Old 12-13-2020, 09:46 PM #16
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by jp.vegas View Post
And give up my seat heaters? Noooooo
It's a Limited ... the seat warmers are up in the console.
rageandlove is offline   Reply With QuoteReply With Quote
Old 12-13-2020, 10:58 PM #17
Originally Posted by jrandom View Post
Thanks, I’m glad I stumbled upon it.
I have a fused subsystem that is directly connected to the battery, it is controlled via “keyed” relay (the relay is triggered by the key when turned to “on” the step before accessory) that is where I pull the voltage from, so it is as close to the batteries “true” voltage.
You could easily wire it direct and throw a toggle/push inline so that it is on demand.
I would be super cool it the meter was a push button switch itself.
Thanks @jrandom . That's a great idea. I might email the good folks in Australia and suggest they give you a dozen as a royalty :-).
I'm more interested in watching the voltage when the vehicle isn't on, specifically when I am out doing trips to make sure I don't run down the battery too far at night when I use it for lighting etc. So I think I'll go with your second suggestion about an in-line switch.
I've never managed to find a toggle that fits in the 4Runner blank that can work without a relay ... anyone else out there ever seen one? The more stock looking the better.
Else, I guess I'll just drill a hole in one of the blanks next to where I put in the voltmeter and use something like this, which will still be pretty discrete hopefully.
Old 12-15-2020, 11:39 AM #18
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I am pretty sure you could use one of the regular ~3amp 150 Toyota push buttons, the voltage meter isn’t going to draw much power to run. I’d be really surprised if it drew anywhere near 3 amps.
Just checked, from their website: Dual Battery Volt Meter for Toyota Prado 150, Landcruiser 200, 2016 Hilux - Solid Kit
Low current draw, only 14 mA per panel (0.336 Ah per day)
There you go
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 07:40 PM #19
There you go
Thank you! I'll give it a whirl and use a 2A fuse just in case. I'll try and remember to report back when I get around to it - have some other wiring to take care of first.
Old 01-13-2021, 11:52 PM #20
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
LOL. Looks like... With the logo
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 11:59 AM #21
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
<<<< is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 03:17 PM #22
OK, for anyone else that shows up on this thread and wants to know how to use an AOB switch (what I used) to power an in-dash voltmeter (like this one), here's what I did:
Note, the switch is on the negative because the gauge requires each volt meter to be wired independently to the battery ... this way one switch can still control both. Hence the funky red (switch) to ground (voltmeter).
Old 06-29-2024, 11:05 AM #23
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by jawkdna View Post
That one is no longer available. Anyone know of one like that to fit in the dash of my 2018 4Runner?
All the ones I can find are for earlier years.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-29-2024, 01:52 PM #24
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
I've had this one for years now. Always on and seems to be pretty accurate as well. Don't remember where it came from, but I see others that look the same listed in other post.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 06-29-2024, 10:28 PM #25
Thanks. I only need one display since I don’t have an aux battery.
Old 06-30-2024, 11:50 AM #26
<<<<'s Avatar
<<<<'s Avatar
Old 06-30-2024, 10:20 PM #27
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
based on the other models that work with the one that is no longer available, this one fits... can't be sure but looks to fit
Amazon.com
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 06-30-2024, 11:16 PM #28
Amazon.com
Thanks. That looks like it might fit, plus it uses the connector to the 12 volt outlet. I'll order it and see if it fits.
Old 07-02-2024, 02:03 PM #29
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
TPMS DISPLAY WITH PSI/TEMP - Style A | Luxious Automotive
Dual DC Voltmeter - Late Toyota applications
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 07-04-2024, 05:12 PM #30
Amazon.com
Received this a yesterday and installed today.
Pros:
1. Fits nicely in any of the 4Runner blank switch places.
2. Plug and play. Connects to the 12 volt outlet connectors. No wire cutting, tapping, or fuse taps needed.
3. Nice long wire (4 feet) so you can place it in any of the blank switch places and have it reach the 12 volt outlet.
Cons:
1. Very dim. Impossible to see in the day with sunglasses on.
2. Voltage display is quite low. Display showed 13.1 volts, while my precision voltmeter displayed 13.42 volts.
3. Display voltage drops a couple tenths if you plug in a device to charge, such as my iPhone. I can't believe the system voltage drops that much.
blanks , dash , found , plenty , switch
Volt meter/ usb plugs Johnnie General Discussions 0 08-28-2019 11:02 PM
Thoughts on this volt/amp meter Rocket61 4th Gen T4Rs 1 02-25-2016 04:31 PM
Rear seat power port and volt meter concordcarlos 3rd gen T4Rs 8 11-15-2015 12:38 AM
!2 Volt power some place in dash? nathannookie 4th Gen T4Rs 4 03-05-2004 09:30 PM
