Old 02-26-2020, 10:34 AM #1
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
5th gen PS fluid
So along with all the other fluids I like to do a siphon & refill on the power steering fluid periodically. Would like to do a little brain pickin' here for those that've got a bit more technical savvy or have already done this --
Previous gens allowed/specified transmission fluid to be used for the PS, but I see a different spec in the manual for my '15.
Any harm in using trans fluid, assuming I can get all or most of the old fluid out? My thought is that it is a hydraulic fluid with cleaning properties yadda yadda.
Appreciate any insight/experience/commentary.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:44 AM #2
Crashnrondo Crashnrondo is offline
Crashnrondo is on a distinguished road
My 2010 said Dexron 3 right on the cap, does your cap say something different?
2010 SR5 4x4--5100's @ 1.75" + 1.5" Daystar rears
Crashnrondo is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:50 AM #3
The Waco Kid's Avatar
The Waco Kid The Waco Kid is offline
The Waco Kid will become famous soon enough
I used this like many others have suggested. I doubt anything has changed since 2010.
https://www.mobil.com/en/lubricants/...synthetic-atf/
https://www.amazon.com/Mobil-112980-...001VY01XA?th=1
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
The Waco Kid is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 10:58 AM #4
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
What does your '15 manual say? The owner's manual for my '19 says:
"Automatic transmission fluid DEXRON® II or III"
ETA: I just wish there was some available out there without the red dye like the factory fill stuff.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 01:01 PM #5
Thanks for all the replies.
"Automatic transmission fluid DEXRON® II or III".
Mine says the same, apologies for not expressing myself well this morning.
I'm leaning toward using the same transmission fluid as used in the transmission...rather than the Dexron version. Since lots of folks are using the M1 fluid as Waco stated, I'm thinking that any transmission fluid that's good for the transmission would be ok for the PS pump as well.
Between outfits.
Old 02-26-2020, 01:20 PM #6
When I changed mine at 75,000 it was reddish brown anyway so the dex 3 I used matched just fine
Old 02-26-2020, 02:17 PM #7
Dynamo's Avatar
Dynamo's Avatar
I would not use Toyota WS transmission fluid for your PS if that's what you mean. The stuff The Waco Kid posted says "Recommended by ExxonMobil for use in applications requiring Dexron III". DEXRON is just a trade name for a group of technical specs of ATF.
2019 TRD ORP
Old 02-26-2020, 02:37 PM #8
EZBR. EZBR. is offline
EZBR. will become famous soon enough
I've used Valvoline MAXLIFE ATF in both trans flush and PS flush.... been well over 30,000 KM's (18-ish k miles) now. No issues
EZBR. is offline   Reply With QuoteReply With Quote
Old 08-18-2020, 11:15 PM #9
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
I'll second that for the PS flush! For the transmission though, I personally stick to either WS or AMSOIL. The transmission and engine is not something I like risking, even a little.
ALL Fluids Guide: Beginner Fluid Maintenance
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 08-20-2020, 12:52 AM #10
I am currently in the process of replacing my PS fluid via the turkey baster method, aka siphon as much as you can then replace.
Using the same Schaeffer Oil as per transmission, seems to be improved so far after 1 cycle, with lighter steering feel and no leaks.
Between outfits.
Old 08-20-2020, 10:04 AM #11
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
Using the same Schaeffer Oil as per transmission, sems to be improved so far after 1 cycle, with lighter steering feel and no leaks.
1. siphon as much as you can out of reservoir
2. add fresh fluid
3. disconnect the top return line leave bottom one connected
4. shove a vinyl tube that'll fit into the black hose as far and deep as you can
5. while vehicle engine is OFF but key is in ACC turn the steering wheel all the way left
6. while holding the steering wheel farthest left, turn the key on for 2 TWO seconds (this will pump out a buttload of old fluid
7. add more fluid to reservoir
8. repeat steps 5 and 6 for turning a full RIGHT
9. observe clean bright red fluid
10. get paranoid about the clicking sounds you'll hear as the PS pump works out the air in the lines
11. post about it on 4runner forum
1jzgte is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 01:02 PM #12
Chilow Chilow is offline
Chilow will become famous soon enough
For those who just sucked the old fluid out and refilled with new fluid, did you rotate the steering wheel in both directions a few times to push out more fluid in the lines or is that not necessary?
Is there a bleeding process for this or simply suck out fluid and replace it. Make sure the fluid level is at the appropriate hot min line?
Chilow is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 03:56 PM #13
JeuTheIdit's Avatar
JeuTheIdit JeuTheIdit is offline
JeuTheIdit will become famous soon enough
JeuTheIdit's Avatar
Another Maxlife user here! Both tranny and PS.
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
JeuTheIdit is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 05:19 PM #14
MAXISTYLES's Avatar
MAXISTYLES MAXISTYLES is offline
MAXISTYLES will become famous soon enough
MAXISTYLES's Avatar
I replaced my fluid with Valvoline Dex/Merc ATF Fluid,Dexron II and III compliant. I lifted the front end of the vehicle slightly so I can easily turn the steering wheel. Used the turkey baster method. I little time consuming but everything worked out great.
There is no bleeding process that I'm aware of.
MAXISTYLES is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 05:43 PM #15
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Excuse the watermark. (Just thought it was strange you mention "red".
Use it in all mine for years without issue.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
5th , fluid , harm , manual , yadda
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
Tranny fluid change...which fluid? wm69 3rd gen T4Rs 3 02-12-2008 01:11 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
