Old 02-18-2020, 05:51 PM #1
thegreatchangsby thegreatchangsby is offline
thegreatchangsby is on a distinguished road
2020 spod/stec/switchpro/relay box position
Has anyone with a 2020 4runner installed any sort of relay box?
In the 2020 there's a fairly large factory relay/fuse box in the place where we usually install relay boxes/power tray. I assuming this new OEM box is due to the added TSS. The harness for this box is super short and there's not anywhere to really put it.
Where are all of you installing your relay box/bus system in the 2020's.
I ended up just mounting my stech relays on top of the current fuse box, but I don't really want to mount it there full time. Anyone have any other solutions?
thegreatchangsby is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 08:12 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
I was looking at that over the weekend. I had more or less decided to mount anything I needed to the cover of the underhood fuse box and just leave enough slack to be able to remove that as needed.
I did the same thing in my 4th gen and to be honest, it was 100% OK. I don't think I ever needed to get into that underhood box more than once or twice in the years that I owned that truck.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 11:00 PM #3
casrunner casrunner is offline
casrunner is on a distinguished road
I had a hard time deciding where to put it but just ended up putting it over top the new fuse box. I made my own relay box using the blank tray from powertrays.com. It was one of the most difficult things I have done to my vehicle. Trying to screw in the two screws into the sidewall was near impossible with that new fuse box. I hope I never have to get into that fuse box because I don't think I will be able to put the powertray back on, let alone remove it.
I also had to clip the little retaining/grounding piece off the bracket that holds it to the sidewall. I will try and post pictures. I'm new around here so sorry for any formatting issues.
I think if I would do it again I would find a way to put it on the other side of the engine compartment, but then I would be restricting myself from a second battery.
2020 spod/stec/switchpro/relay box position-20200125_095620-jpg  2020 spod/stec/switchpro/relay box position-20200125_095639-jpg  2020 spod/stec/switchpro/relay box position-20200128_203627-jpg  2020 spod/stec/switchpro/relay box position-20200128_203638-jpg
casrunner is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 11:46 AM #4
bokehshooter bokehshooter is offline
bokehshooter is on a distinguished road
Thanks for the photos. I was looking to purchase the vertical power tray as well for my Switch Pros on my 2020 and found your post. Did you by chance contact Power Trays about this dilema? Is this what everyone else is doing for their mounting solution? I am hesitated to install over the top of the relocated relay box myself.
bokehshooter is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 03:00 PM #5
SpaceBanana's Avatar
SpaceBanana SpaceBanana is offline
SpaceBanana is on a distinguished road
I was in constant contact with Maverick, which I believe is the owner. He eventually stopped replying to me, but he did offer me a refund. His solution was to mount it at the same location in the pictures, but due to how small of a space it would be I decided against it. There doesnt seem to be a solution to mounting it, unless some was makes a support beam in the center to hold the tray up, but even then that seems kinda sketchy.
I tried to relocate the relay box but even that barely moves, so it doesnt seem like there's an option to mount it with a tray. I hope someone makes one in the future, I will probably ask for a refund from PowerTrays (Maverick) once this Covid thing blows over.
SpaceBanana is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 03:03 PM #6
MillerPKA's Avatar
MillerPKA MillerPKA is offline
Real Name: Weston
MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough
MillerPKA's Avatar
Real Name: Weston
The sPOD Bantam mounts on the fuse box lid so you should still be fine there?
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
MillerPKA is offline   Reply With QuoteReply With Quote
Old 03-20-2020, 03:44 PM #7
Im trying to mount a SwithPro with a blue sea fuse box.
Old 04-06-2020, 09:36 PM #8
baysta baysta is offline
baysta has a spectacular aura about baysta has a spectacular aura about
Anyone figure out any other ideas for the switchpros mounting in 2020s?
baysta is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 02:00 PM #9
SDOffroad was working on a tray that would work with the 2020's. Here is the thread link. Switch Pro 9100 Vertical Mounting Solution
Old 04-07-2020, 02:30 PM #10
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If you are using a SwitchPro, you could consider deleting the fuse block altogether. It's not really required with how it was designed to operate.
Old 05-31-2020, 04:30 PM #11
SD Offroad SD Offroad is offline
Real Name: Derek
SD Offroad is on a distinguished road
Real Name: Derek
Thats correct, the Fuse Block is not used in conjunction with the Switch-Pros... But sometimes people need to protect mods not run through it.
Here's what Spacebanana was talking about. Just got these in. Couple cables coming in this week.... ready to ship now without them.... PM me for more info
2020 spod/stec/switchpro/relay box position-2020-5th-gen-4runner-fuse-terminal-block-mount-tray-sm-jpg
SD Offroad is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 06:10 PM #12
mystiqueskillz mystiqueskillz is offline
mystiqueskillz is on a distinguished road
Would this work for the sPod too?
mystiqueskillz is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 09:11 PM #13
umidkusername umidkusername is offline
umidkusername will become famous soon enough
I understand the desire to do it yourself, the spod I’m looking at is like 850 or something but it literally has all the hookups and is super easy to install. Location would be on top of the fuse box. Hook positives to it, hook negatives to it. Built in fuses. No hassle.
I would imagine with a custom fuse box you could mount anywhere as long as you get a piece of metal cut to mount somewhere. A custom set up may not fit on top of the fuse box if you’re doing relays, which with the wires, take up a good bit of space.
Another option would be the trunk and mounting to molle panels. Avoid the engine bay all together.
umidkusername is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 01:43 PM #14
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
The sPod needs to be connected to the battery, so you'd either have to run longer cables or make a whole different setup to run it in the back. I used the PowerTray for my sPod, that's a shame that it doesn't work on the 2020's because it was super convenient for me
Old 06-02-2020, 03:26 PM #15
Hook a spod to an aux battery and put it in the rear. I’ve considered it. The engine produces a lot of heat. I don’t want too many things in the engine bay.
I know plenty of people do it with no problems though. It’s just another option really.
box , mount , mounting , relay , relays
Generic amazon SwitchPro alternatives: anyone have experience w/ these? PVB'Runner 5th gen T4Rs 3 05-18-2019 05:03 PM
For Sale: $300 New Unused SwitchPro 8100 version 2.0 empty403 For Sale: Non-T4R Items 4 12-13-2017 05:43 PM
LED Light Position (diode position in projectors) tral 5th gen T4Rs 1 10-26-2017 12:31 PM
Help with SwitchPro and camera MadeInMaine 5th gen T4Rs 8 08-08-2017 01:31 PM
