Old 01-26-2021, 04:01 PM #136
brokamonster brokamonster is offline
brokamonster is on a distinguished road
I wish mine would have worked, and Magnuson wouldn't have botched the tensioner issue for the better part of a year.
Just don't get a defective tensioner, and you'll be happy.
The coolant lines and tank are very cheaply done. Like others, mine was leaking after only a few months. Had I kept the SC, I would have re-done the tank and lines. You could get away with just better clamps, but the tank is really thin. It's not something that feels at home on such a well-built kit.
Not the greatest experience for me and Magnuson's customer service left a bad taste in my mouth. But I'm the exception, not the norm.
brokamonster is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 10:33 PM #137
Raymich24 Raymich24 is offline
Raymich24 is on a distinguished road
Shipment arrived! Need to plan a weekend for install. Picture of tensioner shipped ~ February 2021.
Magnuson SC Kit Idles Like Garbage - HELP!-img_2651-jpg
Raymich24 is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 10:43 PM #138
05EVORS 05EVORS is offline
05EVORS is on a distinguished road
Thats the made in china tensioner, the same one that goes bad on these kits and went bad on mine. They sent me a made in EU version that is the all silver one no black front different design with a deeper 1/2" drive cutout. The china ones round out super easy w your breaker bar bc they are very shallow and you cannot get good engagement so BE CAREFULL and tape around your 1/2" drive to keep ut solid in there when trying to get your belt off. Maybee use 2 peeps to work belt loose as you use 2 hands to relieve tension. Call/email maggie and demand the non China-man version!
05EVORS is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 11:13 PM #139
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
So why do you get a new tensioner? I understand a new belt, there’s an extra pulley, but other applications let you keep your stock tensioner.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 11:41 PM #140
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
You keep your stock tensioner but with the new blower you add a new drive belt system onto your OEM one. This requires another tensioner for the supercharger belt.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 11:43 PM #141
Did you talk to someone particular at Magnuson? The made in China ones are cheap. I would like to try a EU version. Did it ship in the same box, model number? Just wondering if it’s even a Dayco brand?
Old 08-23-2021, 12:13 AM #142
Ok so Mine was installed in March '21 on my '17 with 55k miles(61k when replaced) and a month later I started hearing the very low noise when It was in gear w AC on/low fan setting it was noticiable pulling away cold in morning out of the garage. Eventually it got worse during a big road trip cross-country and the noise was replicated by turning AC off when the now semi-loud noise would instantly go away. I was blaming my AC clutch and searching forums for that, but FINALLY figured it all out when I opened the hood after putting parking brake ON and IN GEAR w AC ON. Looked underhood and boom......when AC comp cycled it TOTALLY induced some sort of harmonic vibe from the main belt drive to to blower belt drive. The chinese (black) tensioner it ships with flaps back n forth and its totally obvious the outer belt flaps around wildly almost slapping the inner idlers. This happens ONLY when AC clutch is locked in-cycle. Apparently the 'supplied china tensioner' that happens to cross reference from a Mopar application for 15-20 y/o fwd 300c/jeeps is not rated correctly for our belt stiffness and the all silver one is. The silver EU part has a whole different design to the spring/housing.
My theory is that the belt length specified is SUPER stiff anyway before it breaks-in and the weaker spring in the supplied tensioner gives out from the initial belt stiffness quickly...as in several hundred miles it starts to display faint noise w AC running.
To start my repair story, after seeing this thread and coming to conclusion that it has to be it, I emailed Magnuson tech, he requested a movie of it(cell phone worked fine like 8sec vid, proof on invoice from dealer/installer) & they replied within a day that a replacement tensioner would be shipped. They also supplied a new idler pulley to put on the tensioner since they do not come w it installed. You can re-use the one on there I guess and take chances w another prob, or just use the new idler they also ship. Got it all 3-4 biz days later bc of weekend and starting the claim on a Friday. I was going to have local Socal dealer swap it since they were the o.g. auth installer, but bc the 1/2" drive socket square was starting to round off from me trying to mess w it(cheap china one sucks!) Technician said he wanted to CUT my belt and then remove the tensioner b/c he did not feel comfortable putting leverage on the magnuson specific water neck housing thats next to tensioner (he claims he could not use his breaker bar!!!.
Note: If water neck breaks its 60-90 days for new water neck or for ANY magnuson specific blower related parts so be carefull!) And also belts ...nobody stocks the belt locally in socal even.... so... I laughed in the techs general direction and went home and just did it myself. I had my son help me w a 3rd hand while i used my 2 hands to relieve tension on the Chinese junk while not hurting my belt or water neck w a cheater bar using my breaker bar that I wrapped tape around the drive to make it fit snug where it was starting to round-off. After completion in 20 minutes It was obvious that the magnuson install tech was trying to sheist me out of 3 hrs billable.
