02-16-2020, 09:42 PM
#16
Real Name: Brandon
Real Name: Brandon
Originally Posted by Flighht2k
If they’re iced up why do you open your window? Just thaw it out?
To back out of the driveway makes it easier to see. Or if I want to get some bfast or coffee at a drive thru
02-16-2020, 09:43 PM
#17
Real Name: Brandon
Real Name: Brandon
Originally Posted by CF_Machete
-18 c is around 0 f, not terrible.
OP, what does the voltage look like on your battery? Do you're head lights dim when you start the truck?
Truck is only 2 months old. Voltage is fine. Didn’t check the head lights when starting. But I think battery is ok. It wasn’t even that cold out. Maybe 20F
02-16-2020, 09:50 PM
#18
Real Name: Brandon
Real Name: Brandon
Originally Posted by catrains
Flagstaff is a good place to go in the hot summer if you live in phoenix..
I have been to that area many times nice in the summer but ya a very cold snowy place in winter.. a great place to go camping ..
In the boston area I live , I go to the white mountains in new hampshire.. ..also in winter a great place for skiing ..
I live in flagstaff now. It is a nice place. I lived in Nashua NH for a few years and used to go up to the white mountains too. Nice area!
02-16-2020, 09:52 PM
#19
Real Name: Brandon
Real Name: Brandon
check and clean the battery terminals.. 0F then a much higher current is required so a battery connection may be the problem.
I put on a silicone dielectric grease on the battery connections .. keeps out the corrosive reaction..
short drives will reduce battery charging.. if a battery is @0F then the battery will not charge.. has to get warmer then it will start to charge....
I have done this work.. a cold battery sitting in the cold for a couple of weeks engine did not crank much slow.. I put the battery in the house put charger on it battery did not charge .. then after a 30 min charge on it it charged up normally .. 5-7yrs is a normal battery life .. short runs will not hold up in your area gets sulfated ..
run it for an hour then bring to a auto store have them do the load tester on it.. O F and it starts IMO still a good battery..
The truck is only 2 months old. Pretty sure then battery is good. I guess it’s possible I got a bad one but probably unlikely. Good info still! Thanks
02-16-2020, 11:18 PM
#20
Had a mid 20's degree day and ice was on my 4runner when I was taking our 7 year old to the walk-in clinic. After 15 minutes of driving, I tried cracking the window down, for some reason I can't remember now, and it wouldn't budge. I kept trying because I thought something was wrong...then realized it was the ice, so I stopped. Probably 10 more minutes passed by and I as able to roll it down. I've had that happen with our other vehicles in the past, but it was much colder at the time.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
02-17-2020, 08:04 AM
#21
$2.94
I like to be able to see through the side windows before I drive off. All of the windows in fact.
The other thing is that whenever I thaw the windows out a little and then lower them the ice and snow falls into the truck.
2023 TRD ORP w/KDSS. Red again.
This 2016 TEP w/KDSS is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
02-17-2020, 09:47 AM
#22
Real Name: Joe
Real Name: Joe
Both of my 19's suffer from the same problem. The windows ice and lock-up very easily. When it gets below freezing my wife and I argue about who's 4R gets to stay in the garage.... I bet you can guess who wins that one...
2019 White 4Runner Limited - NJ
2019 Black 4Runner TRD Off Road - NJ
2019 Silver 4Runner Limited - FL
02-17-2020, 01:17 PM
#23
Real Name: Brandon
Real Name: Brandon
Sounds like a common problem. Thanks
02-17-2020, 10:54 PM
#24
Real Name: Sparky
Real Name: Sparky
Get an ice scraper.
If your windows are iced over, you can't see.
Old and (c)rusty.
02-18-2020, 12:04 AM
#25
Banned
Real Name: Tobias Fünke
Banned
Originally Posted by STX4Runner
Flagstaff is about 7,000 feet in elevation and gets 100 inches of snow a year...
Need to get up there for some play time. My turd gen was a murderer in the snow stock with good tires.
02-18-2020, 12:06 AM
#26
Banned
Banned
Oh yeah op.
Cold ****s with every vehicle. Some people recommend products for your windows. Scraper is also a must.
Silicon spray on your door seals when it drops really low. My turd gen would freeze shut until I wised up.
02-18-2020, 01:31 AM
#27
Real Name: Brandon
Real Name: Brandon
Originally Posted by Mutant138
Oh yeah op.
Yeah I definitely have a scraper living up north! Just used to being able to get a window down with a LITTLE ice on them
02-23-2020, 01:01 AM
#28
Yeah dude, that ain't right. My 2015 with a Batteries Plus Battery dropped Windows at normal speed and it was -9 f up in Vermont last weekend. Sounds like you have a shit battery.
On top of the new battery that I installed, I got a $10 ish voltage meter that plugs into my cigarette lighter. When I started the truck, it was around 14 volts.
I was asking about the lights because my headlights would always dim with the stock battery when I would start up the vehicle. No issues with the new battery.
Troner envy... the struggle is real!
02-23-2020, 02:19 PM
#29
Window wind deflectors help a lot, the rubber doesn't freeze to the glass.
P.S -18C is cute.... Come to Alberta and try some of that -40 weather (-52 with windchill) we have from time to time
02-24-2020, 05:46 PM
#30
Real Name: Brandon
Real Name: Brandon
Interesting. I’ll have to check the battery!
