Old 02-19-2020, 02:56 PM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
When should I replace diff oil?
Hello guys,
I have about 41k on the my 2016 4runner limited .Since I got it used, I am not sure if the previews owner did it. When should I replace my differential oil? Should I replace transfer case oil too?
Thanks
amir_gh is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:10 PM #2
spartacus's Avatar
spartacus's Avatar
Its's fairly straight forward. undo the fill plug before the drain plug. just do it as cheap insurance.
Front and Rear Diff fluid change
Old 02-19-2020, 03:11 PM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Some do it at 30K and 60K. I'm very comfortable performing the Diff and Transfer case service between 60-90K miles. I'm at 60K now on a 2015 Limited and am not in a rush. Maybe next summer. I will use the special expensive Toyota Gear Oil 75w in the transfer case. Just me being particualr about the oil in the transfer case. I'm not so concerned about what I put in the diffs.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:32 PM #4
amir_gh's Avatar
amir_gh's Avatar
Prefect thanks for the link.
Old 02-19-2020, 03:38 PM #5
amir_gh's Avatar
amir_gh's Avatar
Great thanks
Old 02-19-2020, 04:01 PM #6
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Originally Posted by amir_gh View Post
Hello guys,
Thanks
I check the drive train fluids on my oil changes. @3K miles on it the rear diff was a dark gray color.. changed it .. 2016 SR5 4WD.
last nov 2019 diff oil and other drive train fluids still look good.
check the color and condition of the gear oils.
the other issue . well NOW we must use the SN plus engine oil spec... this got approved in may 2018 . engine very quiet on cold start.
read the back of the oil bottle for SN PLUS not just SN....have fun
catrains is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 08:16 PM #7
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
the other issue I had was we all have fuel direct injection engines. well NOW we must use the SN plus engine oil spec... this got approved in may 2018 because manufactures had many of these engines damaged because of the direct fuel injection.
Uhh No- the 4.0 is not a direct injection engine.
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 09:54 PM #8
Yes I did make a mistake on the direct fuel injection comment .. DFI dumps fuel into the combustion chamber ..
on the 4L engine .SFI.sequential fuel injection system with twelve-hole fuel nozzles for each cylinder..
because I did change to SN PLUS the runner is very quiet on cold starts.
moly keeps it quiet no ticking on any cold start. 800PPM moly.
Old 02-19-2020, 10:38 PM #9
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
On my 3rd 4runner now, have always done 50k mile intervals for both diffs and transfer case.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 11:37 PM #10
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
The Toyota 0W-20 Synthetic is labeled as API SN and SN PLUS. I presume this is what you used.
More info:
API SN Plus: Fast Tracking New Engine Oil Specifications | F&L Asia
API | Latest Oil Classifications
When should I replace diff oil?-a118f09d-d1a8-494e-8410-788799b7f2bb-jpeg
Old 02-20-2020, 12:52 AM #11
ghost.runner ghost.runner is offline
ghost.runner is on a distinguished road
If you do not do much off-roading, you can get away with changing fluids at longer intervals. I like to do mine every 15K miles in the wet PNW climate, even though I'm on pavement around 99 miles out of 100. Just a force of habit from my Jeep days, but I also like the peace of mind.
ghost.runner is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 12:18 PM #12
More info:
ya that is what I used nov2019 it works no cold start ticking ..
Old 02-20-2020, 01:26 PM #13
gsla72 gsla72 is offline
gsla72 will become famous soon enough
Just changed my diff fluids out about a week ago - 45k miles on the fluid (factory fill). I sent a sample off for analysis and it came back squeaky clean. My vehicle seens mostly highway miles and has not been through much if any deep water.
As with everything oil related, your specific usage is going to set the timing for when to replace fluids. Unless you know the previous owner of your truck, it's safer to assume that no fluid maintenance was performed if there are no records of it.
If you've driven through deep water without having completed the diff breather mod you may want to change the fluid just in case regardless.
gsla72 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 01:46 PM #14
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Where you gonna get the synthetic factory 75w90? I couldnt even find any dealers who even stock it let alone use it on vehicles. They all use mineral based due cost and lack of routine use.
I doubt you will find a dealer in NA who uses the factory fluid in a refill of a diff.
Grug556 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 02:00 PM #15
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Red Line makes OEM compatible fluids that list the specific Toyota part numbers. Look under the OEM Compatibility tab of each and you will see what I mean. I bought some for my FJ Cruiser but ended up trading it in for my T4R so I will use it in it instead.
Toyota/Lexus 08885-02506 equivalent
Toyota/Lexus transfer case fluid "Genuine Gear Oil LF 75W“ 08885-81080 equivalent
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
differential , oil , owner , previews , replace
Front Diff: Replace Axle Seal? or Both Seal and CV? Berty_K 4th Gen T4Rs 10 10-10-2021 10:36 PM
have to replace diff...what mods? WeeRunner 3rd gen T4Rs 5 10-19-2013 07:48 PM
99 4wd limited, diff burned up... need to replace vstech 3rd gen T4Rs 17 07-22-2013 11:28 PM
replace rear diff. or entire rear end? Washington4R 3rd gen T4Rs 7 02-27-2007 04:10 PM
replace rear diff. or entire rear end? Washington4R Maintenance/Detailing 3 02-26-2007 11:41 AM
