Old 04-05-2020, 08:31 PM #31
PaulC4 PaulC4 is offline
PaulC4 will become famous soon enough PaulC4 will become famous soon enough
Well, I finally finished my install. I used the void in the center console, as described by Wanderlost Overland, but I changed the mounting points for the connectors to a different location. I went with the low cubby in front of the shift lever. The 3 foot cable lengths that they had spec'ed in their YouTube posting were long enough to reach.
Other changes I made - I vampire-tapped the auxiliary power socket that runs to the center console. Adding a power distribution system is on my list of things to do real soon now...
Part of the decision on the connector location was driven by thoughts on where the Mic Cord would have the least conflicts with coffee cups. And since I'm also considering that cubby for a set of rocker switches, the connector could easily be moved forward at that time. But all also admit that since cutting these holes will be the first non-reversible mod, I wanted to go for an unobtrusive spot...
I'm not sure how or what I was measuring when I thought that this would work (as shown in the first picture). If anybody else tries this, do not place them as shown there!! The air duct behind that piece was much wider, and closer than I realized.
I wound up moving the RJ-45 plug to the far left, and even then had to apply significant Dremel-tool and X-acto knife surgery to the plug. I moved the USB power port to the far right, and turned it sideways to ensure no conflict.
All of this required a healthy application of epoxy to hold the RJ45 in the new position, since I'd carved away extra plastic, and black duct tape to cover up the empty space. Images of the results of that carnage are further down.
I'm happy with the end result. And, happily, the evidence of this experiment is hidden away where it can't be seen.
Anyone install a Midland MXT275 in a 5th gen?-img_2875-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2876-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2877-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2879-jpg  Anyone install a Midland MXT275 in a 5th gen?-img_2881-jpg
PaulC4 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 12:44 AM #32
dade73 dade73 is offline
dade73 will become famous soon enough
I mounted both my GMRS and CB in my center console. This includes the mic spliters for dual access. Plenty of space.
Dades Bluegirl build
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
dade73 is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 07:07 AM #33
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Originally Posted by KB180 View Post
Finally got around to installing the Midland MXT275 MicroMobile Two-Way GMRS Radio (thanks to Mark at Wanderlost Overland for the review: YouTube). Mounted mine on the Rago Center Console Bridge (drivers side), and ran the power cord plug to the vacant socket in the backseat area of the center transmission console (keeping the radio completely removable/portable). Mounted the Midland optional 6db gain whip antenna to the top of the Gobi Stealth roof rack using a Rhino-Rack Folding Aerial Bracket (still got to get the rig in the garage folks), on the passenger side directly above the slider kick-out so it can be easily reached to fold up/down. Keep in mind that you will be required to obtain an FCC license to operate this radio.
Midland MXT275 Radio: MXT275 MicroMobile(R) Two-Way Radio | Midland USA
Midland MXTA26 6db Gain Whip Antenna: MicroMobile(R) MXTA26 6db Gain Whip Antenna | Midland Radio
Midland MXTA24 Low Profile Antenna Cable: MicroMobile(R) MXTA24 Low Profile Antenna Cable | Midland Radio
Rhino-Rack Folding Aerial Bracket: #43196 - Folding Aerial Bracket | Rhino-Rack
Where do you put your big gulp???
Ogre75 is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 08:37 PM #34
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Anyone using the Ghost Antenna with the MXT275?
MicroMobile(R) MXTA25 3dB Gain Ghost Antenna | Midland Radio
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 08:42 PM #35
Campndad Campndad is offline
Campndad is on a distinguished road
I am using the ghost antenna
Campndad is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 08:54 PM #36
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
I got it. Works well. Put it on the A-Pillar, although I learned from a guy who knows what he was talking about the way radios and attenaes work that Midland is "stretching" the actual specs a bit.
rob_dixon is offline   Reply With QuoteReply With Quote
Old 05-16-2020, 11:22 AM #37
The_Reaper's Avatar
The_Reaper The_Reaper is offline
The_Reaper is on a distinguished road
The_Reaper's Avatar
I like where you mounted your ghost antenna, was the 12ft cable long enough or did you have to extend it? If you did extend it did that effect the performance? I was going to mount mine on the rear of the rack the route the wires back to the center console, but I don't think I can do that without extending the cable and I'm not sure that recommended.
