Old 02-11-2020, 11:21 AM #1
DurangoMax DurangoMax is offline
DurangoMax is on a distinguished road
KDSS Calibration
Starting a new thread as I can't seem to find any reliable information on calibrating KDSS after completing a lift. I am in the process of installing a Dobinsons lift (2.5" in front and 1.5" in back). Lift installation instructions had me turn out the shutter valve bolts on the accumulator (3 turns max), install the lift, rock the vehicle back and forth for a minute and then close the shutter valves. I did remove the front sway brackets on the LCA to do the install (big mistake - lots of wrangling and choice words getting those buggers back on afterwards).
My question - should I have the system re-calibrated after this install since I removed brackets, what does calibration do and how do you find someone knowledgeable enough to do it?
Will be posting pics of my install when done - Dobinsons lift, SSO low pro bumper, X20 winch and RCI aluminum skids. SSO bumper just arrived yesterday
'16 4Runner Trail w/KDSS Barcelona Red, Dobinsons Lift (2.5F/1.5R), Dobinsons UCAs, SSO Slimline bumper, Smittybilt X20 Winch, RCI Aluminum Skids, N-Fab Nerf Bar, BFG AT K02 (285/70R17)
DurangoMax is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 11:26 AM #2
mteolus's Avatar
mteolus mteolus is offline
mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all
mteolus's Avatar
All I know is what my mechanic told me briefly. He puts it on a level flat surface after the lift and there are some valves on each side he opens to balance it out. Then of course closes it back. It was a brief conversation and I wasn't paying much attention so my details may be lacking.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor.
Old 02-11-2020, 12:06 PM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
Here's the instructions, although I didn't do this when I changed my shocks. I used a method I found on here and didn't really mess with KDSS to much.
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 201,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:28 PM #4
OYOTA TRD's Avatar
OYOTA TRD OYOTA TRD is offline
OYOTA TRD will become famous soon enough OYOTA TRD will become famous soon enough
OYOTA TRD's Avatar
Regardless they (installers) should do a courtesy check after a few miles (personally around 1k, some recommend 5k). Mainly to check the suspension and all the pieces are working correctly, and level the ride again. If self installed, should get a good idea to make finite adjustments along with other aspects overlooked like adjusting headlights.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP
OYOTA TRD is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:51 PM #5
Appreciate the input - the installer (me) will perform the test and calibrate once I have the rear lift installed (doing that right now). This coincides with the Dobinsons directions to loosen the shutter Valves and rock the vehicle. I will add in the height check, drive it and check again Heading to Moab next weekend for the real test but need to get it aligned before I head over there.
Cheers - Max
back , dobinsons , front , install , lift
RCI Skid Plates KDSS vs Non-KDSS - What's the difference? jthoms1 5th gen T4Rs 13 09-09-2018 10:24 AM
KDSS Calibration tlflow 5th gen T4Rs 17 12-20-2017 12:42 AM
New 4R Purchase: KDSS vs Non-KDSS with Modified Suspension and Added Weight? yellowdog 5th gen T4Rs 5 12-13-2017 01:32 PM
5th Gen. KDSS vs. Non-KDSS handling performance & sway bar diameter differences. CS223 5th gen T4Rs 52 08-19-2017 09:13 PM
Zero point calibration KDSS recalibration Moto69Joe 5th gen T4Rs 6 09-01-2015 08:19 AM
