Old 02-21-2020, 11:02 PM #1
apache67 apache67 is offline
apache67 is on a distinguished road
License Plate Screws
Hi Guys,
Having an issue with some rusted license plate screws (rear ones).
Question: do these screws protrude enough to double-nut them from the backside (inside of hatch) in an attempt to remove them?
Assuming they do, how do you get the plastic assembly off of the rear hatch? (simple or a PITA?)
TIA!!
G
apache67 is offline   Reply With QuoteReply With Quote
Old 02-22-2020, 12:06 AM #2
Attached screen capture:
Are the two bolts (circled in cyan) the license plate holder nuts/bolts?
License Plate Screws-screen-shot-2020-02-21-9-01-41-pm-jpg
Old 02-22-2020, 12:48 AM #3
spartacus's Avatar
spartacus's Avatar
I've never taken mine apart so no help their but jugding by the pic it's the disassembly writeup @Trail Runner and it shows how to take trim off the liftgate.
5th Gen 4Runner Mods - Step-By-Step Rear Hatch Trim Removal
Old 02-24-2020, 02:12 PM #4
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
I just dealt with this on my 2012. I hit them with some rust buster and then use a pair of vice grips to grab the head - it can be done- and give them a couple slight turns in both directions. Then screwdriver got them out.
Good luck.
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 02:39 PM #5
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
Looks like you're probably right. I would think the nuts for the license plate mounts would be welded on like the ones shown in your picture circled in blue. This is actually one of the reasons I swapped out my license plate bolts with titanium ones. Good luck !
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 02:42 PM #6
WISluggo WISluggo is offline
WISluggo is on a distinguished road
Link to these Ti bolts?
WISluggo is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 03:07 PM #7
anomalous's Avatar
anomalous's Avatar
I went with these, but you can go with any M6x20mm bolt
4X M6X12 M6X15 M6X20mm Titanium Bike Motorcycle Allen Button Head Bolt Ti Screw | eBay
I also went and replaced the fasteners on the Baja Design foglights over to titanium. They were unfinished, so I polished them up, and heat anodized them to a bronze finish
License Plate Screws-s-l1600-jpg  License Plate Screws-image-jpg
Old 02-24-2020, 03:27 PM #8
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
Good luck.
X
Happened to me too. Also heating the screws a bit w/ a heat gun helped.
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 03:40 PM #9
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping will become famous soon enough
This doesn't help with your predicament at the moment but I used these to prevent that issue: https://www.amazon.com/gp/product/B07QWM86GX/
Black nylon so no issue of ever rusting. Plus I didn't want anything shiny.
Gonecamping is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 04:41 PM #10
drewsro's Avatar
drewsro drewsro is offline
drewsro has a spectacular aura about drewsro has a spectacular aura about
drewsro's Avatar
This is a reason I like a lot of the American car companies. I work around cars everyday and trying to get those seized license plate screws out is pain in the arse. With American cars, it's usually just coarse threaded screws into a plastic square.
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 05:52 PM #11
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Mine had nylon screws. Both of them snapped off when I tried to remove. I drilled out the center of the nylon machine screws and replaced with stainless screws.
Old 02-24-2020, 06:18 PM #12
PJSnow's Avatar
PJSnow PJSnow is offline
PJSnow will become famous soon enough
PJSnow's Avatar
My previous vehicle had nylon screws from the factory. Heads sheared off when I was trying to remove the dealer license plate frame. Drilling them out was a PITA. Never touching plastic screws again.
PJSnow is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 02:38 PM #13
larrylegend larrylegend is offline
larrylegend is on a distinguished road
I also had this issue and replaced mine with Stainless Steel screws to avoid further rust issues. If you live in a salt prone area, I would suggest being proactive in replacing your screws before they become seized and a real pain in the butt to remove, as occurred on my 1999 4Runner.
1999 - Ltd. - Deckplate, 265/75/16 Goodyear Duratracs, Removed Running boards, hurculined entire interior, more to come...
2015 Trail Premium - S.S. Sliders...
larrylegend is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 08:34 PM #14
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
I used 18-8 Stainless Tamper Proof Torx screws from McMaster Carr.
M6x1.0, 16mm long
McMaster-Carr
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 05:18 AM #15
Deaone123 Deaone123 is offline
Deaone123 is on a distinguished road
Replaced mine with plastic screws, also noticed my rear plate lights screws were resting replaced those with stainless steel
Deaone123 is offline   Reply With QuoteReply With Quote
hatch , license , plate , rear , screws
Dagnabit -- License plate light screws chester4Run 5th gen T4Rs 9 10-05-2023 10:57 AM
Ughhh- rusted license plate light screws Hapeacres 4th Gen T4Rs 12 11-20-2020 08:28 PM
License Plate Screws/Bolts MaliciousClout 4th Gen T4Rs 11 06-30-2018 11:37 AM
need some help - license plate screws stuck theliman Maintenance/Detailing 8 01-09-2014 06:50 PM
Repair Bumper Holes (license plate screws) jpless Maintenance/Detailing 2 05-13-2010 06:55 PM