The_Reaper is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 06:44 PM #38
4xColt 4xColt is offline
4xColt will become famous soon enough
Antenna wire path
Hey guys,
I am thinking about getting a MXT275 and putting it in my center console.
What is the best way to get the antenna cable out of the truck? I know there is a grommet in the passenger side of the firewall since I used it for my OEM audio install but I don't see me passing another cable thru there.
If it helps, I am thinking of temporarily mounting it on my hood with the magnetic base. I will only be using it once in a while so I am looking for the easiest way.
Thanks
Colt
2020 Runner TRD Offroad Premium w/KDSS and Moonroof | RSG Sliders | TRD Pro Rims | BFG KO2s | Hikari Ultra (Low and High) | Toyota OEM Black LED Fogs | Focal IS 690 with EOM audio tweeters | Focal IC 165 | OEM Audio Plus System 500 with Dedicated Sub Amp
4xColt is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 09:59 PM #39
Mudhorn's Avatar
Mudhorn's Avatar
Firewall on driver or passenger side is your best option. Some of the antenna cables disconnect on the end to make running the wire a lot easier. I always do the coat hanger trick.
Old 07-06-2020, 10:37 PM #40
Originally Posted by rob_dixon View Post
I liked the way wanderlust overland did it but that is indeed overkill and it occurs to me the wire would still be in the way of your center cupholders and storage.
Ended up putting it under the dash, easily mounted and cant be seen. I fed the power to the rear passenger 12v under the mat. Scroll for video.
Midland in a 4runner - Album on Imgur
Okay, it took me a minute to figure out what you did. Simple and Brilliant!
Your solution works perfectly for me since I will keep the mic in my center console 95% of the time and just plug it in when I need it. The unit is tucked up and out of the way but easy to get at when needed.
Couple of questions:
1. Are those threaded washers?
2. Did you use washers on the other side as well?
3. Do you happen to have a parts list of the hardware you used?
Colt
Old 07-06-2020, 11:04 PM #41
Thanks for the response. I didn't know that the end comes off the cable. I feel a little better now.
Colt
Old 07-07-2020, 06:12 AM #42
Mudhorn's Avatar
Mudhorn's Avatar
Colt
My setup is a low profile antenna cable, ghost antenna, and roll bar mount (installed on Gobi rack). A few people have that setup.
Old 07-07-2020, 01:59 PM #43
rob_dixon's Avatar
rob_dixon's Avatar
Colt
No, they arent threaded. Just flat washers, but you need wide ones with a small hole. I did use washers on the other side i think it was a while ago. Sorry, i do not remember the parts list, all i did was take the screw to the ace hardware and use thier nuts and washer display.
My biggest issue is i simply cant find double stick tape strong enough to hold the mic on. I tried the top stuff and even that peels right off over time.
My other TIP for all of you is do not waste your money on a GMRS license. Yes, i am advising you to technically break the law, but its a $70, and NO ONE FOLLOWS THE RULES. 90% of the traffic is kids playing hide and seek or other child games LOl
Old 07-07-2020, 05:09 PM #44
Stupid question - Be nice!!! :)
I will eventually pickup a antenna that can mount between the hood and windshield but until then...
Would it work if I put the antenna that comes with the unit in the rear passenger side panel? See picture. I am assuming that it should work better than a little hand held unit, right?
Also, would it be safe, health-wise? I am assuming 15 watts coming from the other side of the windshield vs the rear cargo area wouldn't make much of a difference?
Thanks ahead of time for all your help
Colt
Anyone install a Midland MXT275 in a 5th gen?-img_0026-1-jpeg
Old 07-07-2020, 06:47 PM #45
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
FYI, you're going to have a pretty big null in your antenna coverage because of the rack. With any antenna, metal in close proximity is going to absolutely kill the radiation pattern. I'd recommend getting the can completely above the rack rails, unless you prefer the "super stealth" look over improved performance.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
cup , front , holder , perfectly , photos
FS NIB Midland 75-822 CB MeefZah For Sale: Non-T4R Items 3 06-21-2016 11:42 AM
Midland CB Ashtray Install. Need Help. SR5Runner97 3rd gen T4Rs 1 08-09-2014 09:59 PM
Toyota of Midland, Midland, TX fetcher Dealers - Your Experience 2 01-29-2012 12:33 AM