To add spice to story the same dealer had another 4R in there getting a blower done and they told me even the latest kits have the same Chinese tensioner inside!!! So...do yourself a favor if your looking to install one even thru a yoda stealership - BUY the $40-50 replacement tensioner from Magnuson AHEAD of install and have the tech use it instead. Its sad that Magnuson needs to be doing a recall on these and/or sending communication + matching # of correct better Tensioners as a supplement to each kit thats in inventory. Toyota people are very loyal and precise and Magnuson should be stepping up to show accountability. I even recommended to the dealer that they proactively order a few Tensioners as a precaution and invoice them out $00.00 IE; eat the cost or even just retail sell to the new customer...that would pay to not have to deal with the worry down the road.
Heres the Magnuson part#s for made in EU Tensioner I was shipped
# 56-50-53-012 Dayco 89280
....and the Idler that bolts on it
# 56-50-53-001 Dayco 89143 75mm 6rib
The Internet sells BOTH chinese and the made in EU on the box version under DAYCO brand # 89280 so choose wisely and only use an all silver one w made in EU on the box. The crappy one has black circle front and made in china is visible next to the 1/2" socket drive insert.
Some sources online show the china black one and some show pics of the better all silver tensioner. Its up to you to possibly find the right one for $30+ from rock auto, amazon, etc; im willing to bet Magnuson is the best bet since they know its a big problem now,..... but some of these posts prev show Magnuson sending out yet another black china version w the shallow 1/2" drive. Smfh??!! !!!
To play it safe bc belts arent stocked locally and bc chyna-virus has stuff backordered, I also bought a second blower belt from amazon jungle for $32 to be safe and ready:
Dayco Poly Rib V-Ribbed Belt (5060701)
To be clear here, the stealership service writer said maggie has had issues with the Tundra blowers also I believe its a coupler inside the case. Customers are having to pay x2 labour for installs bc the blower has to be completely taken apart to swap warranty couplers. The magnuson warranty does NOT cover ANY labor costs, only parts. Im willing to bet if Toyota still sold these under TRD name labor would be included. Maybee this is part/why Toyota quit selling them as an accessory. Just something to think about if your on the fence with getting a maggie. The upcoming '22+ Boosted OEM drivelines might be worth waiting for?
I love having 350hp/355tq now pushing 33's around it is totally worth it especially w the whine. But after spending 25years playing w cars one thing has never changed and that is that aftermarket stuff is rarely perfect, there is always something that screws up lol. Hope this helps.
Old 08-23-2021, 12:18 AM #143
I think dayco has 2 different suppliers and you have to just figure out how to source the all silver one on your own or make sure maggie wharehouse person picks one off shelf that is all silver/made in EU before sending out. The Dayco box I was sent says Made in EU and the part is nicer quality(imo)
Old 08-23-2021, 01:04 PM #144
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
....and this is why I'd never supercharge a car that didn't come with one in the first place. Over the past 20 years or so, I know lots of people that have added Vortech/ATI/Edlebrock/etc SCs to their muscle cars and trucks and they've all had reoccurring issues with tensioners, idler pullies, alignment issues that cause belts to throw, etc.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 08:49 PM #145
It really sucks that Magnuson can't source a reliable part. Aside from this ongoing tensioner issue and the tank/coolant lines, the kit is OEM quality. I had the tensioner issue two years ago, and Magnuson is still skirting the issue, blaming their sub-manufacturers. I want to SC my FJ and was hoping this problem was long gone, but I guess not.
Old 09-03-2023, 09:27 AM #146
Joanbritts Joanbritts is offline
Joanbritts is on a distinguished road
Thumbs up Dayco is great
I got one from Dayco a while back, its the Dayco HD Automatic Belt Tensioner 89470 (the link is
89470 by DAYCO - AUTOMATIC BELT TENSIONER, HD, DAYCO.)
It's been with me for three or four years now and even though it's a little pricey I have not regretted the purchase once. Around one and a half kilos and absorbs compression shock really well. I do construction work so a lot of the stuff carried with it eventually just gets thrown out here at a bin dump.
That's just my suggestion anyways
Joanbritts is offline   Reply With QuoteReply With Quote
Old 09-03-2023, 11:25 PM #147
Hbc234 Hbc234 is offline
Hbc234 is on a distinguished road
Has this issue been fixed in newer Magnuson kits? I asked them recently about the coolant line issue and they claimed the new design had solved that problem.
Hbc234 is offline   Reply With QuoteReply With Quote
Old 09-05-2023, 12:20 PM #148
Probably, I haven't seen anyone complaining about this issue in well over a year.
It's also an easy fix if you do have the issue, they just need to supply the correct tensioner.
belt , idle , issue , issues , magnuson
what's with all the garbage posted here!? 01thunder For Sale: T4R Items 9 11-17-2015 07:51 PM
Garbage fightman80 Off Topic 27 09-01-2010 09:56 AM
damne garbage men..... savagebeast 4th Gen T4Rs 1 01-10-2006 11:24 PM
Garbage gonzo 4th Gen T4Rs 3 12-15-2004 05:42 PM
