Old 10-12-2021, 02:42 PM #16
TRD88 TRD88 is offline
TRD88 is on a distinguished road
The Toyota installation instructions for my 3rd Gen roof rack called out 3M Ultrapro Autobody Sealant Part# 08302
Amazon.com: 3M Ultrapro Autobody Sealant, 08302, Clear, 5 oz Tube : Everything Else
TRD88 is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 02:02 PM #17
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Subscribed!
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 02:51 PM #18
cbaty08 cbaty08 is offline
cbaty08 will become famous soon enough
I used RTV silicone, and it seems to be doing the trick.
2021 Lunar Rock
cbaty08 is offline   Reply With QuoteReply With Quote
Old 10-15-2021, 03:26 PM #19
02SE 02SE is online now
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Make informed choices when deciding what to use when sealing roof rack mounts.
Destroyed Factory Roof Mounting Locations
02SE is online now   Reply With QuoteReply With Quote
Old 12-04-2021, 05:10 PM #20
docsnavely's Avatar
docsnavely docsnavely is offline
docsnavely will become famous soon enough
docsnavely's Avatar
This is a bad reference though. The OP later explained how the damage in the initial post happened.
He never once inspected the seals after putting the rack up. This happened more than 5 years after installing the rack. He linexed the roof up to the seams of the rack. He kept it outside in Hawaii for 5+ years, and had annual periods of up to 6 months at a time where it was never moved.
I'm installing my full length victory 4x4 rack today and plan on using the black RTV as they recommend. My 4runner stays garaged in the PNW and serves as my daily driver to and from the garage at work when not out on weekend trips.
For those that fear water intrusion despite following the installation guidelines, maybe you should reconsider the necessity of an after market rack.
2020 Army Green TRD Pro - Trips and Mod Thread
Former owner of a 2018 Cavalry Blue TRD Pro, a 2015 Nautical Blue Metallic Limited with 3rd row, still the managing owner of my wife's 2013 PriusC III.
docsnavely is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 08:25 PM #21
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
I had a leak after the dealer replaced my rack at the port. I took it back to the dealer shortly after discovering the water intrusion and was told they didn't have a "diagnostic technician" on duty (I was told this AFTER making an appointment for a leaking roof rack). I found it much easier on my time and frustration level to pull/wrap all of the bolts in teflon tape and retorque.
Haven't seen/felt a leak afterwards.
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 08:52 PM #22
I'm not sure why you think it's a bad reference...
If you only read the first post, then I could see your point.
It was an example of what could happen, which is why I posted it. Obviously you want to read the full thread, if you're changing roof racks.
Old 12-04-2021, 09:24 PM #23
Kfish Kfish is offline
Kfish is on a distinguished road
If I were to do it again I would probably go with butyl tape, and make sure the bolts have some kind of metal washer not the OEM bolts. My rack leaked driver side, pulled out wet seatbelt one morning...oh crap...
Despite careful silicone application I think it was a shrinkage issue, pretty sure b/c I was very methodical at install.
That particular roof rack reuses OEM bolts though and everything sit exposed to UV slowly breaking down, would only be a matter of time without the cover caps that OEM rack has. I took it all off and went back to OEM rack to get that piece of mind, I guess those Toyota engineers were onto something after all
Kfish is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 09:25 PM #24
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I used globs of silicone RVT years ago and haven't had a problem. Obviously, there are less messy alternatives now that weren't available 5 years ago. Too lazy to redo it.
Old 12-05-2021, 08:15 PM #25
docsnavely's Avatar
docsnavely's Avatar
You apparently failed to read what I wrote, or else you would have seen that I referenced OP's reply and explanation for how the water damage happened which was on the third page of the thread.
Old 12-06-2021, 02:34 PM #26
I guess the fact that you quoted me, and called it a bad reference, made me assume you were referring to me...
Old 12-06-2021, 04:58 PM #27
DL771 DL771 is offline
DL771 is on a distinguished road
I applied butyl tape when I installed my Prinsu last year. No issues so far.
DL771 is offline   Reply With QuoteReply With Quote
mounting , rack , roof , rtv , tape
Roof Rack Sealant? Need Advice DreamsOfDirt 5th gen T4Rs 30 10-23-2020 06:26 PM
Strongest Aftermarket Roof Rack? Drilling more holes in the roof is a plus. randy88fj62 4th Gen T4Rs 6 01-17-2020 04:51 PM
Roof rack sealant Islandchanel 5th gen T4Rs 0 04-14-2019 07:45 PM
WTB Roof rack aftermarket Royston1018 Want to Buy/Trade 2 08-08-2015 05:34 PM
roof rack sealant / washers ?? ultimatt 3rd gen T4Rs 5 04-02-2011 08:56 PM
