Old 06-29-2020, 08:11 PM #61
fbksurferjoe fbksurferjoe is offline
fbksurferjoe is on a distinguished road
Can I see the other side of the new tensioner you got. I want to see which one I have on my kit. This is the one I have.
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
fbksurferjoe is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 10:24 AM #62
pheen pheen is offline
pheen is on a distinguished road
The one you have is the older style tensioner. I had that same tensioner and it was the cause of my issue.
pheen is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 11:20 AM #63
Damn, I am having a slight noise at idle with the ac running and in gear. I checked for flutter but I don't see anything. It only seems to happen when it is in gear. I am going to give them a call and just get a new one. Sounds like it is a common enough issue that I am just going to change it out before it becomes a bigger issue.
Old 06-30-2020, 09:10 PM #64
Sounds like my issue. It was more pronounced when in gear and the AC on.
Yeah I would give them a call and get that replaced asap...
Old 08-19-2020, 01:51 AM #65
Dreamw0rkz's Avatar
Dreamw0rkz Dreamw0rkz is offline
Dreamw0rkz is on a distinguished road
Dreamw0rkz's Avatar
I am
Having the same issue with the fluttering and noise inside the cabin area especially with the AC compressor engaged.
I’ll check the tensioner assembly tomorrow to see if it’s the newer style or the older one.
Just had mine installed a week ago. 🤦🏼*♂️
2016 4Runner Trail Edition silver met.
Under construction!
Dreamw0rkz is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 05:40 AM #66
mailbox mailbox is offline
mailbox is on a distinguished road
Originally Posted by brokamonster View Post
Final update, the dealer did remove the kit last week and gave me a refund.
We know 4Runners are painfully slow, but damn they are so slow! Once you go SC you should never go back, lol.
Good on Magnuson for providing all the OEM parts needed for the reversal (after I threatened to sue the dealer).
Bad on Magnuson and their dealer for attempting to ignore me long enough for me to go away.
I'm glad my issue prompted them to keep digging and find the manufacturing issue in the tensioners.
Thanks for everyone that helped with suggestions and provided video of properly working kits :-D
/unsubscribe
well now you gotta guinea pig a procharger kit for us
mailbox is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 10:05 AM #67
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
Originally Posted by Dreamw0rkz View Post
I am
Just had mine installed a week ago. Magnuson SC Kit Idles Like Garbage - HELP!*Magnuson SC Kit Idles Like Garbage - HELP!
Let us know which one you have.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 10:22 AM #68
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Would like to know as well. Can you post a pic of your tensioner?
ax2021 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 01:51 PM #69
Dreamw0rkz's Avatar
Dreamw0rkz's Avatar
So it seems like the tensioner that I have is a newer one ? But it have a lot of play and the rattle noise is louder with AC on.
Magnuson SC Kit Idles Like Garbage - HELP!-2a98a152-2a24-4fc5-96f0-fd89ae47db04-jpeg  Magnuson SC Kit Idles Like Garbage - HELP!-73a817bd-06d3-443e-9dfe-462f65588351-jpeg
Under construction!
Old 08-19-2020, 04:43 PM #70
Dreamw0rkz's Avatar
Dreamw0rkz's Avatar
So I have emailed Magnuson and hey are sending me a new belt tensioner, let’s see how it goes when I get it swap out.
Under construction!
Old 08-19-2020, 04:55 PM #71
Post the pics from both sides,when you receive it. Thanks
Old 08-19-2020, 07:00 PM #72
I sent them an email today still waiting on a response. I have the exact one that you do. Not loose at all just a little more noise or grumble when the A/C kicks on.
Old 08-19-2020, 09:44 PM #73
Same here! It was perfect for 300 miles or so and same story, nothing crazy just a little noise and vibration when A/C clutch kicks on, SC also doesn’t sound the same. I kind of had a filing about it, right before living after installed SC from the Shop I tried to squeeze belt right under SC pulley, and it was solid as a rock, now I can literally touch my fingers doing that. Well looks like I’m next one to email them. Thank you guys for info!
Old 08-19-2020, 10:41 PM #74
I responded to another thread but I had the same issue. Received a new tensioner and the rattle is gone. The new one is completely different. No black cover anymore. Here is the new one and the box it came in. Several people have noticed that the pulley and other parts look completely different than the dayco part number so I'm not sure if magnuson changes some of the components before shipping it.
Old 08-19-2020, 11:02 PM #75
Copy that. Thanks
belt , idle , issue , issues , magnuson
what's with all the garbage posted here!? 01thunder For Sale: T4R Items 9 11-17-2015 07:51 PM
Garbage fightman80 Off Topic 27 09-01-2010 09:56 AM
damne garbage men..... savagebeast 4th Gen T4Rs 1 01-10-2006 11:24 PM
Garbage gonzo 4th Gen T4Rs 3 12-15-2004 05:42 PM
