Old 01-14-2021, 07:55 PM #16
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
Originally Posted by Chilow View Post
For those who just sucked the old fluid out and refilled with new fluid, did you rotate the steering wheel in both directions a few times to push out more fluid in the lines or is that not necessary?
Is there a bleeding process for this or simply suck out fluid and replace it. Make sure the fluid level is at the appropriate hot min line?
This is how I plan on doing it: Absolute BEST Method To Flush Power Steering Fluid!! - YouTube
Here's my fluid guide: Beginner Fluid Maintenance
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 08:53 PM #17
1000MPH's Avatar
1000MPH 1000MPH is online now
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
The first time I did the turkey baster I cycled the fluid by winding the wheel a couple times. I did this 4-5 times and only used about 1/2 qt. It is time consuming. Sucking out the res only gets 3-4oz. I could have pulled the return line but didn’t have a way to plug the res at the time.
Since then I just suck the reservoir every time I change the oil. Working well so far. I use the M1 Dexron III but I would have no problem using Max-Life. I’ve finally used a qt of fluid over the past 4 years.
1000MPH is online now   Reply With QuoteReply With Quote
Old 01-14-2021, 09:23 PM #18
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Update for anyone that's interested.
I double checked the fluid I'm using, and it's Dexron 6 compatible....after lots of reading, Dexron 6 is supposed to be backwards compatible with 2 and 3.
I did another drain and refill over the summer, and last week did 2 more. Each time it was a short drive to get turns lock to lock and circulate as much fluid as possible.
Smooth like butter now. No leaks.
I'll repeat every 25-30k miles from here on out.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 12:19 AM #19
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
PS oil is the easiest fluid change ever! I could do it every year and its cheap.
1jzgte is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 12:49 AM #20
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Originally Posted by DougEFresh2 View Post
This method is how I change PS fluid. Engine off, no mess. It's thorough. I put the front tires in the air to make it easy.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 09-03-2022, 03:23 PM #21
cheeser cheeser is offline
cheeser is on a distinguished road
Just used this method as well…fairly easy and mess free with the right hose to a drain pan. I wasn’t sure at first which line was the return side, but assumed it was the smaller top most line running to the PS fill plastic container…was correct. I went through about 1.5 qts to flush / fill.
2023 SR5 Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
cheeser is offline   Reply With QuoteReply With Quote
Old 09-03-2022, 05:13 PM #22
correct.. return lines are typically on top... transmission cooler, ps fluid, oil cooler, etc etc.. fluid is pulled from the bottom hoses because of air bubbles and so on that could cause a disruption in the flow of fluid within the hoses. Gravity is more reliable than mechanical/electronic pumps and bubbles should rise to the top before making it into hoses.
5th , fluid , harm , manual , yadda
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
Tranny fluid change...which fluid? wm69 3rd gen T4Rs 3 02-12-2008 01:11 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
