08-24-2020, 05:17 PM
#91
Yeah no problem, I have put about 1000 miles on it since the install. Install was a piece of cake. Uninstall belt with 1/2" breaker bar on the tensioner. I decided to keep the belt since it looked fine but it wouldn't be hard to install a new one if yours does not look good. I believe the socket for the bolt holding the tensioner is 12mm. Remove that and the tensioner. Put new one in and apply blue loctite to the new one and torque to 18ft lbs. Re route the belt and use breaker bar again. Done.
No more noises or vibrations. It seems to have solved the issue.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
08-24-2020, 05:27 PM
#92
Thanks! Just one more thing. Does it say Dayco on tensioner or something else?
08-24-2020, 05:37 PM
#93
I could not find any markings on it at all before I installed it. Just the box it came in.
08-24-2020, 06:34 PM
#94
Okay. The reason I asked you this, that there’s no Dayco tensioner that looks like yours. But I found another manufacturer that makes tensioners just like your. If you can look at it and tell me what you think? Thanks
08-24-2020, 07:36 PM
#95
Look up 4861277AD, it’s a Mopar part number, from a 2.4L Jeep Wrangler. This part also matches the Dayco part that comes with the kit. Might be something worth looking into.
08-24-2020, 07:38 PM
#96
I would need to see the other side unfortunately. I did a search on Google with the part number you have there and this looks like it may be the other side which looks nothing like mine either.
08-24-2020, 07:44 PM
#97
Got it thanks
08-24-2020, 10:22 PM
#98
They’re sending me a new tensioner
Mods are loading.......
08-24-2020, 10:33 PM
#99
Can’t wait to see how that one going to look like. I have a filing Magnuson send to us anything that they have on the shelves. LOL : keep my fingers crossed 2:
08-24-2020, 10:36 PM
#100
Post some pictures before you installed, both sides please, and # , name, lattes on part will be helpful. Thanks
08-24-2020, 11:28 PM
#101
Sure will, they are 15 minutes away from me. Fingers crossed it shows up tomorrow.
08-25-2020, 12:31 PM
#102
Originally Posted by Dreamw0rkz
So after the third day. I hear another noise, sounds like a light tapping. I can’t pin point what it is right now. I guess I’ll have to wait till it gets a bit louder. 🤦🏼*♂️
Mine sounded like a light tapping and it got louder as time went on (but maxed out after a few weeks) and when the engine was fully heated and on hotter days.
When I first found the issue last September, I'm in AZ, it was loud and then subsided a bit in the Fall/Winter as Magnuson tried to troubleshoot.
When April and May rolled around it sounded like the front end was vibrating off. I was getting looks at stoplights from people, like bro, your truck is going o blow up, lol.
08-25-2020, 06:27 PM
#103
Just heard from Magnuson, they are sending me a new tensioner. They claimed there was quite a few that got sent out that were defective. This was mine.
08-25-2020, 06:43 PM
#104
Mine has same #. Does it mean is defective too?
08-25-2020, 06:52 PM
#105
Is it making any noise at all? Any vibrations when fully cranked with the A/C compressor kicks on?
