02-10-2020, 12:28 PM
Hidden Alarm Carista or Techstream
Saw a short vid of a man activating installed but hidden alarm system on a toyota car. He used Techstream. I read somewhere that a man did the same thing on a 2019 4runner. Not sure how true.
Anyone done this or tried it using one or the other software mentioned above?
02-10-2020, 12:42 PM
What video? Carista gives no option for alarm settings in my 2019 TRD Premium.
02-10-2020, 03:52 PM
i've used teachstream to add a new smart key to my limited. can you post link of the short vid you saw.
02-10-2020, 07:03 PM
There are engine immobilizer diagnostics and functions in Techstream. So I guess, what do you mean by "hidden alarm"?
None mentioned above is available though Carista.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
02-11-2020, 07:46 PM
YouTube
Like I said in first post, it is a car, but toyota.
02-11-2020, 08:02 PM
Do you own a 5th gen 4runner?
All 5th gen 4runners to my knowledge have factory alarms that are enabled by default. So I guess I am confused why you are asking. They come with dash active light, entry trip, hood trip, engine immobilizer, some years IIRC have glass sensor others do not.
At least a few folks around here have discovered aftermarket crap under their dashes that they claim to be "hidden" alarms installed prepurchase by the dealer.
2013 TE w/ KDSS Nav
02-11-2020, 08:07 PM
Negative. It's just keyless entry unless you upgrade it.
02-11-2020, 08:12 PM
Are you sure about that? I certainly didn't "upgrade" it. OR do you mean by upgrade, enable what is already there?
Both my 3rd gen and 5th gen had/have "security" dash lights.
2013 TE w/ KDSS Nav
02-11-2020, 08:21 PM
Yes. The brochure only states keyless entry. The security light is an anti-theft light to show the vehicle is equipped with a passive anti-theft (chipped key). The upgrade was the RS3200 alarm but I guess it's no longer available. My Tacoma was the same way, just keyless. Drop the window, lock it with the key and open the door. Nothing will happen.
02-11-2020, 08:45 PM
Interesting, rolldown the window, arm it, open the door and my horn and lights go off, same for the hood. Of course this was 7 years ago, I did have them "install" OEM remote start when I bought it but remember nothing about alarm. Will have to go look through my purchase agreement, if I can find it.
2013 TE w/ KDSS Nav
Reason: clarify
02-11-2020, 08:49 PM
Interesting, rolldown the window, arm it, open the door and my horn and lights go off, same for the hood. Of course this was 7 years ago, I did have them "install" remote start when I bought it but remember nothing about alarm. Will have to go look through my purchase agreement, if I can find it.
More than likely part of the upgrade. I'd get video of mine but I have the junk Karr alarm system.
02-11-2020, 09:03 PM
False, This is spread by dealerships trying to sell you the Karr system. at least for newer cars.
Start at page 76
https://www.toyota.com/t3Portal/docu...f/OM35B54U.pdf
02-12-2020, 12:53 AM
Originally Posted by Cndnmax
That's passive anti-theft (chipped key) that's in all vehicles now, not a active system that sounds the horn and flashes the lights when you open a locked door like an alarm.
02-12-2020, 07:55 AM
Keep reading...
02-12-2020, 10:39 AM
Keep reading...
Alarm *
*If equipped
So there is an alarm but probably only on the Limited and Pro.
