Originally Posted by Rack
I have to agree with the post above.
The 4runner is capable of towing 5000 lb Max. I personally would not push it to its limit. In Florida you don't have the Mountain passes like in the west. So you might be Ok.
Just keep in mind you will be adding your gear, cooking utensils. Maybe a kid or two this all adds up.
Sure you can add air bags, heavier suspension,Trans cooler $$$ and get the rig towing but you also have to stop it. Trailer brakes $$$ are a must. But the one thing that you don't have is wheel base.
I tow a lot, but not with the 4runner. I have a older K 2500 Suburban with a 454 cu in V8 that when towing gets 12 MPG at 70 MPH. and has a 42 gal fuel tank. I prefer Longer wheel base and heavier suspension and Larger Brakes.
At 10 to 12 MPG with the 4runner smaller fuel capacity you will not pass a gas station.
I see where your coming from trying to dual purpose your investment.
But to live in a trailer the size of what you might be able to tow in the 4runner is going to be a challenge.
You can Rent a larger trailer and have them put it in your driveway while your construction is going on. When your home is livable have them pick it up.
Then you can down size your trailer to match your 4runners towing.
I feel your pain, I'm having major construction done at my house as we speak,But I can still live here while its being done.
Unfortunately rental trailers are not available here so that’s why I wanted to invest into a small trailer. The one we are looking at is 3400lbs dry so outfitted it will be around 4000lbs. I have these crazy thoughts of using it for camping after we move in the house but that may fade after spending 60 to 90 days in a 160 sq/ft space with my lovely wife.
