Old 02-12-2020, 06:11 PM #1
2012sr5's Avatar
2012sr5 2012sr5 is offline
2012sr5 will become famous soon enough
2012sr5's Avatar
"Rumble strip" shudder at slower speeds
Found some threads on this in the 4th gen section...it sure sounds like what I'm experiencing. Between 20 and 35mph, if I'm accelerating lightly I get a shudder that doesn't last very long that feels almost like driving over a rumble strip. It seems to happen more in 4th or 5th gear.
I am inclined to believe that it's a transmission issue because I just had a transmission service done a week ago. I'm at 126k miles. I'm going to call the shop in the morning and let them know of the issue (they're already closed). I want to get it back in with them so they can double check their work.
Is this issue something that you'd expect if they didn't put enough fluid back in or if they used the wrong fluid? This was not a full flush or drain and fill...just a service.
2012 SR5 4WD 3rd Row
Build/Adventure thread
Nitto TG G2 LT265/70R17 review thread
2012sr5 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 06:31 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough
make sure they used WS ATF. The fluid level is checked by removing an overflow plug when the engine is warm. Did you get the work done a regular shop or Toyota? It is a bit complicated to drain and fill because their is not a dipstick.
Share what service you received? Was it not drain and fill?
2015 4runner Limited
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 06:42 PM #3
drewsro's Avatar
drewsro drewsro is offline
drewsro will become famous soon enough drewsro will become famous soon enough
drewsro's Avatar
What is a transmission service? If they did not drain and fill, or flush, I'm not really sure what they did.
Also, was it having issues before you had it "serviced"? I don't see the need of doing anything other than changing out the fluids if there was not an issue beforehand.
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 07:11 PM #4
2012sr5's Avatar
2012sr5's Avatar
It wasnít a full flush...they didnít drain and fill ALL the fluid; just a regular drain and fill (that is only a few quarts) from a highly regarded private transmission shop in town. The idea was to have them do it every 20k miles after 100k. First one I had done was at 105k, and the second one was a week ago at just under 126k.
No prior issues at all...this was for preventative maintenance. Noticed the shudder for the first time yesterday.
Old 02-12-2020, 10:53 PM #5
OYOTA TRD's Avatar
OYOTA TRD OYOTA TRD is offline
OYOTA TRD will become famous soon enough OYOTA TRD will become famous soon enough
OYOTA TRD's Avatar
Iíve experienced similar issues due to suspension issues, alignment, etc.
I wouldnít be surprised if something got off slightly during the transmission work.
My Toyota mechanic said alignment is a common issue with the 5th Gen in my area due to the road conditions (not sure if he was trying to make me feel good or liability reasons).
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD Off Road Premium
OYOTA TRD is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 01:16 AM #6
PK930's Avatar
PK930 PK930 is offline
PK930 is on a distinguished road
PK930's Avatar
Sounds like it wasn’t a complete flush that took all the old fluid out. There’s probably some build up left in the torque converter that didn’t get cleaned out. Go by an auto parts store and look for a little bottle called Dr Tranny. Instant fix.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 08:55 AM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
Sounds like gear hunting 4th-5th. mine has done this since new when cruising around 45mph with a light foot on the accelerator. Are you sure it wasn't doing before? Is it very pronounced or subtle?
Sounds like your on top of maintenance, but dirty engine oil or sludge build up on the OCV filter screens or the OCV will cause this engine to shudder as well. Are you sure it's the tranny?
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 198,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 09:07 AM #8
2012sr5's Avatar
2012sr5's Avatar
I have experienced the dreaded highway wobble around 55mph that I could always fix with an alignment. This ainít that.
Iím inclined to believe that itís the hunting issue. I canít make it happen unless the drivetrain is working, and it seems to happen at low speed when the trans has already shifted a few times. Iím only at 400ish miles since my last oil change.
Old 02-13-2020, 09:16 AM #9
OYOTA TRD's Avatar
OYOTA TRD's Avatar
I had the same issue at 45mph. I took it to the dealer. They did an alignment and the problem was fixed, hasnít done it since. I think the camber was off.
Old 02-13-2020, 10:16 AM #10
Jivewalker's Avatar
Jivewalker's Avatar
Not an alignment issue for me, I've had 192,000 miles worth of alignments. For me, I'm 100% positive it is hunting between 4th and 5th and happens around 45mph with a light foot. A non issue, but hard to tune out once you become sensitive to it, like every other thing you notice when the stereo is off.
Old 02-13-2020, 10:21 AM #11
Jivewalker's Avatar
Jivewalker's Avatar
I would still take it back to the transmission shop and let them drive it with the computer on it and replicate it. They should be able to tell you exactly what's going on. Otherwise, it will drive you nuts.
Old 02-13-2020, 10:35 AM #12
2012sr5's Avatar
2012sr5's Avatar
It definitely seems to happen when it’s getting ready to shift.
I’m going to call them. I find it hard to believe this would just naturally start happening within a couple hundred miles of them servicing the transmission.
Old 02-13-2020, 10:43 AM #13
progress4m progress4m is offline
progress4m will become famous soon enough
It definitely seems to happen when itís getting ready to shift.
Iím going to call them. I find it hard to believe this would just naturally start happening within a couple hundred miles of them servicing the transmission.
I would venture to say the shop either put the wrong fluid (not Toyota WS) or did not fill it to the proper level (more likely underfill), good luck and keep us posted.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: http://www.toyota-4runner.org/5th-ge...estion-50.html thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 11:01 AM #14
2012sr5's Avatar
2012sr5's Avatar
Just dropped it off. The shop owner went for a drive with me and said thatís definitely torque converter chatter. I hope itís just a simple underfill.
Old 02-13-2020, 11:23 AM #15
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
Good news that you could replicate with the shop owner.
I hope the fix is easy and quick and doesnít cost you a dime.
Let us know how you make out
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
back , issue , service , strip , transmission
"Rumble Strip" Transmission issue Ducman 4th Gen T4Rs 357 02-27-2020 11:55 AM
Oil leak and "rumble strip", thoughts? BagiMT 4th Gen T4Rs 3 12-05-2018 04:24 PM
I have the Transmission "Rumble shudder" Issue going on lcbjr77 4th Gen T4Rs 9 03-09-2016 08:11 PM
? " Rumble Strip Tranny" oljedi11950 4th Gen T4Rs 6 01-26-2014 09:18 PM
"Rumble Strip" Transmission issue moved from 4th gen ningduo 5th gen T4Rs 0 10-26-2010 04:13 PM
