02-24-2020, 12:01 PM
Dual Battery - Do I need it?
Yes, I read all the threads on dual battery setups. The engineer talk was above my level and I’m leaning towards a built kit. But reflecting on some comments about just upgrading the battery, do I really need a dual battery setup?
Daily Driver
-small Domatic Fridge that is only on full time when camping
-Lights (3 E-Series, 4 Duallys, 2 Cyclones, 1 Light Bar)
-Front Camera
-Winch
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
02-24-2020, 12:33 PM
you don't need it
depending on how often you go camping (i.e. how often your fridge is fully on) you might want to upgrade your starting battery to an AGM so it doesn't mind cycling as much, but AGM isn't without downsides so even that probably isn't worth it if you just need to run the fride for 8 hours a few times a year.
02-24-2020, 01:06 PM
Originally Posted by jhguth
you don't need it
What size AGM battery do you recommend? I’m slowly learning about the different sizes and the booster requirements.
Would a voltage booster be needed or a good safety net?
02-24-2020, 02:14 PM
I'm kinda on the fence about going dual too. I have a winch and would like to do some camping with the truck. Maybe a long road trip around the country as I've never been out west. But I use a c-pap... Thinking if I had a dual setup maybe I could wire the inverter to work all the time off the second battery for that, a small fridge, and have that dedicated pretty much to the winch also. I don't know. Probably don't need it but it would be nice. Of course it would be way cheaper to do such a trip on my V-strom anyhow. Battery pack that charges off a USB for the C-pap and just forget cold stuff. Way easier and probably more fun on the bike anyhow.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
02-24-2020, 02:20 PM
for me personally, heavy winching was the deciding factor for dual batteries.
assuming you wont need to do a lot of winching, you may not NEED it.
however, with extended trips away from civilization, its not a bad idea. for JUST IN CASE.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
02-24-2020, 08:14 PM
Size just depends on what capacity you want, 1 Ah/h is a good rule of thumb for fridges but if you have a small fridge you may be 0.75Ah/h or less. At its highest voltage shutoff, my 110Ah group 31 battery will run my fridge for 2-3 days in summer, on the medium voltage shutoff I get about another day and the vehicle will still start I just dont like cycling 5he battery that low unless I have a specific need to.
The arclightled charger is what I use, its probably the best option. I also have an HKB and Ebay booster but use the ArcLight.
I run a single 31m, the downside is with a 31m you need to upgrade your battery mount but the positive is i have 110Ah capacity which at the highest voltage shutoff will run my fridge for 2-3 days.
(I run my fridge 24/7 so AGM is worth it for me. My stock battery lasted about 6 months of running my fridge 24/7 before it started dying)
02-24-2020, 08:32 PM
Real Name: Weston
Real Name: Weston
I had a National Luna system in my 3rd gen and loved it in principle. But for my 2019 I think I'm going with the Goal Zero Yeti link kit which basically allows you to charge their bigger power stations while driving. Portable, rechargeable power that is much easier to implement.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
02-24-2020, 09:16 PM
You dont need one.
You DO need a dual purpose / deep cell battery, a good one like this.
Pick one up @ batteriesplus
I'm on my 4th year with mine. Cells tested 3 weeks ago and are still good. Been through -0F degree +100F weather, no issues. Plus it sat for a little while too. I run ARB Fridge 24hrs while camping for a few days, Winch, lights, hids, etc.
2016 TRD Pro (MGM) / OME BP51's / Heavy Duty OME Springs / JBA UCA / ARB Safari Snorkel / SSO Slimline Hybrid Front Bumper w/Rigid Industries LED Light Bar / Smittybuilt Winch / ARB Fridge / Firestone M/T2 285-70-17 / C4 Fab Rock Sliders / Rago Ditch Brackets w/Baja Design Ditch Lights / RCI Skidplates (All) / aFe power MACH Force-Xp 2-1/2" 304 Stainless Steel Cat-Back Exhaust / Sprint Booster. flickr Noisia Radio
02-24-2020, 09:50 PM
Originally Posted by propain
You dont need one.
Did you have to change the battery terminal?
02-24-2020, 10:09 PM
Nope.
02-24-2020, 10:28 PM
Nice, I got a Yeti 400 from “Santa” so I’ll need to pick up a link kit.
02-24-2020, 10:52 PM
You don't need dual battery for a cpap, run the cpap on DC instead of with an inverter and they dont use much power (the humidifier function will, but leave that at home or turn that off when camping)
Small, low cost battery packs can run a cpap for multiple days, or if you want flexibility to use it for more than the cpap get something like a rockpals battery pack
02-24-2020, 10:53 PM
Goal Zero everything is overpriced, there are better options on the market now
02-24-2020, 11:30 PM
Nope.
Looks like my local Battery Plus has them. Would you recommend the Group 24 or 31? I see you have 24 in your pic.
02-24-2020, 11:34 PM
24. Bonus it has a 5 yr warranty.
