Old 02-17-2020, 07:17 PM #1
SpaceBanana's Avatar
SpaceBanana SpaceBanana is offline
SpaceBanana is on a distinguished road
Switch Pro 9100 on 2020
Has anyone installed a switchpro on a 2020, kinda lost on how the wiring should go.
Also does anyone happen to use a powertray, I also ran into some issues of it not fitting. I think this might have to do with the relay box.
Any help would be extremely appreciated!
SpaceBanana is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 12:08 PM #2
V8eR_Runner's Avatar
V8eR_Runner V8eR_Runner is offline
Real Name: Kris
V8eR_Runner is on a distinguished road
Real Name: Kris
This might help:
https://trail4runner.com/2018/04/10/...ation-4runner/
Instagram @Vader_Runner 2015 4Runner TRD Pro / ARC LED w/red option / Ellis Precision Shifter &Transfer Case shifter / Xenon Depot Extreme HID Low & LED DRL High Beams / ICON Stage 7 / 1.25" Spidertrax / Southern Style Offroad Slimline Bumper / Smitty Built X20 winch / Odyssey X2 deep cycle battery / Switch Pros 9100 / Rigid RS 20" light bar / Gobi Stealth Rack w/ladder / Rigid Industries Midnight Series 40 / Expedition One Rear Bumper / Baja Designs Squadron Sport / Rigid Industries SRM2 /Baja Designs Amber Fogs / Baja Designs 20" S8 behind grille / Infinite Off-Road Rocks Lights (8) RCI Rear Diff skid / RSG Angled Sliders / Cooper STT Maxx 285/70/17 / Rago Fab Rear Panels
V8eR_Runner is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 06:52 PM #3
Originally Posted by V8eR_Runner View Post
Thanks! But I was already using it, the 2020s have an additional relay box which has moved the wiring from in the cabin to the hood. I cant even install the power tray, ive been in contact with them.
I was hoping someone found a solution to this.
Switch Pro 9100 on 2020-thumbnail-jpg
Old 02-18-2020, 07:03 PM #4
thegreatchangsby thegreatchangsby is offline
thegreatchangsby is on a distinguished road
While not a permanent solution, I just mounted the stech directly on top of the current fuse box lid. I really wish someone comes up with an answer as i'm not a fan of mounting it there. The good thing is the fuse box cover is only 30 bucks or so. Once I find the permanent solution i'll just buy a new one. I guess I could just tape over the two hole I made =p.
The only other solution i can think of is the mount the spod/stech relay box on the top left (where everyone mounts their ARB compressor) and just bit the bullet and run a long battery cable wire to there.
thegreatchangsby is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 07:09 PM #5
I purchased a powertray unbeknownst to me that it wouldnt fit. Hopefully Maverick comes up with a solution to this. He suggested to remove the bolt and tighten it down with the relay box supporting it from under.
You can see how tight of a space it is, there is no way of actually screwing it down.
Switch Pro 9100 on 2020-thumbnail-1-jpg
Old 02-18-2020, 10:15 PM #6
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Yep, the 20s are totally different under there. All the electrical has been rearchitected under the hood and in the cabin as well. Even the fuse locations and the actual circuits in the fuse boxes differ greatly from the previous years.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 04-25-2020, 04:13 PM #7
The_Reaper's Avatar
The_Reaper The_Reaper is offline
The_Reaper is on a distinguished road
The_Reaper's Avatar
I'm trying to figure out where to pull power from for the switched and light wire in cab. I'm guessing i'll have to use a t-tap since I can't use the add a fuse. there is only one slot in the fuse box that isn't used and it's not switched. I was also using the guide that was referenced above but ran in to the differences in wiring and relay box being bigger on the 2020. I used the SDHQ mount for now and drilled new holes and mounted the circuit breaker and buss blocks on top of the engine bay fuse lid for now. I wanted to get the powertray and keep it clean but waiting on Magnuson to release the 2020 supercharger. I think the powertray will interfere with the reservoir for the SC.
