Old 02-22-2021, 03:44 PM #76
PrettyGoodSam PrettyGoodSam is offline
PrettyGoodSam will become famous soon enough
also...anyone have a midland discount code?
PrettyGoodSam is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 08:49 PM #77
Land Cruiser Land Cruiser is offline
Land Cruiser is on a distinguished road
EAL -20% off
Land Cruiser is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 10:04 AM #78
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Thinking of getting K-1000 and would be interested in what antenna setup you guys are running.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 10:42 AM #79
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
I even googled that a bit... a K-1000? Are you talking about the K-PO CB/AM/FM radio?
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 11:14 AM #80
Originally Posted by Land Cruiser View Post
EAL -20% off
good lookin out!
Old 02-23-2021, 11:34 AM #81
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
i have a 2012 TE and didnt know that was in there hahaha. i think i may copy this...where is the unit mounted? what antenna setup did you go with? the 275 comes bundled with a mag mount which i think i will use for now, but would like to go with the ghost antenna at some point. gotta figure out what mount will fit the TE roof rack though.
Hi mine is mounted up under and above and behind the knee airbag to part of the steering column support. The antenna is the stock provided, I ran it along the the bottom door trim tunnel over the drivers wheel well, out through the driver rear turn signal, up along the hatch trim, on on to the roof near the roof rack channel. I made a mount from a yakima rack clamp (I had a leftover one of these MightyMount 34H Set of 4
– Yakima
) and a small rectangle (1"x1.75") of 18 gauge steel.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 02:23 PM #82
right on, thanks!
Old 02-23-2021, 05:03 PM #83
Charlievee's Avatar
Charlievee's Avatar
My bad, phone types whatever it wants if I don't pay complete attention to every syllable.
KG-1000G
Wouxun KG-1000G GMRS Base/Mobile Two Way Radio
Old 02-23-2021, 07:52 PM #84
EZBR. EZBR. is offline
EZBR. will become famous soon enough
EZBR. is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 03:27 PM #85
utctscanr75's Avatar
utctscanr75 utctscanr75 is offline
Real Name: Bird Dog Overland
utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light
Originally Posted by PaulC4 View Post
Well, I finally finished my install. I used the void in the center console, as described by Wanderlost Overland, but I changed the mounting points for the connectors to a different location. I went with the low cubby in front of the shift lever. The 3 foot cable lengths that they had spec'ed in their YouTube posting were long enough to reach.
Other changes I made - I vampire-tapped the auxiliary power socket that runs to the center console. Adding a power distribution system is on my list of things to do real soon now...
Part of the decision on the connector location was driven by thoughts on where the Mic Cord would have the least conflicts with coffee cups. And since I'm also considering that cubby for a set of rocker switches, the connector could easily be moved forward at that time. But all also admit that since cutting these holes will be the first non-reversible mod, I wanted to go for an unobtrusive spot...
I'm not sure how or what I was measuring when I thought that this would work (as shown in the first picture). If anybody else tries this, do not place them as shown there!! The air duct behind that piece was much wider, and closer than I realized.
I wound up moving the RJ-45 plug to the far left, and even then had to apply significant Dremel-tool and X-acto knife surgery to the plug. I moved the USB power port to the far right, and turned it sideways to ensure no conflict.
All of this required a healthy application of epoxy to hold the RJ45 in the new position, since I'd carved away extra plastic, and black duct tape to cover up the empty space. Images of the results of that carnage are further down.
I'm happy with the end result. And, happily, the evidence of this experiment is hidden away where it can't be seen.
I was thinking something similar to this except putting the plugs in the smaller hub above that (since I keep my sunglasses in the bigger one, lol).
utctscanr75 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 11:48 AM #86
Originally Posted by ATX14 View Post
I mounted my Midland MXT275 in the glove box like shown on their website. I ran the power wire to my sPOD in the engine bay and run it via my sPOD. I bought a antenna off of Amazon that mounts on my Prinsu roof rack and can be folded down between the cross bars of the roof rack when not needed. I routed the antenna wire through the passenger side firewall and up the A-pillar.
have you had any issues with heat dissipation with the head unit in the glove box? i think i want to go this route, but thats really my only potential drawback.
Old 03-02-2021, 03:25 PM #87
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
These will mount up under the dash... away from your knees. No heat problem.
No having it across the rig.
Mount it under the dash then get a plug for the mic that goes in a switch blank (shown in this thread earlier).
Now you haven't wasted any storage space and the install is hidden.
My 2cents.
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 08:53 PM #88
ATX14 ATX14 is offline
ATX14 will become famous soon enough
No heat issues with the head unit mounted in the glove box. It is exposed to the interior climate of the cabin. It definitely beats my CB radio. Hope this helps.
JD
2017 T4R TRD Off-Road Premium, Metallic Gray, CBI Off-road steel bumper, CBI Aluminum Skid Plates, Smitty Built 10k winch, Fox 2.5 DSC/remote reservoir w/ Eibach 700# front coil spring replacement, Icon 2" rear coil springs with Sumo Springs, Prinsu Roof Rack, Rago Fab. Window Storage Panels, Method Wheels 285/70/17 BF Goodrich KO2.
ATX14 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 03:31 PM #89
JD
thanks for the reply! so the glove box temp usually hovers around the same temps as the interior? if so, that sounds like a winner. thanks again!
Old 03-22-2021, 11:30 AM #90
loosely installed mine this past weekend. zip tied the bracket to the victory center console molle panel for now so i could use it. gonna do the glove box install when i have some time and swap out the stock antenna for the 3db ghost antenna. radio works great! i like it a lot.
cup , front , holder , perfectly , photos
FS NIB Midland 75-822 CB MeefZah For Sale: Non-T4R Items 3 06-21-2016 11:42 AM
Midland CB Ashtray Install. Need Help. SR5Runner97 3rd gen T4Rs 1 08-09-2014 09:59 PM
Toyota of Midland, Midland, TX fetcher Dealers - Your Experience 2 01-29-2012 12:33 AM
