Originally Posted by TeaMan
Thanks. Got the bottom shock, appreciated. The one I need yet is the bar that goes from the passenger side frame to the drivers side rear end, just behind the spring on the back side of the rear end. I thought it was called the sway bar. It's about a 12mm bolt I think. Thanks.
That's the panhard bar - 96 ft-lb.
The lower rear control arms are also 96 ft-lb
the upper rear control arms are 59 ft-lb
