Old 02-27-2020, 11:58 AM #16
Space King's Avatar
Space King Space King is offline
Space King is a jewel in the rough Space King is a jewel in the rough Space King is a jewel in the rough
Space King's Avatar
Just watched the video...
On first blush, here's what I can gather:
1. The surge is perfectly cyclical, which means it's not any sort of intermittent or transient fault.
2. The excessive slop in the slack side of the belt is synchronized to the rotation of the SC. This allows us to eliminate stiction of other accessories on the belt. The cycle starts when the marker on the SC pulley is at approximately the 7 o'clock position, and completes in 1 full rotation.
3. Factoring in item 2, would lead me to believe that there is some sort cyclical variance in the parasitic drag imparted onto the system by the SC.
Jeez, I need to wake up more to speculate any further...
"Sometimes I sit and think. Sometimes I just sit."
Space King is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 12:44 PM #17
brokamonster brokamonster is offline
brokamonster is on a distinguished road
Thanks so much! I checked it out on IG. That's way smoother than mine for sure. The big issue I have with mine is the eccentric flutter which causes a vibration that sounds terrible and can be felt inside the cabin.
brokamonster is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 12:47 PM #18
Good eye! I'm going to take some slow-motion video to see if I can catch that better.
Old 02-27-2020, 12:54 PM #19
Originally Posted by david05111 View Post
It's too bad there's not a Magnuson rep on the site to address this. Frankly, its the type of problem and customer service that would result in the loss of sales. I'm certainly re-thinking it for the future.
The problem may be rare, as evidenced by loads of different positive things I've read about the system, but you're not just judged by what goes right. You're judged by how you deal with someone having a problem, and this doesn't sound like proper customer service to me. Had it been my company, I would have put one of my engineers on a plane to come have a look at it. And if he couldn't figure it out, I'd have him install a brand new one on my dime.
This "it's not our fault and its normal" response is unacceptable. Anyone who knows anything about forced induction knows that's not normal.
Unfortunately, that's their approach at the moment. After dealing with this for almost six months I told the dealer I need my money back and to take it off and suddenly both Magnuson and the dealer changed their tune. Instead of or more attempts to fix the issues they are pretending it's no longer an issue.
I've had the belt flutter since the initial installation back in September of 2019 and the dealer has had it in the shop four more times after that to work on the issue.
I said enough is enough. If it's"100% complete bolt-on system" then I said they can unbolt 100% or fix it.
They didn't like that apparently.
Old 02-27-2020, 01:37 PM #20
Here's a video of how the dealer's demo vehicle idled with the same Magnuson kit, dramatically smoother with ZERO belt flutter.
Link for working belt drive video
And here's a longer video of my 2016 Limited with tons of belt flutter at idle.
Link for belt drive with belt flutter
Do I need to put up a poll or is the difference obvious enough?
Old 02-27-2020, 01:49 PM #21
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
Mine has been fine since day 1, too. Not sure what else to check other than what's already been said, but that definitely doesn't look normal. Hope you get it fixed. Keep us updated
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 01:53 PM #22
Thanks! I appreciate the support!
Old 02-27-2020, 02:17 PM #23
anomalous's Avatar
anomalous's Avatar
I'll check mine after work today, but haven't noticed anything like what you're experiencing. I know how annoying having problems like this can be. Would bother the hell out of me. Reminds me of when I was having problems with downloading the tune file for Magnuson. Will see if there's anything I would check if I were having these problems
Old 02-27-2020, 04:18 PM #24
rossk35 rossk35 is offline
rossk35 is on a distinguished road
Same here mine has no issues or makes noise at idle either I'd say from the video that the belt tensioner is bad or something else not suppose to be like that. Should replace the entire drive belt system with brand new stuff.
07 Tacoma TRD Sport Dub Cab TRD S/C/APR 2.85 Pulley/TRD Intake/TRD Boost Gauge/DT Headers/TL retro/Magnaflow/18" limited 4runner rims
16 4runner Supercharged
94 supra 6 speed
rossk35 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 05:26 PM #25
david05111 david05111 is offline
david05111 will become famous soon enough
Have an independent shop look at it and call an attorney. The amount in question probably falls outside of small claims court.
david05111 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 06:18 PM #26
anomalous's Avatar
anomalous's Avatar
Out of curiousity, does the car idle rough at all ? Does it run ok ? If it idles, or runs rough, I'm wondering if a bad tune could also be the cause. Also, are you 100% positive that the parts changed were actually changed ?
Old 02-28-2020, 01:23 PM #27
Good questions. The engine ran like a champ before having the Magnuson kit installed, 41K miles with all scheduled maintenance done. Even when the Magnuson belt is fluttering, the engine is quiet and the factory serpentine belt is smooth as butter. Luckily, since the entire belt drive is independent accept for the pulley piggybacking off the stock crank pulley it's pretty easy to see the issue is with the Magnuson belt drive. Everyting else on the engine idles nice a quiet like stock.
It could be the tune, it's possible. I'm told many parts were replaced but was never provided any paperwork showing all the work that was done. I can tell at least one tensioner and one belt was replaced because the new parts had different markings.
Old 02-28-2020, 01:26 PM #28
Sadly, this is the path I'm taking since Magnuson and their dealer are now refusing to or can't resolve the issue. Either way, both Magnuson and the dealer won't reply to me anymore
Old 02-28-2020, 02:33 PM #29
boyguan boyguan is offline
boyguan is on a distinguished road
has your mechanic taken an indicator and turned the pullies to check if they are out of round?
boyguan is offline   Reply With QuoteReply With Quote
Old 02-28-2020, 03:19 PM #30
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
could be an optical illusion, but the SC pulley looks out of round to me
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
belt , idle , issue , issues , magnuson
what's with all the garbage posted here!? 01thunder For Sale: T4R Items 9 11-17-2015 07:51 PM
Garbage fightman80 Off Topic 27 09-01-2010 09:56 AM
damne garbage men..... savagebeast 4th Gen T4Rs 1 01-10-2006 11:24 PM
Garbage gonzo 4th Gen T4Rs 3 12-15-2004 05:42 PM
