Old 02-23-2020, 03:03 PM #1
4xColt 4xColt is offline
4xColt will become famous soon enough
OEM Audio Plus Questions
Hey guys,
I have a few questions about OEM Audio Plus. I am exclusively looking for plug and play kits that are made for the 4runner.
Currently I have Focal components up front but I am still in the need of a subwoofer. In a 2 minute conversation with my wife where I mentioned that I had two choices that I was considering. Alpine under the seat or a subwoofer "built in" to the back. She basically said "I don't want to have a subwoofer "thumping" under my seat." So OEM Audio it is.
I am considering either the full kit or just the sub and keep my Focal and eventually pick up some Focal 6.5 for the rear doors and maybe... the rear hatch. Either way I will be getting the $299 dedicated subwoofer amp with gain control.
So here are my questions:
  1. Do you think or even know based on experience that the Focal would sound better than the EOM audio components?
  2. Since the system comes with a DSP dialed in for their solution, would my Focals throw it out of balance?
  3. Would it even make a difference on which speakers I use as long as I am adding an amp and a subwoofer with a dedicated amp?
  4. Does anyone out there have the full OEM Audio setup live in San Diego?
  5. Are the cables and amp they provide and standard connection? In other words, if one of the amps dies can I replace it with any other unit?
Thanks
Colt
2020 Runner TRD Offroad Premium w/KDSS and Moonroof | RSG Sliders | TRD Pro Rims | BFG KO2s | Hikari Ultra (Low and High) | Toyota OEM Black LED Fogs | Focal IS 690 with EOM audio tweeters | Focal IC 165 | OEM Audio Plus System 500 with Dedicated Sub Amp
4xColt is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 05:58 PM #2
4powells 4powells is offline
4powells is on a distinguished road
Following.
Sent from my HD1907 using Tapatalk
2020 TRD ORP Silver - Currently Stock
4powells is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 02:31 PM #3
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I used a harness from tacotunes to add a small powered sub in mine. That and infinity speakers in all the stock locations and I'm quite happy. Worlds different than stock.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 02:42 PM #4
Whippersnapper02's Avatar
Originally Posted by 4xColt View Post
Hey guys,
    Honestly don't know but have been thinking about using different dash speakers
    The DSP is definitely optimized for their drivers. They use about 6 microphones and noise to calibrate. I'd ask them about it but I'm thinking they will tell you to use their drivers.
    I think it would just matter on the DSP side. I'm not sure what their amps out out for power.
    I'm in Yorba Linda pretty close to OEM Audio but if I'm ever in SD I'll let you listen.
  5. Is the cable and amp they provide and standard connection? In other words, if one of the amps dies can I replace it with any other unit?
    Their wiring is proprietary but it would be easy to splice. They are using speaker level signal not line level.
Thanks
Colt
Answers are in bold.
Old 02-24-2020, 09:52 PM #5
Thanks for the reply.
How's the bass from the sub and do you have the dedicated sub amp?
Old 02-24-2020, 10:01 PM #6
gakattack gakattack is offline
gakattack will become famous soon enough
To add to this question, are you running the single or double sub option?
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
gakattack is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 11:15 PM #7
Another question.
Does OEM Audio Plus ever offer discounts? If so, how much have you seen?
Old 02-25-2020, 03:28 AM #8
Yes I have the dedicated sub amp. It's good 90% of the time but I wish it had more. I purchased because I heard the dual system in person and it sounded damn good. I'm waiting for the 2nd sub to become available for current owners but in June it will be a year since I purchased and I haven't heard anything. All you get is "we're working on an upgrade path for current owners."
Old 02-27-2020, 11:21 PM #9
Here's an odd question for those of you with the OEM Audio Plus sub.
Can you still use a cargo net that goes across the back?
OEM Audio Plus Questions-net-jpg
Old 02-28-2020, 12:15 AM #10
I have the net and never used it. You do lose the corner tie down points. Does the net use those?
Old 02-28-2020, 07:19 AM #11
FoRunnuh FoRunnuh is offline
FoRunnuh is on a distinguished road
Based on the photos on OEM Audio + website, you do lose the driver side D-ring for the single subwoofer system. Also based on their pics/videos if you get the second sub, that D-ring is gone too. This is kind of a shame. Although more complicated to work around, they could have taken that into consideration.
