Old 03-01-2020, 10:31 AM #1
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
Adjusting low beams
I put a 3" lift in a few weeks ago and finally got around to adjusting the low beams down a little so I'm not blinding on coming traffic.. well after looking for over 30 mins, removing covers, looking in the owners manual, I can't see how to adjust my low beams. Tell me there's a trick I'm just missing. I'm pretty mechanical incline but damn this one got me stumped.. how do you adjust the low beams?
mr.walleye is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 10:45 AM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Screwdriver straight down through the radiator cover.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 10:50 AM #3
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Remove the plastic panel by the radiator so you can get behind the grill/headlights.
There's an 8mm bolt that you turn to raise or lower the beam. A ratcheting box end works best.
The bolt also accepts a Phillip's screwdriver through a hole in the radiator support.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 10:51 AM #4
08TxRunner's Avatar
08TxRunner's Avatar
Why would you remove the panel? There are access holes for the screwdriver.
Old 03-01-2020, 11:10 AM #5
I removed the panel because I didn't know where the screw/bolts were.
Now I do.
I also wanted to look behind the grill. I've only had the truck for 3 months (now)
Old 03-01-2020, 12:06 PM #6
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Clockwise lowers if I remember right
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 01:27 PM #7
08TxRunner's Avatar
08TxRunner's Avatar
Here's the procedure I followed. It's a pretty good write up.
How to Aim your Low Beam Headlights - 5th Gen Toyota 4Runner
Old 03-01-2020, 03:21 PM #8
Thanks guys! I was looking yesterday after a 16 hr shift, this morning it was right where it was when I adjusted the morimoto bulbs I installed months back and where you said the adjustment screw was. I feel kind Of duh..
adjust , adjusting , beams , low , put
Adjusting DRL/High Beams VT4RunnerSR5 5th gen T4Rs 5 10-18-2017 02:28 PM
Very simple question: why are low-beams in a protective case but high-beams aren't? Da8ron 5th gen T4Rs 2 04-17-2017 06:13 AM
High beams work, low beams don't? Shine4JC 3rd gen T4Rs 22 12-24-2015 05:33 PM
Low beams, high beams, and fogs won't work... twkoch 3rd gen T4Rs 10 05-07-2015 07:33 PM
Flashing High Beams without Low Beams? Offroader 4th Gen T4Rs 3 04-02-2006 08:04 PM
