Old 02-11-2020, 01:47 AM #31
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
Originally Posted by z32-z33 View Post
Would you say your current setup with the Alpharex Pro is less blinding to on coming traffic than the H9 were? I've tried XD xtreme hids (too much glare)and currently have H9 in my 2017 stock housing, but just not satisfied with them.
Well, if I'm bouncing on bumps and stuff and the cutoffs reach their eye level they're in for some sunshine! Lol. There is absolutely no glare above the cutoff line. The only glare that happens is when you are 2 feet in front of the headlights and the light is bouncing off the projector shrouds. The only time I may really blind people are small cars side view directly to my right. Life of a lifted truck I guess. Then again maybe I just notice it much more now that the cutoffs are more pronounced.
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:50 AM #32
Originally Posted by amigomason View Post
OP- what kelvin rating did you go with for the HID kit? I’m in the debate to go with the Nova vs Pro. That said if it’s marginal difference between Pro and Nova given that you have to send in the unit for any services is a no go for the Nova.
4300k
Old 02-11-2020, 01:55 AM #33
Update:
No pics but I put some katana h7 LEDs in the high beams and the output is even more garbage than with the h7 halogens. That bulb is supposed to be one of the good ones in highbeam projectors but maybe the youtubers only tested the intensity 3 feet away.
So I went to autozone and got some h7 xtremevisions. Much better output and I retain color definition at distance.
That's the route I would go with. HID lows, xtremevision halogens high. I was thinking about HID in the highs too but might want to retain the ability to flash people.
Old 02-11-2020, 09:17 PM #34
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Sorry you might have addressed this already. How much can you adjust the headlight beam up and down? If so, what setting are yours set to (assuming 3" lift)?
Sorry, I have been reading too many retrofit headlight threads.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 10:50 PM #35
The height adjustment is in the same location as the stock headlights. The range is as good as stock. I haven't had to go to either extremes to find out.
Started at 2 inches below cutoff at 35 feet. Then kept adjusting lower.
I believe mine are 4 inches below center of headlight at 25 feet now. I'm lifted 1.75" front and 1.25" rear. I figured my front end went up about 2 inches so I should go down 2 inches from the standard 2 inches at 25 feet others use.
It seems good so far and I haven't been flashed once since installing these lights.
Old 02-12-2020, 11:55 AM #36
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Originally Posted by CharlesNellis View Post
I put some up in the first post. You're welcome. I'm kind of indifferent to the look. I thought stock looked great, but these are appealing. Not ugly or "ricey" to me by any means. I was more after the performance.
Looking “ricey” was one of my main concerns before ordering a set of the PRO’s.
After having them on, I’m happy with the way they look and especially the sequential LED “check mark” turn signal feature. Mostly the reason why I got them.
I personally love the classy look of having mostly OEM parts on all my vehicles with a bit of my personal custom taste. But I guess I’ll make an exception with these aftermarket headlights.
mcat707 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 04:40 PM #37
Ngonerogwu Ngonerogwu is offline
Ngonerogwu is on a distinguished road
I couldn't have said it better.
The white DRL area bothered me a ton at first.. but after a couple days I'm okay with it.
Ngonerogwu is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 07:07 PM #38
Install went well. The lights sit good and there are no noticeable gaps.
Once the lights are in you cannot change the low beam bulb so pick and clock which bulb you want to run before putting everything back together.
This can also pose an issue for those of you who run longer LED bulbs that stick out past the dust cap too. They most likely wont clear. The wires for my HID bulbs barely cleared.
honestly am surprised at those cut offs. Looks great, especially for the price. I'm all about the morimoto products in general but these are super tempting.
Old 02-12-2020, 10:34 PM #39
Yeah the lights looked good to me from the start and they have continued to grow on me. I love these now. Great price, great output, great looks, but not so great if you want to change the low beam bulb lol.
Old 02-12-2020, 10:44 PM #40
It seems as though someone really took their time making sure these projectors were perfectly aligned. Mine were level right out of the box. The steps are the same distance apart as my headlights are away from a wall and the cutoffs are even horizontally. That was what I was having nightmares about before installing and seeing a perfectly horizontal and crisp cutoff afterwards was a huge relief.
I read a few complaints about the cutoffs being crooked on some ford forums but the production numbers for those are probably way more.
Old 02-12-2020, 11:04 PM #41
mcat707's Avatar
mcat707's Avatar
Yeah your cut off lines look really good compared to mine. Mine aren’t that straight horizontally.
Old 02-12-2020, 11:09 PM #42
mcat707's Avatar
mcat707's Avatar
Here is what I got a few days ago. These are with OEM fogs. As you can see its not as straight as yours. Had to go back and lower the height yesterday.
*Review* Alpharex Pro headlights-f2d15480-8742-4ee5-aa9b-7a0abaee8584-jpg
Old 02-12-2020, 11:36 PM #43
Hmm. You have the original halogens in there?
I found that the area the bulbs sit in were finicky. Had to mess around with the bulb orientation until they "set". Its like a tight glove.
Old 02-12-2020, 11:46 PM #44
mcat707's Avatar
mcat707's Avatar
I have the Innovited 5000K Pure White HIDs. Not sure why the color looks like 3000K in that pic. It was taken at dusk.
I double checked the orientation on both H7’s and made sure they were level and locked in tight before mounting the assemblies. Maybe I got a flawed set?
Old 02-12-2020, 11:49 PM #45
Yeah maybe. That would cutoff would bug me.
alpharex , hid , pro , stock , video
Magnuson Supercharger 2K Mile Review and 6K Mile Review bowhun2r 5th gen T4Rs 139 08-24-2023 03:25 PM
Aftermarket black headlights - review and lots of pics fullboogie 4th Gen T4Rs 314 10-01-2021 08:50 AM
GE Night Hawk Platinum Review (headlights) djskorch 3rd gen T4Rs 25 12-03-2018 11:25 PM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
