Old 02-09-2020, 03:22 AM #1
sharky sharky is offline
sharky is on a distinguished road
Sealant for Aftermarket Roof Rack?
Just received my Victory 4x4 roof rack and trying to understand what the best way is to seal the mounting holes to prevent water intrusion. Their instructions were to use a generous amount of black RTV around and in the factory mounting holes. I was planning on going this route, but wondered if there was a cleaner alternative to seal it?
Watching and reading other roof rack install videos seems that the norm is RTV, but the reason I am hesitant with glooping RTV everywhere is because I read that:
  • it's a pain to clean if you want to remove it
  • it needs to eventually be reapplied because of the constant exposure to the sun
  • filling the mounting hole with silicon sounds like a pain to deal with if I wanted to go a different route later on
Found this great post where it was suggested to use butyl tape and silicone washers, which I am leaning towards.
Any insight is appreciated. Also, recommendations on thread sealing for the bolts... thought of pipe dope or teflon tape, but sounds like blue loc-tite would work?
2011 Limited Mag grey | FN f(x) Pros 17x8 | Cooper AT3 265/70/17 | TRD Pro Bilstein 6112/5160 | C4 Fabrication Rock Sliders | Trail rocker trim mod | AVS window vents | Canvasback liner | Plastidipped Chrome
sharky is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 07:50 AM #2
darrensan's Avatar
darrensan darrensan is offline
darrensan is on a distinguished road
darrensan's Avatar
Rorck recommended me this sealant when I bought the ecotechne roof rack and I must say no issues whatsoever https://amzn.to/30DoFiP
2017 4Runner SR5
MAUI, HI
Instagram: @ghostly.t4r
BUILD Page 👇🏼👇🏼👇🏼
https://gearproject.co/gp/ghostly.t4r/662
darrensan is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 08:40 AM #3
Nomad74 Nomad74 is offline
Nomad74 is on a distinguished road
https://www.amazon.com/XFasten-8-Inc...s%2C142&sr=8-2
Nomad74 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 01:02 PM #4
Brownfaux Brownfaux is offline
Brownfaux will become famous soon enough
I used a small amount of silicone sealant, and sourced some rubber washers in addition. If you look at how the roof rack mounts and the holes, the real risk is water in the rain channels going in between the plastic bolt guides and the roof, not down through the nut and bolt threads.
Brownfaux is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 01:29 PM #5
El Dusty's Avatar
El Dusty El Dusty is online now
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
This. Clear RTV has held up great on my Prinsu through 9 months of blizzards, storms and high pressure car washes. Easy to source as well.
El Dusty is online now   Reply With QuoteReply With Quote
Old 04-17-2020, 09:21 PM #6
jasonlw jasonlw is offline
jasonlw is on a distinguished road
Roof rack that do not require sealant
I am aware that there are a few racks on the market that do not depend on silcone, butyl, RTV, or any other offensive, goopy, sticky, messy stuff.
I know ARB and Sherpa rack are designed in this way with OEM style rubber seals.
Are there any other racks that I could add to my list?
jasonlw is offline   Reply With QuoteReply With Quote
Old 04-19-2020, 12:17 PM #7
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
None that I've seen and I've read a lot on the subject. And the Sherpa racks are on sale 12% off for the next two days, so a good deal.
rageandlove is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 11:31 AM #8
Mach1azuress's Avatar
Mach1azuress Mach1azuress is offline
Mach1azuress is on a distinguished road
Rorck recommended me this sealant when I bought the ecotechne roof rack and I must say no issues whatsoever Amazon.com: Permatex 80050 Clear RTV Silicone Adhesive Sealant, 3 oz: Automotive
I used this RTV on when installing Front Runner rack in Nov 2018. I applied it liberally over the bolts and any holes. I haven't had any issues, but I should probably check it's integrity soon.
2017 TRD Off Road
Mach1azuress is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 12:12 PM #9
Blazephantom Blazephantom is offline
Blazephantom is on a distinguished road
I used 3M auto sealant for my install. It rained this weekend and so far no leaks.
3M Clear Super Silicone Seal, 08661, 3 oz Amazon.com: 3M Clear Super Silicone Seal, 08661, 3 oz: Garden & Outdoor
Blazephantom is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 06:09 AM #10
mystiqueskillz mystiqueskillz is offline
mystiqueskillz is on a distinguished road
I'm reading that the Permatex Clear RTV Silicone causes corrosion on the paint after it cures?
mystiqueskillz is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 07:39 AM #11
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Silicone caulks that release acetic acid during the curing would potentially be corrosive to the metal roof or rack. Butyl caulk does not release it.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 08:44 AM #12
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
There was a recent Roof rack thread where a guy used silicone and over time it contracted and allowed water penetration... his roof had rust holes and was trashed. A member posted that through his extensive research found that butyl rubber sealant, like what is used to affix windshields, is best as it does not contract. Just an FYI. You might search out that thread.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:01 PM #13
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
Here's lots of info.
Non Drill roof rack (no silicone)
I'm building my own spacers for the roof rack to sit on with a combination of 3/4" thick plexiglass (making a big ol rectangular block and drilling 2 holes into it), butyl rubber, and a sheet of 1/8" high temp silicone (Red Silicone Rubber Sheet Roll High Temperature Thick Commercial Grade 8" x 8" x 0.12": Amazon.ca: Tools & Home Improvement)
I'm using cutting some silicone sheet to size to sit between the roof itself and the spacer -i.e. I made a silicone gasket which also helps protect the spacer from damaging the paint on the roof. Butyl on both sides of the silicone to be super safe -not a lot but enough to squeeze and fill into any spaces or gaps. I'm also adding a silicone gasket on top of the spacer where the roof rack bracket sits on top of the spacer (it's hard surface on hard surface so it's not water tight).
Lots of ways to skin this cat.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:26 AM #14
LA260's Avatar
LA260 LA260 is offline
LA260 is on a distinguished road
LA260's Avatar
My Prinsu rack should be here in couple of days and this I'm planning to do the following from bottom up:
Butyl tape around the factory white washers/holes
Silicone Rubber Sealing Washer McCaster 99604A123
SS Washer
Silicone
Prinsu Washer
Silicone
Rack.
Not planning on putting any silicone in the holes of the roof but will be wrapping the bolts in blue monster pfte tape. Hopefully this will do it.
LA260 is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 09:47 PM #15
Fermn's Avatar
Fermn Fermn is offline
Fermn will become famous soon enough
Fermn's Avatar
Here is what I did with my Gobi rack. Used Butyl tape. So far it has been 8 months with no leak with heavy rain here in South Fl. Very happy with the outcome
Sealant for Aftermarket Roof Rack?-7d10b4bb-5b78-4430-a7e3-17265e01c324-jpeg
Fermn is offline   Reply With QuoteReply With Quote
mounting , rack , roof , rtv , tape
Roof Rack Sealant? Need Advice DreamsOfDirt 5th gen T4Rs 30 10-23-2020 06:26 PM
Strongest Aftermarket Roof Rack? Drilling more holes in the roof is a plus. randy88fj62 4th Gen T4Rs 6 01-17-2020 04:51 PM
Roof rack sealant Islandchanel 5th gen T4Rs 0 04-14-2019 07:45 PM
WTB Roof rack aftermarket Royston1018 Want to Buy/Trade 2 08-08-2015 05:34 PM
roof rack sealant / washers ?? ultimatt 3rd gen T4Rs 5 04-02-2011 08:56 PM
