Old 02-09-2020, 04:32 PM #16
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Originally Posted by Mutant138 View Post
These are hub to fender measurements.
obviously i need to hit the coffee pot...or the stoli.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 04:35 PM #17
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I think you have it backwards.
c59-238’s they give a measurement of 375mm which is 14 inches.
C59-302 give a measurement of 395mm which is 15.5 inches.
So assuming my 302’s are actually 238’s at 14” free length Does two inches of compression with stock load at 11” really seem crazy?
And just again at this point I could take or leave the 2.5” lift I just want my truck aligned so I can actually use it and try to recoup my losses since Dobinsons seems unconcerned.
yes you're right about the length. 11" could be right at 14" (3" compression) however from 15.5" is seems a lot. My front coils compressed are 11.5" however there's nothing apples to apples about our setups
Sorry about all the headache this is causing.
The link below is from Wheeler's as a point of reference
EIBACH 14" COIL SPRING PAIR FOR 2.5" COILOVERS
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 04:41 PM #18
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
If they are intact 302’a they are garbage for sure. Glad we are on the same page here. I almost feel like I would have noticed the coils collapsing when I give it some over a bump or whoop. But, this is my first modified truck so idk.
Don’t be sorry. Dobinsons is the one who is costing me tons of money and wear and tear on my body/truck.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 04:57 PM #19
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
Stock hub to fender measurements 1engineer (kdss):
Front: 19.125”
Rear: 22.0”
The rear height looks good to me, but are we sure 19.125" is the correct stock front measurement in the first place?
That would mean the front is nearly 3" lower than the back......which shouldn't be the case. All you should need to get the front and rear hub to fender measurements level is 1.75" of lift in the front.
nimby is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 05:03 PM #20
Banned
Banned
Gotta remember the fenders are higher in the rear from the factory. Frame level they are offset too.
Pretty sure those are accurate #’s.
Not trying to level my fenders. Just trying to see what’s up with my front coils. But thanks.
Old 02-09-2020, 05:33 PM #21
Banned
Banned
Well. I don’t want to pull it all apart just to find out it needs to be replaced and not have anything to swap it with.
Going to have to wait on Dobinsons to send those coils. I’m debating getting the eibach pro front setup and just putting that in there instead. Try to sell everything else and recoup some of my losses from was supposed to be a little one weekend project.
Old 02-09-2020, 06:03 PM #22
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Don’t you have kdss? I thought Dobinsons had some super high spring rate coils for KDSS, 750ish vs 590ish. I wonder if you have the 302 and the kDSS is compressing it that much.
On a side not I wanted the dobinsons suspension at first but nobody seemed to be getting consistent lift results out it and they were settling a lot after a few hundred miles. I can’t tell that my Eibach has changed at all.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 06:32 PM #23
Banned
Banned
I do. I had the kdss offset coils in the rear but not up front (as mike advised). That was for the original planned lift. I could see the 302’s getting compressed too much by the kdss. No idea tho. Mikey at dobsions claims that this is 1/100s that is having an issue. I have little faith.
Old 02-09-2020, 07:24 PM #24
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I clicked thinking the thread was about ignition coils, lol.
Still a very good thread that may have narrowed my lift decision by one.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 12:30 PM #25
Banned
Banned
Why not both?
Old 02-10-2020, 02:51 PM #26
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
It will not
What was the height like immediately after the original install?
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 02:12 PM #27
Banned
Banned
Originally Posted by Ryan at Eibach View Post
It will not
Pretty much where it's at. I remember pulling the truck off jack stands and setting it down and kind of going, "Huh. Doesn't seem like that much difference." But, I looked at the skid plate clearance and kind of shrugged it off.
Replacement coils came in from dobinsons. This weekend I'll rip the drivers side apart and measure the coil off the truck. If it's in "spec" i'll have to weigh if I want to bother replacing them or not. Especially if I might have the same problem again.
I'm really hoping they mislabeled them and they are just 1" coils. That way I can button it back up and try to recoup some of my losses.
Shouda stuck with my OG plan and went eibach from the get go.
Old 02-16-2020, 03:44 PM #28
Banned
Banned
Alright so what I feared is true. They are the same length as the Warrantee set unloaded.
Also the strut caps them selves came apart when I pulled the assembly. Pretty stoked on dobsions quality and customer service. Hopefully I can manage to get that back together.
At a loss as to what to do as I wagered they might be a 1” coil. I suppose I’ll swap the springs and see if there is any difference. Something tells me I have wasted yet another weekend and another 80-90 bucks on an alignment.
Mislabeled or faulty lift coils? *Saga*-dcd6290d-3ecd-42d5-874c-99f36593b6a6-jpg
Mislabeled or faulty lift coils? *Saga*-e3043d43-bb6b-4142-a9bf-2439b6c68c14-jpg
Mislabeled or faulty lift coils? *Saga*-4ea57ec5-805e-48d3-8dc0-d3a7e87af0a9-jpg
Old 02-16-2020, 04:43 PM #29
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Attachment 354503
Attachment 354504
Attachment 354505
Hopefully it works out for u, i would consider throwing a corned 1 spacer on if still not getting the desired height.
Good.luck!
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 04:53 PM #30
Banned
Banned
Mislabeled or faulty lift coils? *Saga*-768b379e-eb0d-4656-947a-8ed7d52e6eb0-jpg
In there like swimwear. Moment of truth approaches.
coils , front , lift , rear , stock
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
BOSE Suspension?? Yes, suspension! Thai Off Topic 1 10-17-2004 07:35 PM
