Old 02-11-2020, 11:21 AM #1
DurangoMax's Avatar
DurangoMax DurangoMax is offline
DurangoMax is on a distinguished road
DurangoMax's Avatar
KDSS Calibration
Starting a new thread as I can't seem to find any reliable information on calibrating KDSS after completing a lift. I am in the process of installing a Dobinsons lift (2.5" in front and 1.5" in back). Lift installation instructions had me turn out the shutter valve bolts on the accumulator (3 turns max), install the lift, rock the vehicle back and forth for a minute and then close the shutter valves. I did remove the front sway brackets on the LCA to do the install (big mistake - lots of wrangling and choice words getting those buggers back on afterwards).
My question - should I have the system re-calibrated after this install since I removed brackets, what does calibration do and how do you find someone knowledgeable enough to do it?
Will be posting pics of my install when done - Dobinsons lift, SSO low pro bumper, X20 winch and RCI aluminum skids. SSO bumper just arrived yesterday
'16 4Runner Trail w/KDSS Barcelona Red, Dobinsons Lift (2.5F/1.5R), Dobinsons UCAs, SSO Slimline bumper, Smittybilt X20 Winch, RCI Aluminum Skids, RCI Rock Sliders, BFG AT K02 (285/70R17), APEX Rear Bumper
DurangoMax is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 11:26 AM #2
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
All I know is what my mechanic told me briefly. He puts it on a level flat surface after the lift and there are some valves on each side he opens to balance it out. Then of course closes it back. It was a brief conversation and I wasn't paying much attention so my details may be lacking.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 02-11-2020, 12:06 PM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Here's the instructions, although I didn't do this when I changed my shocks. I used a method I found on here and didn't really mess with KDSS to much.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:28 PM #4
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Regardless they (installers) should do a courtesy check after a few miles (personally around 1k, some recommend 5k). Mainly to check the suspension and all the pieces are working correctly, and level the ride again. If self installed, should get a good idea to make finite adjustments along with other aspects overlooked like adjusting headlights.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:51 PM #5
DurangoMax's Avatar
DurangoMax's Avatar
Appreciate the input - the installer (me) will perform the test and calibrate once I have the rear lift installed (doing that right now). This coincides with the Dobinsons directions to loosen the shutter Valves and rock the vehicle. I will add in the height check, drive it and check again Heading to Moab next weekend for the real test but need to get it aligned before I head over there.
Cheers - Max
back , dobinsons , front , install , lift
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences. CS223 5th gen T4Rs 60 12-08-2021 06:48 PM
RCI Skid Plates KDSS vs Non-KDSS - What's the difference? jthoms1 5th gen T4Rs 13 09-09-2018 10:24 AM
KDSS Calibration tlflow 5th gen T4Rs 17 12-20-2017 12:42 AM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
Zero point calibration KDSS recalibration Moto69Joe 5th gen T4Rs 6 09-01-2015 08:19 AM
