02-18-2020, 06:21 PM
General Grabber vs Nitto Ridge Grapplers
Hello all. In the final stages of negotiating with my installer for the following:
Bilstein 2.5 " suspension upgrade
Pro Comp 69 Wheels
New Tires:
He's pushing the Nitto Ridge Grapplers over my choice, General Grabbers.
I want a solid AT tire that is reliable on pavement but capable off road and to be honest, I want white lettering on the tire.
He's pushing the Nitto's pretty hard, and it's only about $100 total difference.
TireRack says the Grabbers are their #1 A/T by reviews.
Any thoughts from anyone on this? This is the look Im' going for FYI:
Thanks in advance.
b
e
n
2017 TRD Off Road
02-18-2020, 06:50 PM
Real Name: Weston
Real Name: Weston
I ran the Grabber A/T X for a while between my sets of X3s and 2 of our builds are still running them. Absolutely fantastic tire. I did a write up on them if you're interested. General Tire Grabber A/T X Review | Outworld
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
02-18-2020, 07:57 PM
Originally Posted by benhalleniii
He's pushing the Nitto Ridge Grapplers over my choice, General Grabbers...
Get the tires that you want and take ownership of the outcome. Done.
"Sometimes I sit and think. Sometimes I just sit."
02-18-2020, 08:04 PM
I hear plenty of bad things about the Nitto Ridge Grapplers. Conversely I hear very few complaints about the General Grabber ATX. Get the tires you want and don't let the installer push you into a decision you don't want.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
02-18-2020, 08:54 PM
I'd say go with the Generals although I have never run them. I had 1 1/4 sets of Ridge Grapplers and they are just mediocre. (Second set one was horribly out of round and had and had to fight with Nitto for a month to get 50% back on them.) I went to the Cooper St Maxx and it's far better all round albeit a bit more aggressive than the Grapplers.
02-18-2020, 09:24 PM
Id go with the General Grabber... always wanted to try a set.
I had the Nitto Terra Grappler AT on my Silverado and I wasn’t really impressed or disappointed with the tire. I think mediocre is a good descriptor.
Eventually they started cracking and replaced them with Cooper Discoverer AT3
02-18-2020, 09:32 PM
General grabber!
02-18-2020, 10:32 PM
I've been running the Grabber ATX's for 3 months and think they are great.
Sent from my moto z3 using Tapatalk
02-18-2020, 11:29 PM
Well damn...
...that's a slam dunk for the tires I want then! Thanks all.
b
e
n
2017 TRD Off Road
02-19-2020, 12:07 AM
i put ATX's on mine 25k miles ago and they have been great
Toyota 4x4 #17 - 2011 4Runner Trail Edition
02-19-2020, 01:20 AM
Go with the ones you want. I went with Ridge Grapplers in SL. They are light, quiet on road, handle rain and puddles well and almost everything not made out of wood is soft in Central Florida so the SL work in the sandy mud just fine for me. Not trying to persuade you with that, because if you want raised whites and if don't get them it will always be in the back of your mind when you look at at your truck, get a flat etc. regret sucks...
2011 SR5 Bilstein 5100's at 2.5 Cornfed 1.5 in rear. Nitto Ridge grappler 285 70 17 on matte bronze RRW RR5-S
02-19-2020, 01:31 AM
I am running General Grabber AT/x and I am highly impressed.
02-19-2020, 01:34 AM
Pro Comp 69 Wheels
e
n
You can go to Discount Tire Direct, enter your vehicle, then choose the tire size, and then search by Treadwell. That will give you lots of independent tire testing. The ATX gets good reviews here and not so good scores on the testing. I have no idea, personally. Never ran any Generals.
Also, remember that tires play together with shocks and springs. In my experience, lighter duty shocks springs go well with SL tires and heavier duty suspension with heavy tires. My current LTE tires on a stiffer suspension actually feel better than SL on the same. I am not sure about the engineering specifics but tire weight is one part of the story.
Ha! I just put my first 300 miles on the sibling ATZ P3 and cannot have been more impressed. Offroad is obvious, but I have been shocked by how good they have been on road with my heavy duty suspension.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
I've done a ton of research and the general AT X are the way to go
02-19-2020, 09:30 AM
Real Name: Jim
Real Name: Jim
I have no experience with the Nittos but had Generals on my Grand Cherokee and loved them. 2 sets worth as a matter of fact. I have Falkens on my 4Runner mostly because of the great reviews here and any other place I looked plus the Grabbers were not available in the size I wanted. I don't think you can go wrong with the Generals.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
