Old 02-25-2020, 10:27 AM #16
15_T4R TRAIL 15_T4R TRAIL is offline
15_T4R TRAIL is on a distinguished road
Slightly off topic, but while we are on batteries.....what is the proper way to attach aux power off the positive cable? There seem to be 2 different nuts on the lugs. They both seem to work but i can figure out if i should mess with the top one or just add my power wire to the side/tightening lugs.
15_T4R TRAIL is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 11:00 AM #17
Krayziekid's Avatar
Krayziekid Krayziekid is offline
Real Name: Jake
Krayziekid will become famous soon enough
Krayziekid's Avatar
Real Name: Jake
Originally Posted by jhguth View Post
Goal Zero everything is overpriced, there are better options on the market now
What other brands would you recommend? Genuinely curious as I don't know much about these external batteries.
"Po" - '18 Super White TRDORP - Build Thread Here
"Sirius Black" - '03 Limited V8 Build (Sold) - Build Thread Here l 03->06 Headlight Swap Guide
My Photography // My Videography
Krayziekid is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 12:43 PM #18
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Jackery, Rockpals, etc...
The DIY Solar Power with Will Prowse channel has good reviews on batteries and solar panels:
YouTube
you should expect to pay about $1/Wh or less
I have a group 31 AGM and 100W solar panel on the 4Runner but still have a small Rockpals (300W 280Wh) for portability around the campsite and to run an apap
(Note for @85GT-79FJ40 if you get something for your cpap, make sure it doesn't turn off automatically. The Jackery will turn off the 12V DC port after a certain amount of hours if you aren't pulling enough watts, and most cpaps are below that watt limit so don't get the Jackery. The Rockpals doesn't do this, and can even be used in UPS mode which will just pass through power from 120V but automatically switch to battery if you lose power, good feature for cpaps if you live somewhere that loses power from storms or something. For camping run your cpap on DC, it uses a lot less power that way)
jhguth is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 12:58 PM #19
jmf_tracy jmf_tracy is offline
jmf_tracy is on a distinguished road
Originally Posted by OYOTA TRD View Post
Yes, I read all the threads on dual battery setups. The engineer talk was above my level and I’m leaning towards a built kit. But reflecting on some comments about just upgrading the battery, do I really need a dual battery setup?
Daily Driver
-small Domatic Fridge that is only on full time when camping
-Lights (3 E-Series, 4 Duallys, 2 Cyclones, 1 Light Bar)
-Front Camera
-Winch
Yes, you need it.
BLACK 2015 TRD PRO - SAFARI SNORKEL - GOBI STEALTH - TREK BOXX
ICON STAGE 7 (700 LB SPRINGS) - 285/75 R17 NITTO TRAIL GRAPPLER
MAGNUSON SUPERCHARGER - URD FUEL & TUNE UPGRADE
DUAL BATTERY - 250 AMP ALTERNATOR - COMEUP 9500 RSI
SCHROCKWORKS BUMPERS, SLIDERS & SKIDS - 4.56 GEARS
jmf_tracy is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 02:06 PM #20
MillerPKA's Avatar
MillerPKA MillerPKA is offline
Real Name: Weston
MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough
MillerPKA's Avatar
Real Name: Weston
Nice, I got a Yeti 400 from “Santa” so I’ll need to pick up a link kit.
Unfortunately I think it only works with the Yeti 1000 and higher.
Yeah the competition has really ripened the last year or two. I've always been a fan of GZ quality and reliability as I've used their units a TON over the last 4-5 years. Getting a new Yeti just to work with this link kit.
Daily Driver
-Front Camera
-Winch
I'd argue you don't need it. It's unlikely you'll be using most of this concurrently and a good single battery can easily handle the lights, camera, and fridge.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
MillerPKA is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 02:24 PM #21
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I always go for a dual battery. I like having the capacity, flexibility, and peace of mind… I do all my own design/electrical work and I like these types of projects so I don’t look at it as a huge cost or hurdle.
That said, over the years of running an efficient fridge like the ARB 50, I know I can get away with a lot less battery for weekend trips.
Portables are also worth considering. So is just adding a small ~50 watt solar panel and a charge controller to the truck to help maintain a single battery setup when sitting.
With a little DIY spirit you can take some small SLA batteries and an ammo can and easily make something that can run the fridge overnight. Add a solar charge controller and you have a budget Yeti
If all you are running is a fridge when the truck is off, you have a lot of options.
Old 03-06-2020, 12:09 PM #22
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Originally Posted by MillerPKA View Post
I had a National Luna system in my 3rd gen and loved it in principle. But for my 2019 I think I'm going with the Goal Zero Yeti link kit which basically allows you to charge their bigger power stations while driving. Portable, rechargeable power that is much easier to implement.
Have you looked at the new National Luna DC25 Power Pack? It's an isolator, DC-DC battery charger, MPPT solar regular, and portable power pack all in one. Allows you to throw any battery you want in there. I'm sure it won't be cheap but neither is GZ.
I have numerous Goal Zero products and while they are nicely packaged, well thought out, and work well within their own product lines the units themselves are often very limiting. Their battery tech is dated for the prices they charge. I know their 400W and even 1000W units are not running a regulated 12v output. So you can't run a 12V-DC fridge without purchasing an additional 12V regulated cable adapter for $40. You can run it off AC but then it'd be inefficient. I mean really, a 1000W lithium unit can't run a 12V DC fridge without power drops and the need of a $40 dongle? Seems like there's always a compromise and need to run adapters with the GZ kits and by the time you add it all up you spent a lot of money on a limited solar generator that's not even using LiFePO4 batteries.
I like some of their smaller portable battery packs that I can throw in my backpack but I think their solar generators are quite lacking.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
battery , domatic , dual , fridge , full
Dual Battery Vs. Portable Battery nick_rabbo 4th Gen T4Rs 29 05-23-2022 12:39 PM
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual Battery Planning, Dual Group 31s mikeySA 3rd gen T4Rs 10 11-04-2017 04:25 PM
Cheap Dual Battery, Battery! SirWilliamGoes General Discussions 21 05-30-2017 10:59 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
