Old 09-11-2022, 01:23 AM #16
10RingRunner 10RingRunner is offline
10RingRunner is on a distinguished road
Originally Posted by FourT6and2 View Post
So any tips on where to tap the ignition wire for the Switch Pros on a 2020 or 2021 model?
Any progress on this, running into the same issue?
10RingRunner is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 02:13 AM #17
FourT6and2 FourT6and2 is offline
FourT6and2 is on a distinguished road
I just tapped one of the fuses in the driver's footwell fuse box. I forgot which one but I can take a look tomorrow
FourT6and2 is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 12:33 PM #18
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Are there any ignition only fuses to tap into in the under hood fuse box?
214RUNNER is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 07:07 PM #19
Did some research this morning
I started mapping the cabin fuse box, diagrams attached if this would help anyone else with a 2020+. Looking for a fuse to plug into for my switch pros 9100, plugging into the only open fuse slot is power not tied to the ignition.
Any help would be appreciated.
Switch Pros 8 button controller (uses the blue wire for power) to an Add'a'fuse
Option #1 KDSS, because I don't have KDSS even though I have a fuse for it.
Option #2 IGN No 2 or 3?
Switch Pros automatic dimmer control (White Wire)
Use an Add'a'fuse to the TAIL fuse
thoughts?
Switch Pro 9100 on 2020-fusebox1-jpg  Switch Pro 9100 on 2020-fusebox2-jpg  Switch Pro 9100 on 2020-fusebox3-jpg  Switch Pro 9100 on 2020-fusebox4-jpg  Switch Pro 9100 on 2020-fusebox5-jpg  Switch Pro 9100 on 2020-fusebox6-jpg  Switch Pro 9100 on 2020-fuseboxnotmapped-jpg
Old 09-11-2022, 07:09 PM #20
Not from any of the install videos I have watched, but most of them skip this step or are installing on an 2018 or older. I will start checking my service manual tonight, good thought.
Old 09-11-2022, 07:29 PM #21
First glance I think the only candidate would be 10A STOP fuse, but I think there are systems utilizing this fuse that are not tied to the ignition.
Switch Pro 9100 on 2020-engine-fuse-box-jpg
Old 09-11-2022, 08:48 PM #22
je32188 je32188 is offline
je32188 is on a distinguished road
For 2020+ for ACC switched power, I've used:
Under hood fuse box: INJ, and I'm 90% sure DEICER will also work
Driver footwell fuse box: Empty slot first column six up from the bottom, ACC, S/HTR FR, COOLING
All those fuses have worked for me for ACC power. I'm not really worried about power draw because everything I've added via fuse tap has a separate power lead for power, it just uses the ACC power via the fuse tap to tell it that it's allowed to turn on. That and I try to pick low amperage fuses of things I almost never use, like the power seats mechanism, or the seat heater circuit, or the power outlets. I absolutely will not tap a fuse that relates to the drivetrain or anything critical to vehicle operation.
je32188 is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 10:36 PM #23
Worked like a charm, thanks for the help!
box , extremely , fitting , issues , relay
Switch pro 9100 not connecting to app Flea7907 5th gen T4Rs 13 06-10-2022 10:02 PM
Switch Pro 9100 Vertical Mounting Solution NC[4]Runner 5th gen T4Rs 114 04-27-2022 12:26 PM
sPod HD or Switch Pros 9100 Tejas 5th gen T4Rs 17 05-29-2019 02:34 AM
FS: IL, Switch Pro 9100 Switching set up, $395 BNIB Shipped chitown4x4 For Sale: T4R Items 2 08-09-2018 02:34 PM
