Old 02-26-2020, 11:13 AM #1
obxbird obxbird is offline
obxbird is on a distinguished road
What pressure are you running your Falken Wildpeaks AT3W's
Just had a new set of Falken Wildpeaks installed. I have a 2.5" lift running 265/70R17's. I have 36 psi in them now and it seems to ride ok, now I'm trying to figure out where the sweet spot is for tire pressure. Just curious as to what everyone else is running theirs at.
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 11:30 AM #2
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
2.5" lift. 285's 10ply. I run about 38psi on the street. 25psi on dirt. 15-18psi for sand/mud/snow and sometimes rock. Need to get a tire gage, track wear now that I got my lift and alignments where I want them, and adjust street pressures accordingly.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 12:01 PM #3
bamma's Avatar
bamma bamma is offline
Location: Stuck in an electric mountain trap in the Pyrenees or Mars, or Spokane WA.
Real Name: Dark Lord Xenu
bamma will become famous soon enough
bamma's Avatar
Find the Correct Tire Inflation Pressure | Toyo Tires
There are tables for this. If you are running LTs you are too low (unsafe). If running P metric you are higher than recommended.
If I recall from the minimum tire load (based on % of GAWR) the p metric in this size should have 32 psi. An LT should have a minimum of 38 PSI. Both are for on road application. Offroad is a different discussion.
bamma is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 12:44 PM #4
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
I have my c-range AT3Ws at about 40psi, they ride well there and chalk mark looked good
(which is a bit lower load capacity than stock but still well above gvwr, i think i needed a little over 45psi to match stock)
https://static1.1.sqspcdn.com/static...+inflation.pdf
jhguth is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 05:58 PM #5
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
36 psi when loaded and towing light camper. 32-34 psi unloaded...chalk test for both is good.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 06:02 PM #6
KKD989's Avatar
KKD989 KKD989 is offline
KKD989 will become famous soon enough
KKD989's Avatar
33psi on my 265 SL's
KKD989 is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 08:24 PM #7
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
37 psi when warmed up to operating temp. Chalk tested
265s
Wearing very even
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 08:43 PM #8
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
I ended up with 39 because I developed a slight shimmy but mostly street driven and perfect ride
Mudballz is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 08:53 PM #9
Mudballz's Avatar
Mudballz's Avatar
Old 02-26-2020, 09:28 PM #10
DenverTiger504's Avatar
DenverTiger504 DenverTiger504 is offline
DenverTiger504 is on a distinguished road
Smile
I have been running the same size in SL for the past 3 weeks. Started at 38 and worked my way down to 32. 32 cold has been perfect on the road and driving around town at stock weight. I will probably bump it up to 35 on road trips with a loaded rig.
2016 Trail | KDSS | Bilstein 6112 2.7” | Eibach Pro-Truck Rear Shocks and 1” Springs | 285/70/17 BFG KO2 | SPC UCAs
DenverTiger504 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 02:04 AM #11
Just wanted to report back on the 265/70/17 SLs. 32 PSI set cold around high 30s/low 40s outside has been overall great for a empty stock weight rig on street roads. It’s subjective, but I think it’s smoother than the LT KO2 by a good bit. I occasionally do get a little vibration before they warm on the highway commute - not sure if psi related or balancing. I haven’t felt the need to mess with the psi as I did before at higher psi’s. I do think every rig is different and the moment I have more weight in or on the truck I will need to adjust.
falken , figure , pressure , running , wildpeaks
For daily drivers who've gone through a set of Falken Wildpeaks Scaiza General Discussions 27 05-27-2020 07:38 AM
Falken Wildpeaks 265/70/17 Vegas markie671 For Sale: Suspension/Wheels/Tires 0 08-08-2019 08:49 AM
No Falken Wildpeaks in 275/70-17? Or go with 285? 3s1kill 5th gen T4Rs 22 03-16-2018 08:27 PM
Which Falken Wildpeaks ATW3 to buy 3s1kill Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-20-2018 06:01 PM
Happy with my Falken Wildpeaks kbach 3rd gen T4Rs 13 10-06-2012 02:51 PM
