Old 07-07-2020, 07:26 PM #46
4xColt 4xColt is offline
4xColt will become famous soon enough
The other option for me is to just stick the magnet mount on the roof when I plan on hitting the trail.
For those of you that use the magnet mount antenna, what is the best way temporarily run the cable to the roof? Is there route that is better than others, like rear or front door jam, between the doors, rear hatch?
Thanks again guys
Colt
2020 Runner TRD Offroad Premium w/KDSS and Moonroof | RSG Sliders | TRD Pro Rims | BFG KO2s | Hikari Ultra (Low and High) | Toyota OEM Black LED Fogs | Focal IS 690 with EOM audio tweeters | Focal IC 165 | OEM Audio Plus System 500 with Dedicated Sub Amp
4xColt is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 08:13 PM #47
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Originally Posted by jdhunz View Post
We have Midland GXT1000s and they are pretty well built. Waterproof-ish and fairly compact. Great sound and easy to use.
If you are doing only FRS/GMRS I would highly recommend the Midland GXT100s. In expensive, high quality, compact, no extra holes in your truck and does not require an FCC license in the US. Canada is different.
Not that anyone checks it, but that particular mobile unit requires an FCC license and there are people out there with nothing to do. I think $75 will get you that, no test required. My advice is to be legit, pay the $$ and use your call sign.
I have the Midland GXT1000 and a Baofang BF-8HP. I use the midland in rural areas for group comms and only use the Baofang on licensed Ham frequencies, which not everyone has, but in a pinch I can usually get to someone somewhere if I have a repeater.
A mobile GMRS will have a better antenna with a tiny bit more elevation and does transmit at 15W vs 2W handheld. However, more transmit power means they might hear you, but you can't hear them. Also 100W doesn't go through a mountain, it's all relative line of sight at that frequency.
In the end mobile GMRS doesn't really buy you much. Receive will be exactly the same. But you have the ability to source more power and use repeaters that mostly don't exists.
If you buy a programmable radio, like the Baofang, they are not FCC certified for GRMS (back to people with nothing better to do) they don't sound any better even at higher power levels nor do they have better range (about .5-1 mile urban) than the Midland handhelds. Seriously. It's because the Baofang is inexpensive and has a crap speaker.
Best of luck and stay safe.
itr1275 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 06:40 PM #48
Okay, so I will figure out how to temporarily get the cable to the roof out the back hatch.
I will be ordering a ghost antenna, cable and the MICROMOBILE®MXTA20 TOYOTA 4RUNNER BRACKET MOUNT when they are back in stock.
Do I need to "ground" the bracket? I thought I read somewhere that the Rago CB bracket needed to be grounded, is this true for the Midland GMRS bracket as well?
Thanks again,
Colt
Old 09-04-2020, 01:42 PM #49
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
Originally Posted by Campndad View Post
I put mine in the rear behind a custom panel and created a splitter that goes to a rear plug and one up front, so this allows me access to either connection for when we are sitting at the tailgate and running trails.
Can I ask where you got that "UHF" plug for the front?
Want to replicate this!
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 09-07-2020, 06:33 PM #50
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
I don't know about OP, but if you search Amazon with "UHF rj45 radio panel", you'll get a few hits.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 08:47 PM #51
Tajji28's Avatar
Tajji28 Tajji28 is offline
Tajji28 is on a distinguished road
Tajji28's Avatar
Does anyone know how much amperage the usb ports put out? Im putting the unit in the glovebox and was thinking of running a charge cable for my navigation tablet while Ive got a bunch of the dash out. Thanks!
Tajji28 is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 10:17 PM #52
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
What are some good antenna mounts? Not a fan of magnet options or the "lip mount" types.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 08:33 PM #53
jawkdna's Avatar
jawkdna's Avatar
A Gobi Rack makes a great mount...
XXX
Old 01-14-2021, 09:08 AM #54
Campndad Campndad is offline
Campndad is on a distinguished road
Originally Posted by The_Reaper View Post
I like where you mounted your ghost antenna, was the 12ft cable long enough or did you have to extend it? If you did extend it did that effect the performance? I was going to mount mine on the rear of the rack the route the wires back to the center console, but I don't think I can do that without extending the cable and I'm not sure that recommended.
Sorry reaper just saw this. The unit is actually in the rear so we used the 12ft and had a lot left over.
Here is a link to the article on it.
Custom Two Mic Installation of the MXT275 MicroMobile | Midland Radio
Campndad is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 02:15 PM #55
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
I drilled three NMOs into the roof, but that's a pretty extreme option.
Like others have said, a roof rack offers a pretty good ground plane.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:54 PM #56
Charlievee's Avatar
Charlievee's Avatar
Not getting a rack to mount an antenna.
Old 01-14-2021, 06:32 PM #57
jawkdna's Avatar
jawkdna's Avatar
So:
no magnet
no "lip mount" types
no roof rack
You're running out of options here...
you could try:
Rago's 5TH GEN TOYOTA 4RUNNER CB ANTENNA MOUNT - STAINLESS STEEL
or
Rago's HAM ANTENNA DITCH BRACKET EXTENSION
You could just mount a single ditch light bracket from any manufacturer and mount the antenna to that (with no light). I've seen a few people do that, but you're going to get a better signal the higher up on the rig you can get that antenna....
good luck
XXX
Old 01-17-2021, 09:59 PM #58
Stabbi Stabbi is offline
Stabbi is on a distinguished road
Originally Posted by rob_dixon View Post
Do you feel in hindsight now that this model was the correct one to buy? I am pretty close to making a decision but so many options and i want to reach FRS stations (FCC requires lower power) in case people have handheld cheapo 2 ways. Not sure this can do that.
Just bought the Btech GMRS 50x1...hope to be installing over the next few weeks (hasn't shipped yet).
Stabbi is offline   Reply With QuoteReply With Quote
Old 02-06-2021, 08:09 PM #59
TanSolo TanSolo is offline
TanSolo is on a distinguished road
Has anyone hardwired their MTX275 radio to the fuse box or the actual battery? The cables upfront are such an eyesore..
TanSolo is offline   Reply With QuoteReply With Quote
Old 02-06-2021, 08:17 PM #60
jawkdna's Avatar
jawkdna's Avatar
Have mine wired to my Overland Equipped auxiliary power kit...
Less things running to the in cabin fuse box the better (in my humble opinion).
XXX
cup , front , holder , perfectly , photos
FS NIB Midland 75-822 CB MeefZah For Sale: Non-T4R Items 3 06-21-2016 11:42 AM
Midland CB Ashtray Install. Need Help. SR5Runner97 3rd gen T4Rs 1 08-09-2014 09:59 PM
Toyota of Midland, Midland, TX fetcher Dealers - Your Experience 2 01-29-2012 12:33 AM
