Old 02-23-2020, 06:14 PM #1
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about scratchhax has a spectacular aura about
Easy fix for firewall grommet leaks
When I ran all of the wires through the large grommet in the firewall for switches, I didn't know about the way that water can flow over it and leak into the cab (as you can see from the water spots in the picture), So it did. As soon as the the weather warmed back up I grabbed a couple of packets of Sugru and molded it around the hole. After 24 hours it sets to a nice silicon plug and I'm back to being leak free.
You can make your own if you don't want to buy sugru by mixing silicon caulk (not silicon II, pure silicon caulk) and cornstarch called oogoo.
Hope this helps someone
scratchhax is offline   Reply With QuoteReply With Quote
Old 02-23-2020, 06:58 PM #2
emupoacher emupoacher is offline
emupoacher will become famous soon enough
Thanks for sharing both the method you used and a good alternative. Looks like a solid/quick fix. Cheers!
emupoacher is offline   Reply With QuoteReply With Quote
back , caulk , leak , silicon , water
Passing and Wiring Switch Through Firewall Grommet, How To blacksheep4 5th gen T4Rs 23 03-19-2020 06:08 PM
Passenger side firewall grommet 4x4mike 4th Gen T4Rs 0 11-25-2019 01:44 PM
Firewall grommet plug arehman11 5th gen T4Rs 9 03-26-2019 01:15 AM
Firewall Plug/Grommet RobPolak 5th gen T4Rs 0 05-31-2018 02:34 PM
Adding Firewall Grommet harkco 5th gen T4Rs 5 01-24-2018 12:54 PM