FoRunnuh is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 10:55 AM #12
DryHeatAZ's Avatar
DryHeatAZ DryHeatAZ is offline
DryHeatAZ has a spectacular aura about DryHeatAZ has a spectacular aura about
DryHeatAZ's Avatar
Not bashing on OEM Audio at all. But was curious if you considered having a local stereo shop quote you on a complete sound system with a custom sub enclosure? I went that direction after reading about the bass not living up to expectations for some and them wanting to add a second sub on the OEM audio setup. Seems that if you had a good 5 channel amp/components/sub enclosure and DSP you could exceed what the plug and play package gives you without needing to consider upgrading the bass. My sub enclosure is small and out of the way and honestly it's overkill for what I had in mind but sounds amazing.
Considering mounting a D-ring on it so I can use the cargo net.
2020 SW ORP wrapped in KPMF Chalk White - SCS BR6 -38 with Yokohama Geolandar M/T's, OEM Pro garnish/upper grill, Black out emblems, Sprint Booster, ICON Stage 7 components, , Avid rock sliders, JL Audio system, TRD skid plate, TRD CAI, GOBI stealth, C4 Low Pro w/Warn EVO and High clearance add-ons.
DryHeatAZ is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 02:09 PM #13
keyser_soze's Avatar
keyser_soze keyser_soze is offline
keyser_soze is on a distinguished road
I have not heard the alpine specifically, but i have heard other under seat subs. They really aren't that powerful, so they aren't going to be giving her a massage just because it is under her seat (I believe this would fit under the driver seat as well FYI). I don't recommend an under the seat sub for the simple fact that most of them don't sound that great. You also wont be getting the added amp power and DSP tuning of the OEM Audio for your Focals which will make them sound much better as well.
Honestly unless you frequently have rear passengers I would skip upgrading the rear and hatch speakers, you will not notice anything from the drivers seat. Ideally you would fade the sound forward a bit and just use the rear speakers for "fill". And if you want music while camping, tailgating, at the beach... get a portable speaker.
Do you think or even know based on experience that the Focal would sound better than the OEM audio components?
Focal is a large and established company that makes high quality drivers. Im not sure where their "toyota" speakers fall in their lineup quality wise but I would guess they are on par with OEM Audio
Quick answer: No. I believe their DSP is tuned more to fix the crappy EQ of the OEM Toyota signal (it tapers down the lower freq to save the OEM speakers). They even sell their "System 500" kit without their speakers so you can use it with the OEM Toyota speakers (or aftermarket) and I believe it would be fine.
Not really, as long as they are typical car audio speakers in the 2-4ohm range you should be fine. The OEM audio speakers are 2ohm (4ohm tweeters) all rated at 50w RMS. Their amp just says 360w RMS @ 2ohms, bu that also powers the 100w sub, so I would guess it is around 60-70w RMS x4. That would be fine to power most aftermarket speakers (and MUCH better than the factory Toyota amp)
So after all that rambling.... You said you want a plug and play solution. I think OEM Audio is the way to go. I think it boils down to two options.
1. You could keep your Focals and get the "System 500 kit" for $1600.
2. Get the full "Refrence 500 kit" for $2100 and sell your Focals to offset the price.
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
keyser_soze is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 05:14 PM #14
Good idea. I will probably drop by a local shop just to see what they can do.
I just ordered the rear Focals so all I will eventually need is a sub and amplification.
Thanks for the idea.
Old 02-28-2020, 05:17 PM #15
Thanks for the reply. I just ordered Focals for the rear doors so if I go EOM+ it would be the System 500 kit.
I just ran into a possible issue with the Alpine PSU-300FRN. I believe it may not work with "Premium Audio" that comes with the ORP.
Bummer
amp , audio , focal , oem , subwoofer
Audio Questions - Amp install Wifes_PreRunner 5th gen T4Rs 4 08-14-2018 12:55 AM
Audio Questions.. jstim 3rd gen T4Rs 27 10-20-2014 10:23 AM
Questions on audio 03ToyotaFlo Engines / Suspension / Wheels / Tires / Audio / Accessories 7 10-01-2009 04:29 AM
several audio questions. cotir2005 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 09-03-2008 06:50 AM
Audio questions thomasiii Engines / Suspension / Wheels / Tires / Audio / Accessories 8 11-28-2007 02:32 AM
