Old 02-19-2020, 02:02 PM #16
Crocket's Avatar
Crocket Crocket is offline
Crocket is on a distinguished road
Crocket's Avatar
Originally Posted by Bumbo View Post
My goal on snowy/icy roads is NOT to break traction because it's difficult to recover if you go into a slide. I would never run with a rear diff locked.
Ideally you would want a limited slip differential in the front and or rear if you wanted to put power down to the road like a locker would off-road, but for on-road driving.
Similarly the Limited transfer case in H4F / AWD mode is basically a mechanical limited slip differential which is ideal for snow driving. Unfortunately the other trims don't operate the center unlocked which would only exacerbate the problem as it would promote scrubbing around turns and make it harder for the tire to keep traction.
Agree with you there regarding front and rear LSDs. Unfortunately 5th gen 4wd 4Runners don't come with them, only some of the 2wd versions if I'm not mistaken. Not sure how much it costs to get one aftermarket, but I'm guessing not cheap, probably comparable to an aftermarket locker.
2017 4Runner SR5 Premium, Midnight Black Metallic
Crocket is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 02:06 PM #17
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Originally Posted by llDemonll View Post
Why? There shouldn't be a time where you're traveling fast and need a locker...
Come on man, dont rain on the parade. Whats wrong with a rocker on full driving down the highway in dry pavement at 100mph
Grug556 is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 02:17 PM #18
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
The cost to install an LSD is the same as installing a locker, but the LSD part is generally less than a selectable locker by about half. If I was to get one installed I would buy a mechanical Torsen LSD or similar because I don’t like clutch based systems or ones that require friction modifiers as they can wear out over time.
Truthfully I never had a problem running open/open diffs on-road in the snow with an unlocked center transfer case (H4F). The only time I would do differential work is for lockers / off-road capability.
Old 02-19-2020, 03:56 PM #19
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I bet you could turn some baller donuts with a locker in 2wd.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 09:30 PM #20
DMNHNTR's Avatar
DMNHNTR DMNHNTR is offline
DMNHNTR is on a distinguished road
DMNHNTR's Avatar
I really appreciate all the feedback. I personally have driven multiple vehicles with this type of set up and it makes a huge difference when traveling down dirt roads especially with loose dirt or moon dust (Moab roads). I do not want to be in 4Lo or need 4Hi while driving at a normal speed on these types of surfaces. There is a reason even the Ford Raptor has this option. As much as I would love to have a Raptor it just does not suit my everyday needs like my 4Runner. You guys are correct that this would not be beneficial on snow or ice where you need the open diff for traction and not breaking loose as easily.
Current: 2016 Trail, 5100s, Cornfed rear, Fifteen52 Turbomac HD, 285 KO2s, RED Sliders
SOLD: Her Toy 2016 Limited. Cornfed 2/1, 1.25" Spidertrax, 275/60/R20 BFG KO2.
SOLD: 2014 SR5. Camburg/Fox suspension, 1.25" spacers, 285/70/17 BFG KO, BajaRack…
DMNHNTR is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 09:33 PM #21
DMNHNTR's Avatar
DMNHNTR's Avatar
Yes 2WD, locker, supercharger, and traction control disabled, would make for some awesome donuts.
factory , leave , locker , override , rear
Factory rear locker find and install questions. Benski 3rd gen T4Rs 4 05-30-2017 10:41 AM
Plug and Play Rear Camera Override Dongle bjohnston115 4th Gen T4Rs 8 03-18-2016 12:19 PM
Factory Navigation Override and Unlock Bypass Mod J.A. 4th Gen T4Rs 48 07-14-2015 10:40 AM
Factory Remote Start + Door Override? Engineer 5th gen T4Rs 7 09-02-2014 02:29 PM
Factory Rear Locker clemson4rnr 5th gen T4Rs 14 08-01-2010 01:02 PM
