Old 02-19-2020, 03:53 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Prinsu Snowboard Rack
Anyone on here mount a snowboard rack onto your Prinsu? I'm in the market for a snowboard rack and not sure if they're compatible for the Prinsu. Any pictures of existing setups are greatly appreciated.
Chilow is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 04:16 PM #2
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Im pretty happy with my setup and glad it came out low profile. Links to the products are below.
FatCat 6 EVO
SmarT-Slot Kit 2 - Snow - Activity
Only notes are that the bolts included in the smart slot kit do need minor modification of the heads to fit inside the groves of the prinsu slots. After that you just bolt up and go. Due to the low profile nature of this setup I needed to remove two of the crossbars (see pics) so that I could throw snowboards in upside down. Otherwise the bindings and bars will make it very hard to close the rack.
Prinsu Snowboard Rack-img_1567-jpg  Prinsu Snowboard Rack-img_1568-jpg  Prinsu Snowboard Rack-img_1569-jpg
El Dusty is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 10:28 PM #3
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Yeah I have an old Yakima one that I removed the mounts off of, and used a 1/4-20 bolt in a tnut in the rail. This made the snowboard rack completely flush with the crossbar and low profile.
You can also just use the clamp mounts that come with, as the crossbars will work just like OEM crossbars.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 05:58 PM #4
Gingahrunnah's Avatar
Gingahrunnah Gingahrunnah is offline
Gingahrunnah is on a distinguished road
I’m curious how you altered the t-nut... I have this for my ski rack but ended up going with the clamp setup because the t-nut wouldn’t fit in the slots. I’m using the Victory 4x4 rack.
The clamp system took me a while to install and the t-slot system is not only lower profile, but much easier to set up IMO.
Did you also have to alter the spacers? Mine have tabs that look wider than opening on the rack.
Gingahrunnah is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 12:29 PM #5
El Dusty's Avatar
El Dusty's Avatar
That is correct. I trimmed the rectangular spacer tabs off completely.
My kit came with t-bolts not t-nuts and did need modification. If you hold up the t-bolt head to the profile of your slot you can get an idea of the material that needs to be removed. I trimmed mine with an angle grinder/cutoff wheel. Grind, test fit and repeat until you have a good fit.
It’s a bit of extra work to fit it just right but the connection to the rack is stout. I never have been a fan of the strap on connections and I really don’t think they are intended for the wide rectangular shape of these racks.
Old 03-02-2020, 11:05 PM #6
Thanks for the details. I’m holding on to my t-bolts (misspoke before) in hopes I get access to the correct equipment to alter them.
greatly , mount , prinsu , rack , snowboard
Snowboard Rack Recommendation for Stock Roof Rack petenthend 5th gen T4Rs 4 12-18-2012 07:39 PM
snowboard rack. goodlooking4runner General Discussions 4 12-19-2011 06:31 PM
Which Snowboard Rack Should I Get? MSBX4RUNNER 4th Gen T4Rs 34 01-10-2011 11:36 PM
Snowboard Rack bobbyavidity 4th Gen T4Rs 8 07-26-2009 08:44 PM
07' Ski & Snowboard Rack bigdogxv Engines / Suspension / Wheels / Tires / Audio / Accessories 6 10-16-2008 12:12 PM
