Old 02-18-2020, 08:42 PM #16
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
Originally Posted by jdhunz View Post
We have Midland GXT1000s and they are pretty well built. Waterproof-ish and fairly compact. Great sound and easy to use.
I have also read great things about these handheld radios. However, the reason I was looking into the MXT275 was simply power. The handhelds have 5 Watts (although REI lists them only at 2 Watts) versus 15 watts. Apparently, from those way smarter than I on the subject 15 Watts does make a huge difference in range. Of course the ADVANTAGE of the handhelds is you can bring them with you while hiking.
The ideal set up for that reason of course would be to get both.
And yes, before anyone pipes in on FCC rules, I did apply for and pay my $70 for the GMRS license. ;-)
rob_dixon is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 09:20 PM #17
jdhunz's Avatar
jdhunz jdhunz is offline
jdhunz is on a distinguished road
jdhunz's Avatar
I hear ya. I’m looking at putting the MXT275 into ours as well...would like to have a decent “base” radio that’s powerful and the handhelds first out of the vehicle excursions.
I found the handhelds at Walmart for $65, so pretty reasonable.
jdhunz is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 01:54 PM #18
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
Originally Posted by WanderlostOverland View Post
We installed our base unit under the center console. There's a complete install video over on our YouTube channel here: YouTube
I was actually impressed and inspired by your video. That's probably where I'll put mine. Not sure I'm going to worry about the extra USB port. I'm not above using a cubby space if I need to (I used the ashtray area in a 2nd gen for the CB I installed in it) but your idea doesn't take any visible space. I love keeping the interior clear of extra stuff as much as possible!
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 01:55 PM #19
PaulC4 PaulC4 is offline
PaulC4 will become famous soon enough PaulC4 will become famous soon enough
Originally Posted by KB180 View Post
Rhino-Rack Folding Aerial Bracket: #43196 - Folding Aerial Bracket | Rhino-Rack
I liked your installation, but I think I'm going to go more with the approach shown by @WanderlostOverland for the interior. However their antenna mount approach would not work for us yet (no steel rear bumper).
The top/roof-rack mount you used seemed like a good approach. Then I saw the price tag for the bracket.... Ouch... It seems odd to me that this bracket is only $18 less than the radio (after discount). Guess it's time to work on my metal fabrication skills :-).
Also, thanks to @GripT4R for his mention of the coupon code (usable directly with Midland). I hadn't run across that bit of info, and that was enough to get me to pull the trigger on this purchase.
(The 'mention' tags aren't behaving as I would expect.)
PaulC4 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 02:26 PM #20
dansoore dansoore is offline
dansoore is on a distinguished road
Mine is inside the center console.
dansoore is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 02:51 PM #21
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
I installed mine under the center console just the right of the cup holder. I used velcro to attached it. the mic i ran a cat 7 cable to dash with female connector so I don't need to leave it attached all the time. I put this on bottom right of steering wheel as i had an open spot there. for my antenna, I installed it on my SDHQ ditch light bracket and it works great.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 07:01 PM #22
WanderlostOverland's Avatar
WanderlostOverland WanderlostOverland is offline
Real Name: Mark & Merri Morrall
WanderlostOverland has a spectacular aura about WanderlostOverland has a spectacular aura about WanderlostOverland has a spectacular aura about
Thanks!!!
'17 TRD Offroad
'07 FJ Cruiser.
https://www.youtube.com/c/WanderlostOverland
Our Build Thread; http://www.toyota-4runner.org/5th-ge...d-vlog%3B.html
WanderlostOverland is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 08:23 PM #23
rob_dixon's Avatar
rob_dixon's Avatar
I liked the way wanderlust overland did it but that is indeed overkill and it occurs to me the wire would still be in the way of your center cupholders and storage.
Ended up putting it under the dash, easily mounted and cant be seen. I fed the power to the rear passenger 12v under the mat. Scroll for video.
Midland in a 4runner - Album on Imgur
Old 03-06-2020, 08:51 PM #24
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Looks clean! May end up going this route!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 09:22 AM #25
Rogue_Runner77's Avatar
Rogue_Runner77 Rogue_Runner77 is offline
Rogue_Runner77 is on a distinguished road
I am thinking the head unit can fit perfectly in the dash space right above the front cup holder.
Photos of your setup?
I just installed this last week.
I like that I can take the unit out easily and use it in other vehicles. I didn't need the Aux/USB port so I got a CAT5 extender so it looks a bit more finished.
Anyone install a Midland MXT275 in a 5th gen?-screen-shot-2020-03-07-8-21-12-am-jpg  Anyone install a Midland MXT275 in a 5th gen?-screen-shot-2020-03-07-8-16-43-am-jpg  Anyone install a Midland MXT275 in a 5th gen?-screen-shot-2020-03-07-8-20-50-am-jpg
Rogue_Runner77 is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 09:01 PM #26
Damn thats clean! nicely done!
Old 03-08-2020, 12:33 AM #27
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I installed one last summer. Certainly not as convienent to move as @Rogue_Runner77 .
I fastened the bracket above the OBD port. The plug I simply ran above the vents to the glove box and utilized the unused cig lighter. I fastened the handset cable to the edge near the vent so it stays out of the way, I like the discreteness. I can transfer it, less the antenna in ~5 mins. The location is really decent for hearing both speakers. Sh!tty cell phone pics below:
Anyone install a Midland MXT275 in a 5th gen?-img_0827-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_0826-jpg
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 01:08 AM #28
In the process of installing my MXT275 I started working on the antenna mount. Because I have a Victory roof rack that uses 80/20 railing I decided to to create a mount that would attach to the side of a rail. It's attached using t-nuts, and the cable is routed through the back hatch and inside of the rubber wiring loom. The nice thing about the MXTA24 cable is that it has a small end that fits through spots that a standard UHF connector will not.
Had to get a couple of nylon washers and file the sides in order to get the spacing right. Without those, the center post of the mount is too high, and the antenna won't screw down all the way to the base.
Now to actually work on the interior... But at least things are functional.
Anyone install a Midland MXT275 in a 5th gen?-img_2779-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2780-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2782-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2786-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2787-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2792a-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2793-jpg
Old 03-10-2020, 08:52 AM #29
Campndad Campndad is offline
Campndad is on a distinguished road
I put mine in the rear behind a custom panel and created a splitter that goes to a rear plug and one up front, so this allows me access to either connection for when we are sitting at the tailgate and running trails.
Campndad is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 10:35 AM #30
big44g big44g is offline
Real Name: Gary
big44g is on a distinguished road
Real Name: Gary
I have been using this model for a few years. Works great. Mounted the antenna on Rago Fab hood ditch light bracket. I Used velcro on radio bracket and stuck it directly on carpet under driver seat. works great and has never moved. I was amazed how well it sticks to carpet.
_____________________
2016 Magnetic Grey Trail, Southern Style Sliders, Rhino Rack
big44g is offline   Reply With QuoteReply With Quote
cup , front , holder , perfectly , photos
FS NIB Midland 75-822 CB MeefZah For Sale: Non-T4R Items 3 06-21-2016 11:42 AM
Midland CB Ashtray Install. Need Help. SR5Runner97 3rd gen T4Rs 1 08-09-2014 09:59 PM
Toyota of Midland, Midland, TX fetcher Dealers - Your Experience 2 01-29-2012 12:33 AM
