removed my headlights to see how I inserted them in because I wanted to make sure the "rod" was facing down on the bulb.
Turns out they weren't. I was at about a 10 o clock position with the tab and the rod was at 4.
I fixed it so I was at 12 o clock and the rod was now at 6 o clock.
Remounted the lights and now my passenger side had a wacky beam pattern!
I messed around with it a bit and 10 o clock gave me the best pattern on the passenger's side and 12 o clock on the driver's side.
I guess these cheap Amazon HID bulbs may not be on a perfect plane so you have to pick the right spot for them.
Update: June 29, 2020
I put my stock headlights back in. The alpharex pros with HIDs are a huge improvement over stock, but they are too bright for my eyes.
The projectors need a foreground limiter. The intense foreground lighting dialates the pupils too much and makes everything farther out and to the sides too dark even though the lights are brighter than stock.
I can see why morimoto designed their lights with a dark spot in the front of the vehicle now.
I'm going to store these til I have the ambition to take them apart and tinker with adding foreground limiters.
Having driven with the stock headlights for a bit now, I realize my eyes are not as strained anymore after a long night drive.
The stock 4runner projectors are actually not that bad. They have a good foreground limiter, they don't blind drivers to your right when you are passing, but they do need higher output. Old tech but saves your night vision.
I can see why the best HID projectors have foreground limiters now (TL HID projects, rx350, etc.)
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 12:24 AM #2
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
The HID kit I got is off of Amazon. Innovative 55w 4300k HID off of a recommendation from another forum member. He says he has been running them trouble free for 3 to 4 years.
It's a great improvement over stock for about $520 total (headlights + HIDs). The only negative for me are the high beams. The stock highbeams are 10x better than the ones on the alpharex Pros. Perhaps some LED bulbs are on order for the highs. I can still get to the highbeam dustcap.
YouTube
Alpharex Pro video
YouTube
Some night pics
Imgur: The magic of the Internet
Cutoff lines
Just an FYI, it says Alpharex Pro video here but in the YouTube title you got Alpharex Nova.
mcat707 is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 12:27 AM #3
Dangit I just fixed it on imgur too lol. Thanks for the heads up.
Old 02-08-2020, 12:30 AM #4
mcat707's Avatar
mcat707's Avatar
Are those pics with fog lights on? If so, are they LED or Halogen?
Also, did you install the supplied DRL harness that connects to your battery and fuse box? I know its optional but wondering if you did.
Old 02-08-2020, 12:32 AM #5
No fog lights on in all pics or videos. I didn't install the DRL harness.
I feel like I could aim the lights higher, but the 4runner is so high I dont want to be an a-hole to other drivers. So they are lighting the foreground like a fog but still have more distance than the stock headlights.
I aimed the lights 5 inches below the optical center of the headlights at 35 feet and the step up on the beam is about 1 per 2 inches below the optical center at 35 feet.
Old 02-08-2020, 12:43 AM #6
mcat707's Avatar
mcat707's Avatar
Was hoping someone can answer this question for me....
Installation Guide for 14-20 Toyota 4Runner Headlights | AlphaRex
On the install guide, step 12, For the DRL harness, it says to tap the grey wire into the INJ fuse 10A route. According to a Toyota tech I talked to today, he said thats the fuel injection fuse. Why would they have the DRL harness tapped into that fuse slot?
Old 02-08-2020, 12:57 AM #7
Probably so the DRLs only come on when the engine is running and not when ignition is on and engine not running.
I think all factory DRLs can't run if the engine isn't. Maybe it's a DOT thing.
Old 02-08-2020, 01:03 AM #8
mcat707's Avatar
mcat707's Avatar
Ah ok, that makes more sense.
Old 02-08-2020, 11:34 AM #9
aceee aceee is offline
aceee is on a distinguished road
From your pictures and reviews from others, output on these are amazing. WAY better than those trash morimoto xb headlights people are on the hype train about. These are definitely on my list if my retrofit doesn't go as planned. Thanks for the review!
aceee is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 11:58 AM #10
You're welcome. I'm loving these so far. The morimoto's would have been an option for me too, as well as the Alpharex Novas, but having irreplaceable/unserviceable bulbs bugs me as well as double the price.
Old 02-08-2020, 12:16 PM #11
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
It's hard for me to tell on mobile. The XBs have a dead zero light zone up front and to the sides and looks similar to your pics. Is their useable light or do you need the fogs to see in that area? Thanks
ForRun is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 12:19 PM #12
ForRun's Avatar
ForRun's Avatar
Found my old example, hid vs XB showing the dead zone. These pics taken in the exact same spot camera front center of the steering wheel. Use the cracks in the road as reference, can't see some in the xb dark zone
*Review* Alpharex Pro headlights-20190808_223326_3-jpg  *Review* Alpharex Pro headlights-20190808_223401_3-jpg
Old 02-08-2020, 12:20 PM #13
mcat707's Avatar
mcat707's Avatar
Like what the OP mentioned before, the major downside of the PRO’s (not sure about the Nova’s) is the ability to change out the low beams. You would need to remove the bumper and take out the headlight assemblies once again to replace the bulbs.
A major pain in the azz if you have armor, bull bars, winches or whatever aftermarket parts that take additional work to remove and reinstall over the factory bumper.
Old 02-08-2020, 12:32 PM #14
There's more useable light than with the stock headlights.
With the stock headlights, my factory LED fogs would be needed to light up the sides.
I turned on the factory LED foglights with the new headlights and could barely tell they were on. That tells me the sides are getting enough lighting to the sides from the Pros to drown out the output of the LEDs.
This pic was taken in the same spot. Factory headlights vs Pros. You can see how it lights up that road marker on the drivers side with the Pros but not with the factory lighting. I would have needed my fogs in with the factory lighting to light that up.
My passenger side needs work though. Stock has it beat a little for up close to the right work. Gotta loosen and aim right a tad.
Old 02-08-2020, 12:35 PM #15
Yeah. That's the great thing about stock, everything is accessible.
With the Pros, you have to remove the headlight to service the low beams, blinker, and side marker light.
With the Novas, you have to remove the headlight and send it in to Alpharex.
alpharex , hid , pro , stock , video
Magnuson Supercharger 2K Mile Review and 6K Mile Review bowhun2r 5th gen T4Rs 139 08-24-2023 03:25 PM
Aftermarket black headlights - review and lots of pics fullboogie 4th Gen T4Rs 314 10-01-2021 08:50 AM
GE Night Hawk Platinum Review (headlights) djskorch 3rd gen T4Rs 25 12-03-2018 11:25 PM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
