Old 08-25-2020, 07:29 PM #106
fbksurferjoe fbksurferjoe is offline
fbksurferjoe is on a distinguished road
Mine was when in gear with ac running. Specifically in reverse. Here is a video of it.
August 25, 2020 - YouTube
Sent from my SM-N970U using Tapatalk
14' 4runner SR5 4x4, Baja Designs Squadron Amber Fogs, Dual Battery, Icon Extended travel CO, Icon tubular UCA's, RCI Skids, Custom Sliders, Icon 2.5 RR Shocks, OME 2895e, custom aluminum cargo area, Dometic 50 fridge, front runner fridge slide. Relentless fabrication LOPRO, Expedition one rear bumper with swingout. Build Thread
fbksurferjoe is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:02 PM #107
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Originally Posted by TrailRunnin14 View Post
Is it making any noise at all? Any vibrations when fully cranked with the A/C compressor kicks on?
No. Nothing crazy but it has some vibration only when A/C clutch kicks in and last for 2-3 seconds. In gear or while driving nothing at all.
ax2021 is offline   Reply With QuoteReply With Quote
Old 08-25-2020, 08:07 PM #108
Wow! Just watched your video, really bad, mine don’t do nothing close to it. Glad you solved that problem!
Old 08-25-2020, 11:54 PM #109
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
WTF Magnuson they look exactly the same, I hope something is different internally in this one. I’ll come back with an update after I’m done replacing my water pump.
Magnuson SC Kit Idles Like Garbage - HELP!-3cad08b4-d5d2-4e97-bfea-62bc1c564906-jpg  Magnuson SC Kit Idles Like Garbage - HELP!-d2e7e319-6536-4af9-8836-c173aa13920a-jpg
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 08-26-2020, 03:01 AM #110
What the heck, I hope it works out for you. I wish I knew what tensioner I have then.
Old 08-27-2020, 09:42 AM #111
Sent email to Magnuson pic of your tensioner was included. Trying to get logical explanation why people are getting different looking tensioner with the same part # . Hope they can clear that for us.
Old 08-27-2020, 12:56 PM #112
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I got a response yesterday from Magnuson over my concern of the tensioner issue. I sent them pics of mine and they are sending me a new one. So it will be interesting to see which one I get.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 08-27-2020, 04:31 PM #113
I will say when I inatalled mine the overall thickness of the tensioner was less. I dont know if uou can see it in the picture but the black arm for the hose support had to be bent a little so that I could get the bolt started. The tension was definitely more than the other one, I used the same breaker bar on both and the new one was much harder to get the belt on.
Old 08-28-2020, 07:58 PM #114
Any luck man ? Because mine getting worse. Magnuson never got back to me.
Old 08-28-2020, 08:52 PM #115
Yes I have one on the way. I’ll keep you updated. I could probably give you a contact if you need one.
Old 08-28-2020, 09:24 PM #116
That would be great. Thanks
Old 08-28-2020, 11:05 PM #117
I sent you a PM.
Old 09-01-2020, 06:25 PM #118
Now to add a little more to this, here is what I received today from Magnuson.
Old 09-01-2020, 11:43 PM #119
Maybe we are looking at this all wrong. Maybe I am the one who got the wrong tensioner?
At least yours has a different part number now. Maybe it will be better.
Old 09-02-2020, 06:09 PM #120
PAKM4N PAKM4N is offline
Real Name: Pak
PAKM4N is on a distinguished road
Real Name: Pak
Originally Posted by Paragon1 View Post
mine has been fantastic since day one, apart from the coolant hose rubbing against the belt and getting cut, but the dealer fixed that. Hopefully they'll figure it out.
this happened to me today too. I was freaking out because coolant was all over the place. What was the fix? If i put it close to one side itll be too close to the fan and if i put it the other side itll be hitting the belt.
2015 Toyota 4Runner Trail Edition/KDSS, SCS Stealth BR6, C4 rear bumper ,Relentless front bumper ,RCI under armor, 4.88 gears, dual battery, iKamper rtt
PAKM4N is offline   Reply With QuoteReply With Quote
belt , idle , issue , issues , magnuson
what's with all the garbage posted here!? 01thunder For Sale: T4R Items 9 11-17-2015 07:51 PM
Garbage fightman80 Off Topic 27 09-01-2010 09:56 AM
damne garbage men..... savagebeast 4th Gen T4Rs 1 01-10-2006 11:24 PM
Garbage gonzo 4th Gen T4Rs 3 12-15-2004 05:42 PM
