Originally Posted by Jivewalker
Using a bottle jack under the KDSS piston much easier than the ratchet straps, for the next time of course. Glad you got it figured out!
I kept it captive with the strap and was able to adjust the height with ease. The other pulled it to the lca. It was way easier then the bottle jack which I find always gets knocked over under the piston because of the front to back movement.
On the passenger side I used the floor jack to compress the piston. But honesty next time I’ll prob use that strap method again.
Originally Posted by mattycakes
Glad you got it all back together. Last time I did mine I read somewhere that putting it in 4L disables the kdss and makes it a lot easier to handle. I dunno if it actually worked or not but it sure as hell seemed like it was a lot easier to manhandle back into place than the first two times I tore it apart. I hope you dont have to do it again but just a heads up!
I have heard that. That two strap method really work well tho. Minimal effort and lots of control.
