02-07-2021, 11:06 AM
#61
Originally Posted by TanSolo
Has anyone hardwired their MTX275 radio to the fuse box or the actual battery? The cables upfront are such an eyesore..
Not a big fan of cables out in the open either, I kept it simple and ran the wire over the top of the hvac and to the back of the glovebox, popped the blank out (where a usb might be on other trims) and plugged it into the 12v plug. Out of sight and easy to remove.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
02-08-2021, 12:29 AM
#62
All I have to do is pop out the blank? There's already a 12v plug back there?
02-08-2021, 11:25 AM
#63
Real Name: Ben
Real Name: Ben
He popped out the blank to feed the plug out and then plug it into the 12 volt socket in the dash. The radio comes with a cigarette-lighter type plug.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
02-08-2021, 11:30 AM
#64
Picture inside the glovebox, I may of started here and fed it through, can’t remember, check to see if the plug fits through the knock-out
2013 TE w/ KDSS Nav
02-09-2021, 01:44 AM
#65
Ah, my 2021 ORP doesn't come with it from factory for whatever reason
02-09-2021, 10:53 AM
#66
Real Name: Ben
Real Name: Ben
Yep, mine doesn't either. And that's why I jumped on the idea that he had brought it out of the dash (although, I was kinda stabbing at that without looking at my own dash.)
Sorry for the misleading.
Wouldn't be too terrible to wire in a socket in there if you wanted. The holes are already there. I wonder if there's a loose connector behind the glovebox just waiting to be used?
Now I'm curious...
02-09-2021, 10:21 PM
#67
Those cheap "basturds" As mentioned, you could pop it out with a trim tool and see if it is wired for it, if it is you could either buy an OEM plug, buy a mating connector or just tap it as is, cross fingers.
2013 TE w/ KDSS Nav
02-10-2021, 05:41 AM
#68
i just ran the cig plug to the one of the empty ones behind the center console.
Another buddy, did a ghost install by drilling a hole into the center cubby and used the cig plug in the center cubby.
Although i like your idea more..just gotta get my lazy ass to actually go poke around in the glove box.
02-10-2021, 07:57 AM
#69
Originally Posted by rob_dixon
I am thinking the head unit can fit perfectly in the dash space right above the front cup holder.
Photos of your setup?
I mounted my Midland MXT275 in the glove box like shown on their website. I ran the power wire to my sPOD in the engine bay and run it via my sPOD. I bought a antenna off of Amazon that mounts on my Prinsu roof rack and can be folded down between the cross bars of the roof rack when not needed. I routed the antenna wire through the passenger side firewall and up the A-pillar.
2017 T4R TRD Off-Road Premium, Metallic Gray, CBI Off-road steel bumper, CBI Aluminum Skid Plates, Smitty Built 10k winch, Fox 2.5 DSC/remote reservoir w/ Eibach 700# front coil spring replacement, Icon 2" rear coil springs with Sumo Springs, Prinsu Roof Rack, Rago Fab. Window Storage Panels, Method Wheels 285/70/17 BF Goodrich KO2.
02-10-2021, 07:15 PM
#70
got a link for that foldable antenna mount? I would greatly appreciate it.
02-12-2021, 10:55 AM
#71
Real Name: Bird Dog Overland
As soon as they become available again, I'll buy one and let you know what I came up with in regards of installation.
The 275 and Ghost antenna are both backordered.
02-12-2021, 04:52 PM
#72
Originally Posted by jawkdna
Have mine wired to my Overland Equipped auxiliary power kit...
Less things running to the in cabin fuse box the better (in my humble opinion).
Can you share the tech info on this? It's on my to do list.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
02-12-2021, 08:30 PM
#73
Here is my Amazon link to that antenna.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
02-13-2021, 03:02 AM
#74
thank you!!!!
02-22-2021, 03:44 PM
#75
i have a 2012 TE and didnt know that was in there hahaha. i think i may copy this...where is the unit mounted? what antenna setup did you go with? the 275 comes bundled with a mag mount which i think i will use for now, but would like to go with the ghost antenna at some point. gotta figure out what mount will fit the TE roof rack though.
