Old 12-13-2020, 11:27 PM #61
Brancart675's Avatar
Brancart675 Brancart675 is offline
Brancart675 is on a distinguished road
Originally Posted by zasdds View Post
I ended up going through the main firewall gasket (not fun) and using the TAIL fuse in the cabin fuse box. Seems to be working fine for the past week. Not a true on/off switch but I like that they don't come on just with the ignition.
I ended up with this same configuration after trying several other spots both internally and in the engine bay fuse box. Honestly, I’m not sure there is an ideal fuse location but they seem to work the best.
Brancart675 is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 06:24 AM #62
49Runner 49Runner is offline
49Runner will become famous soon enough
Didn’t bother to read the entire thread but be advised while “cool” looking (which is a fair reason to have them) the lights the Raptor sports are required due to the width of the vehicle, the new RAM TRX will also have them. I drive an F250 work truck which isn’t wide enough to require them.
49Runner is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 01:13 PM #63
Dodgem37 Dodgem37 is offline
Dodgem37 is on a distinguished road
Installed these lights, look great but the add a fuse block height keeps the under hood fuse box from closing completely. This really bothers me, plus I worry about dirt and moister getting in. Thought about taking a heat gun and heating the cover and stretching it to make a "power bulge" to clear the block. I don't think I need more than 1/4". thoughts?
Dodgem37 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:08 PM #64
steraser steraser is offline
steraser will become famous soon enough
Personally, I would just buy one of the covers being made by folks on this site that allow for the use of the add-a-fuse. I don't know if it is linked in this thread but I am sure you can find it with a search.
steraser is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 05:29 PM #65
mattshi93 mattshi93 is offline
mattshi93 is on a distinguished road
Could you link the led you used to fin in the upper grille?
Originally Posted by Area52 View Post
So I managed to get the grand general LEDs in the top of the non-pro grill. They fit surprisingly well. The problem I’m running into is I can’t find an open fuse spot that’s not always hot. I tried both under the dash and in the engine bay. There is only 1 open spot under the dash now.
I remember on the ‘18 there were a couple. Everything I plug the add-a-fuse tap into by passes the ignition. Any advice?
mattshi93 is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 11:05 PM #66
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
I bought the Taco Vinyl Raptor lights and it appears as though I’m going to need to buy my own 10 amp fuse. Do you all know if I can buy any 10 amp fuse for the add a fuse or is there a specific fuse I need to buy?
Stephencovar is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 11:12 PM #67
StormTrooperTRDP StormTrooperTRDP is offline
StormTrooperTRDP is on a distinguished road
Did anyone confirm that putting the add a fuse in the KDSS fuse slot is safe? I have a trd pro so I don’t have kdss and was looking to add it here since my INJ fuse is already being used. Thanks!
StormTrooperTRDP is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 07:24 AM #68
PhillySilver PhillySilver is offline
PhillySilver is on a distinguished road
Looking forward to replies on this one. Tried to do this install on my truck yesterday and the add-a-fuse simply sticks up too far to allow the cover to close (as others have noted already). This is a total non-starter for me, no way my ocd stands for that. I would really like to have them off unless DRL, parking or headlights are on but that involves digging into wires which makes me very nervous without a wiring diagram.
PhillySilver is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 08:37 AM #69
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Look here:
https://www.toyota-4runner.org/3572851-post34.html
Raptor Lights 2020 4Runner-3ef5be14-b33a-4939-b68e-80a491cbdaf8-png
Best Regards,
Saker
Old 04-26-2021, 11:33 AM #70
WhiteMudhorn WhiteMudhorn is offline
WhiteMudhorn is on a distinguished road
I ran into this issue as well. They are low profile fuses. I didn't know that so I got Mini fuses.. they do stick up too high.. so I just cut them down.. Still high but works for now..
This is probably what you want:
Bussmann-BP-ATM-A6LP-RP-Profile-Assortment
I wasn't sure if it was safe to use with KDSS.. so I used the Tail one which should be tied to the parking lights.
I am printing out one of these: Free 2010-2021+ Extended Fuse Cover 3D Print Files
WhiteMudhorn is offline   Reply With QuoteReply With Quote
Old 04-26-2021, 11:23 PM #71
White mud horn, thanks. I called Toyota today and they had no clue about anything fuse relate....go figure �� Might call some electrical person to figure it out regarding the kdss. I’m going to wire it into the tail fuse until I get an answer. Will post my findings once I get someone who truly knows what that kdss fuse is used for on non-kdss rigs.
Old 04-27-2021, 11:04 AM #72
I believe I read on here that someone used that KDSS fuse before as well. But if you are using an add a fuse, it wouldn't really matter if you put it on the TAIL one or the KDSS..
These LED lights don't draw much amperage at all, it should not affect stock wiring.
Also the Tail one is tied to parking lights, so only on with Parking, and Low beam on. If you want it on all of the time then KDSS might be the better way to go.
Old 04-27-2021, 12:20 PM #73
Saker's Avatar
Saker's Avatar
If you use the Tail fuse location, as I did, once you turn the light stalk switch to parking, the Raptor Lights will stay on even low beam & high beam.
Remember, as long as the tail lights are on, you have power to your mod.
Best Regards,
Saker
Old 06-19-2021, 01:50 PM #74
Area52 Area52 is offline
Area52 is on a distinguished road
I used the KDSS fuse in my SR5p al be it with an add-a-fuse. I speculate Toyota just started to use the same fuse box for all models in ‘20+. I had an 18 previously, the fuse lay out is slightly different and that one had blank spots. In the 20 there are no blank spots.
Area52 is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 05:46 AM #75
DaveHNL's Avatar
DaveHNL DaveHNL is offline
DaveHNL is on a distinguished road
DaveHNL's Avatar
Originally Posted by BlueEyedDevil View Post
Anyone?
Was very simple, just open the loom, remove the insulation from the wires, solder/shrink tube.
DaveHNL is offline   Reply With QuoteReply With Quote
appreciated , info , plug , raptor , unsure
Has Anyone Tried These Raptor Lights? zw470 5th gen T4Rs 120 11-13-2020 11:52 PM
***SOLD*** 2020 Toyota 4Runner TRD Pro OEM LED Fog Lights | Los Angeles Area papadop88 For Sale: T4R Items 7 01-31-2020 11:04 PM
***SOLD*** Brand New - 2020 4Runner Stock OEM Tail Lights papadop88 For Sale: T4R Items 11 01-31-2020 12:54 PM
Raptor lights!! Lets see them! Zeke588 4th Gen T4Rs 5 03-08-2019 02:34 PM
