08-26-2014, 09:09 PM
2013 T4R engine ticking noise
Hi,
I have a 2013 4runner SR5 with 20,000miles. The engine has this ticking noise that sounds like a valve noise more noticable on the right side. I took it to the dealer and they told me that the noise is a normal noise for that engine. Does anybody knows about this? Is your 4runner also has that ticking engine noise.
Thanks for your help!
08-26-2014, 09:16 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
When you start it up and for about 5 minutes after? Sounds like valve clatter?
Sorry I don't know anything about it lol. J/K yes mine does it too. I really don't care if anyone elses does it as its no big deal to me.
08-26-2014, 10:10 PM
Same here. I have been to two Toyota dealers and one independent Toyota shop and they all tell me it is perfectly normal for the 5th gens.
2010 Mag Grey SR5 4Runner. 3" Lift with adjustable Boss coilovers in the front and Bilsteins in the rear. Light Racing UCAs. 285/70 17 BFG All Terrains.
08-26-2014, 10:18 PM
Same. Mine has done it since day one and I believe my brother's 4th gen even sounds similar as well.
08-26-2014, 10:27 PM
They all do it. Roller rocker cams in the new (for 2010) dual VVTi 1GR-FE 4.0 V6.
08-27-2014, 02:24 PM
Real Name: Michael
Real Name: Michael
Pretty sure my old 2007 Tundra did it as well. Didn't bother me either.
2013 Silver SR5 Third Row, Entune, SCS Ray 10 DRK BZN 285/70 17 BFG KM2, Satoshi Grill, Icon Stage 2, Total Chaos UCA, Canvasback, Ezei Awn K9 2.2 rack, Pelfreybilt Sliders
08-28-2014, 10:41 AM
Yeah Ive noticed it as well, but it does sound the same as all the 5th gens and FJ's i have heard..
2012 4Runner SR5 Premium
Bilstein 5100 F&R 2.5" front TJM lift springs rear
Firestone Air Bags
08-28-2014, 02:32 PM
Real Name: Rick
Real Name: Rick
It is most likely the fuel injectors. They can be quite loud. Listen to any fuel injected engine and you will hear a clatter that sounds very similar to valve lash noise.
2012 Trail Edition, Salsa Red, MetalTech (Icon) Long Travel Rear, Panhard Relocation Bracket, Radflo 2.5" Extended Travel Front, LR UCA's, 17x9 XD wheels, Cooper S/T Maxx 285/75-17's (34"), 4.56 Gears, Wet Okoles, Weather Tech FLoor Covers, Canvasback Cargo Covers, Shrockworks Sliders, BudBuilt Hidden Winch w/ Warn 9.5ti, On-Board Air (using sliders as air tanks), Rigid D2's, RCI Skids, Body Mount Chop, Console Vault.
08-28-2014, 02:46 PM
Banned
Banned
wait I didn't get the diesel option?
08-28-2014, 09:36 PM
All 1GR-FE engines, be them single or dual VVTi seem to have this "Toyota Tick." Sources seem to range from VSC valves, rocker rollers, fuel injectors, ect. All I know is that these engines tick and are more noticeable with the window down at idle; my suggestion? Apply throttle and listen to some tunes, should quiet it down.
08-28-2014, 09:53 PM
Originally Posted by BlackWorksInc
All 1GR-FE engines, be them single or dual VVTi seem to have this "Toyota Tick." Sources seem to range from VSC valves, rocker rollers, fuel injectors, ect. ......
My 2013 FJ made the same sound, I was also informed this is normal for these engines by my local dealerships service manager.
Not worried!
Best Regards,
Saker
03-07-2016, 11:49 AM
Real Name: Nathan
Real Name: Nathan
I am reviving this thread because I have 3 5th gens and only my 2013 does this. The dealer told me it was normal and all of them do it. So.. I drove my 2010 to the dealer and showed them it does not make the noise. (this was several months ago)
They said they would log it in case there were problems down the road. When I pulled my 2013 out of storage the other day, the noise (it is inside my shop) sounds twice as loud as normal. Again my 2015 does not make the noise at all. Our 4th company 5th gen (owned by GD2013) also does NOT make the noise. Sou our of our 4, only one does it... This disproves that "ALL" of them do it.
05-04-2016, 10:54 AM
Has anyone else had the dealer look at this issue and actually had the noise fixed?
05-04-2016, 11:03 AM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Nothing to fix. Read the thread.
