Old 06-13-2020, 06:41 PM #46
Area52 Area52 is offline
Area52 is on a distinguished road
I’d think you’d be fine. The only open spot on mine was any always on spot (I.e. lights would be on all the time regardless of if the ignition was on or not). So I tapped something else
Area52 is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 01:57 AM #47
kleffman13 kleffman13 is offline
kleffman13 is on a distinguished road
Thanks for getting back to me. I ended up changing it as for some reason the open spot caused my drl’s to not function so I used the acc port. Thinking about switching to my driving lights though so they are only on when they are. Thanks for all the help!
kleffman13 is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 09:55 AM #48
zasdds zasdds is offline
zasdds is on a distinguished road
I ended up going through the main firewall gasket (not fun) and using the TAIL fuse in the cabin fuse box. Seems to be working fine for the past week. Not a true on/off switch but I like that they don't come on just with the ignition.
2020 TRD Off Road Premium w/KDSS, Pro SEMA Wheels, Nitto Ridge Grapplers, Smoked LED Sequential Mirror Turn Signals, Suma Performance Mirrors with integrated LED Turns, GoRhino Tube Steps, Anytime BackUp/Front Camera, TRD Heritage Grill with amber marker lights, RAM Mount, Full interior/exterior LED swap, Accessorides Remote Start
zasdds is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 08:37 PM #49
TBTally TBTally is offline
TBTally is on a distinguished road
Originally Posted by steven350 View Post
false ... was able to follow a video on youtube, shows you if u remove a bolt, youll be able to install the wire to the fuse re-secure that bolt and then close the lid
Good job!
TBTally is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 08:41 PM #50
Originally Posted by DaveHNL View Post
I added a dimmer switch and tapped into the parking light wire.
I like the dimmer switch idea! Nice set up. I ordered a pair from Yota Led. Can't wait!
Old 08-06-2020, 08:03 AM #51
Aham182 Aham182 is offline
Aham182 is on a distinguished road
Originally Posted by Area52 View Post
What’s the general consensus on how to mount these on a regular non-pro grill?
I don’t know how some people are saying they don’t fit on non pro grills. My buddy has a 2016 trd off road and I have a 2018 sr5 and we both got the clip-in 4 lights off of amazon. They cost 40 bucks. Much cheaper than what running4tacos or other 4runner/tacoma dedicated websites are charging 80 bucks and that’s without shipping, not sure if they charge shipping or not but pretty sure they would. But they fit perfectly and clip right in, they might not lineup up to perfection but with a little moving around and pushing in, they will clip in. And just my opinion, if I had a 2020 non pro model, I wouldn’t put raptor lights on there. I think that line they added is enough and looks great but with the raptor lights it just makes the grill way to clustered and busy since these raptor lights are only for aesthetic purposes. They have no benefit besides people maybe being able to see you better coming down the road but that’s about it. That’s just my opinion though, I would leave the 2020 non pro models as they are.
Aham182 is offline   Reply With QuoteReply With Quote
Old 08-06-2020, 08:23 PM #52
Bombguy Bombguy is offline
Bombguy is on a distinguished road
2017 TRD Pro
Wired in my Overland Depot lights with no issues as an always on. So that part works fine.
But, like many others I would like to run a switch - in particular, I picked up one of the Rago press switches to fit the blank.
Problem is, I can't figure out (and Google and search aren't helping me) where to wire IT to - since I don't have a relay coming off the LEDs to hook into.
Has anyone worked with this? Or am I completely off base and just stuck with always-on?