Switch Pro 9100 on 2020-20200424_125923-jpg  Switch Pro 9100 on 2020-20200424_125944-jpg
The_Reaper is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 09:52 PM #8
Rbrtito Rbrtito is offline
Rbrtito is on a distinguished road
I’m not sure if you found a fix for your problem running into mounting the Switch-Pros. But this is want I did when I install my arb/switch pro tray in my 2020 last year. I took the bracket for the relay box and cut off the tabs that mount to the fender side. I then mounted the relay box side ways instead and used the hole on the side of the bracket to mount in down. Hope this helps if you didn’t fix a way to mount it yet
Switch Pro 9100 on 2020-70074da9-aaf3-4eae-a007-66711f5f2358-jpg
Rbrtito is offline   Reply With QuoteReply With Quote
Old 05-14-2020, 10:25 PM #9
baysta baysta is offline
baysta has a spectacular aura about baysta has a spectacular aura about
Contact @sdoffroadmt on Instagram. He has a new tray solution for 2020s.
baysta is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 05:31 AM #10
Paragon1's Avatar
Paragon1 Paragon1 is offline
Paragon1 has a spectacular aura about Paragon1 has a spectacular aura about
Paragon1's Avatar
Just did mine a couple weeks ago. Contact Derek at SD Offroad for the mount tray. [email protected]. Wiring is simple, left to right (or top to bottom in the pic) is switches 1-8 respectively. 1-4 hold 20amps, and 5-8 handle 2x17 amps. Just run the yellow and blue wires thru the firewall, and follow the guide from Trail4Runner that the previous poster linked ya to. Take your time, use thread lock. interior panel piece is from SDHQ if you want a better fit/finish.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
Paragon1 is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 02:39 PM #11
He actually contacted me from a previous post! Thanks!
Originally Posted by Paragon1 View Post
Just did mine a couple weeks ago. Contact Derek at SD Offroad for the mount tray. [email protected]. Wiring is simple, left to right (or top to bottom in the pic) is switches 1-8 respectively. 1-4 hold 20amps, and 5-8 handle 2x17 amps. Just run the yellow and blue wires thru the firewall, and follow the guide from Trail4Runner that the previous poster linked ya to. Take your time, use thread lock. interior panel piece is from SDHQ if you don't want a better fit/finish.
How difficult was it to mount with the new tray?
Old 05-17-2020, 11:32 AM #12
Paragon1's Avatar
Paragon1's Avatar
The tray is easy since it uses pre-existing holes in the engine bay. The support brace on the opposite end mounts to a pre-existing hole in the wheel well. Its less difficult if you're not supercharged since there's not as much plumbing to work around. Actual install time for the tray took ~15min after doing a loose fit check, then re-installing the screws with lock-tite.
Old 05-31-2020, 04:41 PM #13
SD Offroad SD Offroad is offline
Real Name: Derek
SD Offroad is on a distinguished road
Real Name: Derek
2020 Mount Tray for the 4Runner
That setup does not mount the Power Module Vertically....
Check out this one though:
Vertical Mounting Tray For Switch-Pros 9100 (Mount Tray - 4Runner)
Thanks @SpaceBanana and @Paragon1 for the support !
But here is the 2020 Mount Tray for those ready this thread for that info... PM me direct for more information !
There's holes for the Terminal Block to go in place of the Fuse Block if wanted.
Switch Pro 9100 on 2020-2020-5th-gen-4runner-fuse-terminal-block-mount-tray-sm-jpg
SD Offroad is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 02:03 PM #14
bokehshooter bokehshooter is offline
bokehshooter is on a distinguished road
Full write up here guys:
https://www.toyota-4runner.org/3499779-post1.html
bokehshooter is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 12:22 PM #15
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
So any tips on where to tap the ignition wire for the Switch Pros on a 2020 or 2021 model?
FourT6and2 is offline   Reply With QuoteReply With Quote
box , extremely , fitting , issues , relay
Switch pro 9100 not connecting to app Flea7907 5th gen T4Rs 13 06-10-2022 10:02 PM
Switch Pro 9100 Vertical Mounting Solution NC[4]Runner 5th gen T4Rs 114 04-27-2022 12:26 PM
sPod HD or Switch Pros 9100 Tejas 5th gen T4Rs 17 05-29-2019 02:34 AM
FS: IL, Switch Pro 9100 Switching set up, $395 BNIB Shipped chitown4x4 For Sale: T4R Items 2 08-09-2018 02:34 PM
