Old 02-13-2020, 03:35 AM #1
john_galt john_galt is offline
john_galt is on a distinguished road
Power Steering pump covered in fluid/grime. Leak?
While changing the oil on my 2015 4Runner SR5, with 40k miles, I noticed a lot of fluid/grime on the bottom side of the Power Steering pump.
That was the only dirty area of the engine. I’m not great at identifying fluids, but it seems more like P/S fluid as opposed to motor oil. I couldn’t see any fluid or dirt on the top of the pump or elsewhere. Neither hose connected to the pump seemed to be leaking or covered with fluid at all.
The engine was warm for the oil change, and I noticed the PS fluid was about 3/16” below the min Hot line. I thought for sure this indicated the culprit, but when the engine cooled the PS fluid was right on the min Cool line in the reservoir.
I listened to the bearing/shaft with a stethoscope and it sounded fine.
Any ideas, recommendations or suggestions?
john_galt is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 05:51 PM #2
macenator macenator is offline
macenator is on a distinguished road
Did you find the cause of the power steering fluid build up? I have the same issue on my 2015....
macenator is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 02:05 AM #3
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Clean the area with Wd40 and towels. Then check often. I typically use Wd40 for its ability to evaporate. Fresh leaks are easier to detect on clean surfaces.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 03:06 PM #4
dpacifico13 dpacifico13 is offline
dpacifico13 is on a distinguished road
You definitely have an oil leak somewhere. Clean the area up real well and that should help you find where it’s weeping/leaking. I’d use brake cleaner + brush to get that cleaned up.
dpacifico13 is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 05:20 PM #5
That engine has a propensity to leak near where the 3 parts come together in a triangular meeting (timing cover). I was 5 weeks from the warranty expiring and T-SB-0008-20 would only cover drips not seeps.
I was on the fence if I wanted them to fix this or not. It seems that sometimes the fix can exacerbate the problem.
Anyways, the leak stopped. Still can't believe it. About 8k on the car since the mechanic cleaned everything to see if it would drip prior to the warranty expiration.
engine , fluid , line , oil , pump
Power steering pump leak N3BP 4th Gen T4Rs 13 02-01-2020 09:01 PM
Bad Leak Power Steering Fluid Leatherneck Problems & Warranty Issues 2 04-01-2017 06:25 PM
Power Steering Pump Leak RangerME47 Classic T4Rs 6 02-24-2014 07:48 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
power steering fluid leak 3dnovice 3rd gen T4Rs 4 01-04-2009 05:02 PM
