Old 02-17-2020, 03:44 PM #46
Mutant138's Avatar
Mutant138 Mutant138 is offline
Real Name: Tobias Fünke
Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of Mutant138 has much to be proud of
Mutant138's Avatar
Originally Posted by Jivewalker View Post
Using a bottle jack under the KDSS piston much easier than the ratchet straps, for the next time of course. Glad you got it figured out!
I kept it captive with the strap and was able to adjust the height with ease. The other pulled it to the lca. It was way easier then the bottle jack which I find always gets knocked over under the piston because of the front to back movement.
On the passenger side I used the floor jack to compress the piston. But honesty next time I’ll prob use that strap method again.
Originally Posted by mattycakes View Post
Glad you got it all back together. Last time I did mine I read somewhere that putting it in 4L disables the kdss and makes it a lot easier to handle. I dunno if it actually worked or not but it sure as hell seemed like it was a lot easier to manhandle back into place than the first two times I tore it apart. I hope you dont have to do it again but just a heads up!
I have heard that. That two strap method really work well tho. Minimal effort and lots of control.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 03:57 PM #47
Mutant138's Avatar
Mutant138's Avatar
Alignment at firestone later this afternoon.
Took it around the block a bit to help things settle and check for weird noises. Made sure to hit a lot of speed bumps and drainage whooptiedoos. Initial impressions is that these springs feel much more progressive then the ones I took off. The front was a smidge harsh before but only really highlighted by the change.
Checked everything with a level. I have a smidge of rake at the frame which I think is good enough to say I’ll just leave the swapped rear coils in. Truck sits really nicely now.
Lean is noticeable but maybe it will settle down over time. At this point I really don’t see myself wasting more time trying to correct it.
Old 02-17-2020, 09:00 PM #48
Mutant138's Avatar
Mutant138's Avatar
Firestone lifetime alignment ftw. No more wasting money.
They did a good job. Tracks much better now.
Mislabeled or faulty lift coils? *Saga*-ab203328-dbf5-4331-bcb4-fc788f13ba8a-jpg
Imma call this one good. I’m looong overdue for some camping.
Thank you to everyone that helped me think through this.
Old 02-17-2020, 11:00 PM #49
Mutant138's Avatar
Mutant138's Avatar
Mislabeled or faulty lift coils? *Saga*-8e2384f3-1119-4026-9a7a-805341321430-jpg
Old 02-18-2020, 12:03 AM #50
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all SpeedyKevin is a name known to all
Originally Posted by Mutant138 View Post
Looking good! Happy to hear it worked out
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/GS59-705 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor and MORRFlate kit
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 12:50 AM #51
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
Glad its sorted. This sounded like a pita
Sent from my SM-G973U using Tapatalk
Build Thread
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:42 AM #52
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Talking
Everything is back together. Amazing how fast you get when you do it a bizzilion times.
Told ya you're going to get faster! Lol
Glad all is good, 22" is a good number.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 05:56 PM #53
GripT4R's Avatar
GripT4R GripT4R is offline
GripT4R is a jewel in the rough GripT4R is a jewel in the rough GripT4R is a jewel in the rough GripT4R is a jewel in the rough
GripT4R's Avatar
rig looks good man. My Bilstein 6112/5160 & T13 setup is lower than that.
GripT4R is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 07:57 PM #54
Mutant138's Avatar
Mutant138's Avatar
Thanks dude. She breaking peoples necks all day. Alert the authorities.
Btw my rear springs I’m going to sell are 1.25” stock weight with 3rd row or 1.5-1.75” without and offset for kdss.
Old 02-19-2020, 12:50 PM #55
Mutant138's Avatar
Mutant138's Avatar
This may not be over. Took some measurements last night because it looked lower. I was really not happy with the number I got. Looking like they are sagging just like the last ones. I will have to confirm after work.
I have no words to express my frustration and dred of doing this all again for a 4th time. It won't be dobinsons products going back in if I can help it.
Old 02-19-2020, 12:55 PM #56
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
It's that snorkel weighing things down
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 198,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 01:10 PM #57
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
How much height did you lose? Once you scrub it after install they really shouldn't lose any height at all (hopefully).
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 01:15 PM #58
Mutant138's Avatar
Mutant138's Avatar
Think I measured like 20/21 +/-. Almost where it was before I pulled the coils before. I'll have to confirm later.
Old 02-19-2020, 01:36 PM #59
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a jewel in the rough RichinRidgewood is a jewel in the rough RichinRidgewood is a jewel in the rough
Thats funny.
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 10:04 PM #60
Mutant138's Avatar
Mutant138's Avatar
Got on my back and really made sure my eyeball level was on point.
21.25 passenger maybe a little less
21.75 drivers maybe a little more
So, tbh they MAY have settled ever so slightly but I think I was being hyperbolic last night/this morning. In my defense I think you all could understand my frustrations and skepticism.
I’m still pretty skeptical that these are going to hold lift over time. I’ll keep throwing up measurements as the months tick by.
coils , front , lift , rear , stock
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
4Runner suspension upgrade info for tech minded suspension nerd types?? Ruby Khan 5th gen T4Rs 26 07-11-2019 08:08 AM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
BOSE Suspension?? Yes, suspension! Thai Off Topic 1 10-17-2004 07:35 PM
