Old 02-28-2020, 05:38 PM #16
tackindy tackindy is offline
tackindy is on a distinguished road
I have one of those Taco Tunes plug and play wire kits for the 2019 4runner if anyone is interested. New never used.
tackindy is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 06:25 PM #17
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
Originally Posted by 4xColt View Post
Thanks for the reply. I just ordered Focals for the rear doors so if I go EOM+ it would be the System 500 kit.
I just ran into a possible issue with the Alpine PSU-300FRN. I believe it may not work with "Premium Audio" that comes with the ORP.
Bummer
may want to double check that the 2020 radios have the same pin outs as the 14-19.... if not there may not even be a viable solution for you.
depending on what you are looking for, you focals should sound great.
For amps, if I had to do everything all over I would get the AudioControl LC-6.1200. I already had a lc7i and a rf prime 300.4 so i just bought a rf prime 500.1d. For ease of installation, a LC-6.1200 would have eliminated the need for all 3 and much smaller footprint (dimensions: 12"W x 2-1/8"H x 8-1/16"D). I had to run power, ground, distro blocks, 3 rca, signal wires from radio, speaker wires to new speakers, amps under 2 front seats.
for subwoofer, you can always use the stock enclosure and an upgraded 8" woofer (Alpline or JL). Wont be super boomy, but fills the void nicely. $180 for enclosure and 150-$200 for a sub. Only issue I am having right now is the panel cover I will have to make to fill in the pocket voids.
shdw03 is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 10:43 PM #18
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
Someone asked if they ever have discounts, the answer is yes, as I got mine at a discount ($200 off) but it was for Black friday.
rob_dixon is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 10:48 PM #19
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
Hey guys,
I have a few questions about OEM Audio Plus. I am exclusively looking for plug and play kits that are made for the 4runner.
Currently I have Focal components up front but I am still in the need of a subwoofer. In a 2 minute conversation with my wife where I mentioned that I had two choices that I was considering. Alpine under the seat or a subwoofer "built in" to the back. She basically said "I don't want to have a subwoofer "thumping" under my seat." So OEM Audio it is.
I am considering either the full kit or just the sub and keep my Focal and eventually pick up some Focal 6.5 for the rear doors and maybe... the rear hatch. Either way I will be getting the $299 dedicated subwoofer amp with gain control.
So here are my questions:
  1. Do you think or even know based on experience that the Focal would sound better than the EOM audio components?
  2. Since the system comes with a DSP dialed in for their solution, would my Focals throw it out of balance?
  3. Would it even make a difference on which speakers I use as long as I am adding an amp and a subwoofer with a dedicated amp?
  4. Does anyone out there have the full OEM Audio setup live in San Diego?
  5. Are the cables and amp they provide and standard connection? In other words, if one of the amps dies can I replace it with any other unit?
Thanks
Colt
Colt,
i have been using the OEMAudioPlus 500Q Reference system with full speaker package. I receommend giving a call to Daniel De Blanc @ OEMAudio plus. He will give you the right advice based on what you already have. The Focals you already have are a great set and well praised. so (A) I recommend that you also put Focals in the middle row and the trunk gate - that is if you decide to go with OEMPlus middle package (DSP/AMP, Harness, Sub) that is listed on their site for $1299. or (B) you sell the Focals you have and get a complete package from OEMAudio for $1699 and replace all speakers. going back to your question about plug and play.... yes OEM if full plug and play regardless of the option you go with. I'm not sure if I answered all your questions but one thin i can say is it is great setup. I use it with Hi-Res player with external DAC fed to the main using via AUX,,, and the results are simply the best.
and BTW the OEMAudioPlus sub will only work with their setup, so if you go with any alternative setup (replace the rest of the speakers) then you would have look for under the seat sub option or build a dedicated sub box in the trunk and find a way to feed an ampler line single to it.
it all depends on your budget after all. if money is no issue then stay with OEM+
niadh0 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 05:05 AM #20
JeffB JeffB is offline
JeffB is on a distinguished road
Looks awesome
Originally Posted by DryHeatAZ View Post
Not bashing on OEM Audio at all. But was curious if you considered having a local stereo shop quote you on a complete sound system with a custom sub enclosure? I went that direction after reading about the bass not living up to expectations for some and them wanting to add a second sub on the OEM audio setup. Seems that if you had a good 5 channel amp/components/sub enclosure and DSP you could exceed what the plug and play package gives you without needing to consider upgrading the bass. My sub enclosure is small and out of the way and honestly it's overkill for what I had in mind but sounds amazing.
Considering mounting a D-ring on it so I can use the cargo net.
Is that a 10 inch sub? All wood no fiberglass? Love it!
JeffB is offline   Reply With QuoteReply With Quote
Old 07-01-2022, 08:52 AM #21
osugsxr osugsxr is offline
still have the wiring?
amp , audio , focal , oem , subwoofer
Audio Questions - Amp install Wifes_PreRunner 5th gen T4Rs 4 08-14-2018 12:55 AM
Audio Questions.. jstim 3rd gen T4Rs 27 10-20-2014 10:23 AM
Questions on audio 03ToyotaFlo Engines / Suspension / Wheels / Tires / Audio / Accessories 7 10-01-2009 04:29 AM
several audio questions. cotir2005 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 09-03-2008 06:50 AM
Audio questions thomasiii Engines / Suspension / Wheels / Tires / Audio / Accessories 8 11-28-2007 02:32 AM