Bombguy is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 09:31 AM #53
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Any info would be great!! I have a couple posts out with different vendors. Cannot find anything on you tube for the 2020 4runner. So I thought I would post here. Basically the same thing what I’m looking to do. I’m adding a bajadesigns led 20 inch light bar up top behind my grille. It will have 2 different wires one wire will go into my firewall to connect to my push button to turn the led bar on. My led bar will have the back lighting to be on which will be the other wire with a switch. I want to cut that wire and remove switch and add that wire into my fuse box for a add a fuse so it’s on when my DLR’s are on. Or when my headlights are on. But not sure which fuse to use. Anyone know which fuse to tap into. Thanks.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 12:56 PM #54
Justpassedu Justpassedu is offline
Justpassedu is on a distinguished road
Saw this for the 2020 w/raptor lights on youtube , hope it helps as I am going to try and wire mine the same way 2020 4RUNNER TRD PRO - Raptor Light Installation - YouTube
Justpassedu is offline   Reply With QuoteReply With Quote
Old 09-15-2020, 01:16 PM #55
Real Name: Don
Real Name: Don
Thank Dude!! I posted to Chris on his video to see if he knows if it makes a difference. I don’t think it will. But checking with different answers to see what others have done. It’s the 2020 fuse box that’s different just want to make sure. Yeah I can just go pay someone to do it but rather save myself money and do it myself. My led bar I had in my Tacoma did not have a back lightning so I did not have to worry about that. I was going with Raptor lights but now I will sell them. I have a brand new set I did not post yet. I’m putting my led bar in the place top grille where the raptor lights would go. Thank you.
Old 09-15-2020, 02:10 PM #56
yw lmk how it goes , I was just going to wire mine like the video so they are always on. I don't think they put out much light to matter really and I only paid like $40 off amazon for the Seven sparta set, I have yet to install them though as I am waiting on a grille to arrive for the 2020 4runner that they will fit.
Old 09-18-2020, 02:25 AM #57
Sr. Runner Sr. Runner is offline
Sr. Runner is on a distinguished road
Has anyone found a spot for the 2020 fuse box that’s in the cabin near the e brake? I wired mine to the ACC fuse, anyone know if that’s okay to do, despite it being a 7.5 fuse in it originally? This keeps the light on once you turn the key once/radio on. If there is another safer way please let me know.
Sr. Runner is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 03:27 AM #58
JsinLegacy's Avatar
JsinLegacy JsinLegacy is offline
JsinLegacy will become famous soon enough
JsinLegacy's Avatar
Believe you have to plug it trail slot.
JsinLegacy is offline   Reply With QuoteReply With Quote
Old 09-18-2020, 06:49 AM #59
DuffyT4R DuffyT4R is offline
DuffyT4R is on a distinguished road
I installed these a couple weeks ago and had great luck with running the wires through the firewall and using the add-a-fuse in the "tail" fuse of the box next to the E-brake. Now they only turn on when my lights are on which is what I wanted. Hope this helps! it was super easy.
PS, I used the Seven Sparta kit off Amazon and fit and finish was excellent!
2020 MGM PRO | iDrive | Wescott Designs | Falken Wildpeak 285/70r17 | Spidertrax | Prinsu | RCI | AlphaRex | DD SS3 Pro |
DuffyT4R is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 08:58 PM #60
NewToToyota2020 NewToToyota2020 is offline
NewToToyota2020 is on a distinguished road
I've got a 2020 that I installed these lights on. I used the INJ fuse first, but the fuse box cover didn't fit plus I don't want the lights to turn on everytime I start my engine. I want them to turn on when my running lights are on, just like they are on my Ford Raptor. I've plugged them into the H-LP RH-LO 10A fuse and they work when I turn my headlights on, no problem. I really want to find the fuse that operates the running lights only and to plug into that one so I don't have to have my headlights on to run them. Does anyone know which fuse operates the running lights alone?
NewToToyota2020 is offline   Reply With QuoteReply With Quote
appreciated , info , plug , raptor , unsure
Has Anyone Tried These Raptor Lights? zw470 5th gen T4Rs 120 11-13-2020 11:52 PM
***SOLD*** 2020 Toyota 4Runner TRD Pro OEM LED Fog Lights | Los Angeles Area papadop88 For Sale: T4R Items 7 01-31-2020 11:04 PM
***SOLD*** Brand New - 2020 4Runner Stock OEM Tail Lights papadop88 For Sale: T4R Items 11 01-31-2020 12:54 PM
Raptor lights!! Lets see them! Zeke588 4th Gen T4Rs 5 03-08-2019 02:34 PM
