02-19-2020, 02:39 PM
Reverse Lights
So I replaced my reverse lights as shown in the link below. These lights are no better, maybe even worse than the stock lights. This thread is several years old, so maybe those lights are out of date. I did a google search & these are the most recent that came up. Does anyone have a better option, that doesn't cost an arm & a leg?
LED Reverse Lights for 5th Gen 4Runner, Reverse Lights LED Swap
02-19-2020, 02:55 PM
Real Name: Jason
Real Name: Jason
Diode Dynamics Tail as Turn module is $50. Then just purchase the LED of your choice, doesn't have to be through DD.
02-19-2020, 03:10 PM
Thanks NW.OH.T4R, I should have specified better. All I want to do is switch out the bulbs. Doesn't even need to be LED.
02-19-2020, 03:15 PM
Cut and paste this into Amazon. They are awesome for $14....
JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White
__________________________
2014 4Runner LE - XD Grenade OR 17" Gunmetal Wheels - 285/70/17 Ridge Grapplers - XREAS Delete - ToyTec BOSS Suspension Lift w/SPC UCA's - Borla Catback Exhaust - AFE Momentum GT Pro CAI - Sprint Booster (wow!) - Tint Match - AVS Aeroskin - K&N Washable Cabin Air Filter - Black Emblem Kit - Stock Running Board & LE Rocker Trim Delete - Added RSG Flat Sliders w/bump-out & TE Rocker Trim - Full LED Swap - Rola Rack & Fox Wing Awning: Skids, lights and new front end w/Slimline bumper & winch still awaiting clearance from the tower...
02-19-2020, 04:05 PM
Real Name: Chris
Real Name: Chris
If you have the stock head unit you may have to adjust the brightness and contrast to see the LED light as well.
I'm using these, they're insanely bright!
https://www.amazon.com/LASFIT-Revers...2142701&sr=8-4
02-19-2020, 04:49 PM
Real Name: Luke
Real Name: Luke
I put these JDM ASTAR 921 in for $14, they're plenty bright enough!
02-19-2020, 06:21 PM
Just put JDM ASTAR in my truck last week, bright as hell and works perfect.
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
02-19-2020, 06:37 PM
Reverse lights
02-19-2020, 07:48 PM
Originally Posted by ForRun
Reverse lights
which ones do you have?
02-19-2020, 08:53 PM
I put these in after seeing another thread:
AUXITO 912 921 LED Backup Light Bulbs High Power 2835 15-SMD Chipsets Error Free T... https://www.amazon.com/dp/B0728DYR9H..._bGDtEbBVKE7PS
They are hella bright and really illuminate things way better than stock.
When you have to shoot, shoot....don't talk.
#black4runnersmatter #myprodoesntclunk
02-19-2020, 09:44 PM
Went with these. Mounted underneath tucked away. Tap the hitch for power and reverse trigger. Black and yellow, grabbed a ground in the hatch and ran relays to switches on the dash. Auto on with reverse/off/ on at will, helps with tailgaters
02-20-2020, 10:56 AM
Real Name: John
Real Name: John
Does anybody have the Vleds for $70 a pair? If so comments and maybe
pictures from outside and the dash cam.
Thank you
Education costs money, whether you go to college or make a mistake you end up paying for it.
02-20-2020, 11:19 AM
Real Name: Ben
Real Name: Ben
It looks like you re-mounted your trailer plug. Am I right? I've thought about moving mine. Tucked back up is nice and out of the way, but it sure sucks when you want to plug into it.
If you did do it, what did you do to move it regarding wiring and mount?
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
02-20-2020, 03:21 PM
Do your bulbs have LEDs all around the bulb or just on 2 sides? Mine were only up & down and I had to rotate them so the LEDs were facing right & left. Made the visibility better by casting out the light in the proper directions. Hope that makes sense.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
02-20-2020, 03:27 PM
Real Name: Chris
Real Name: Chris
Anybody looking for a set of reverse bulbs, I have a set of these for sale. Selling for $25 shipped. They go for $35 plus shipping
921 2.0 LED Bulbs - Profile Peak – High Performance LED Reverse Light Bulbs from The Retrofit Source
Nothing wrong with them. I was given another set of bulbs so these have just been sitting on my work bench.
Here's the output
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
